11-20-2018, 05:18 PM | #1 |
Member#: 393208
Vehicle:2006 Wrx Crystal Grey Metallic |
2014 WRX - Hard Start / Long crank
If I park the car overnight or go to work (6-8 hours) the car starts fine no issues. If I head to the gym/school and come out after 1-3 hours and try to start it I have this issue shown in the video. I took it to a mechanic and a Subaru dealership, both times the car magically went back to normal. I brought recordings and everything but they couldn't get it to happen. When I picked up the car from a shop and the dealership the car started up like normal. It just gave me a code for a missfire in cylinder #2. I'm going to see if maybe the spark plugs are worn out and check the coilpacks as well. The car has 46k miles I bought it with 42k. If anyone can maybe help me out on what else to check on thursday I'd appreciate it.
11-21-2018, 08:58 PM | #2 |
Member#: 472037
Vehicle:2018 WRX Limited CWP |
Could it be a leaky injector?
11-22-2018, 12:12 PM | #3 |
Member#: 459629
International
Vehicle:2017 WRX base WR Blue |
Plugs are cheap. How long since last set?
11-24-2018, 09:09 AM | #4 |
Member#: 393208
12-07-2018, 12:57 AM | #5 |
Member#: 100300
Vehicle:06 WRX CGM |
That's similar to how my car starts after the battery has been disconnected.
Only the first start after reconnecting it, but really really similar to your video. |
06-06-2019, 08:10 PM | #6 |
Member#: 502940
2014 Hard start
So did you ever figure out what it was? My car just started do this today!
06-10-2019, 04:37 PM | #7 |
Member#: 502940
So my car went to the shop, loose ground touching starter, causing sparks to be seen underneath the car when I tried to start it. Also CAM position sensor went bad again. Suppose the bad ground could have caused this to fail, last one was inatalled 1 year ago. Problem solved.
06-20-2019, 05:48 PM | #8 |
Member#: 393208
No, I still haven't figured out the issue. I've swapped out the fuel pressure regulator as well cleaned out the MAF sensor. I still have this issue and it's beyond frustrating.
07-17-2019, 08:46 AM | #9 |
Member#: 504346
That sounds like your sparkplugs or maybe a failing injector? I was having a similar issue in my 04 and I replaced the sparkplugs and it was fine and CEL went away.
08-20-2019, 07:23 AM | #10 |
Member#: 393208
05-12-2020, 11:49 AM | #11 |
Member#: 393208
I have swapped injectors and spark plugs but still have this issue. Took it to shops and they couldn't figure it out as well.
