03-11-2021, 12:44 PM | #1 |
Member#: 494757
Vehicle:2011 STI Hatch Black |
WGDC Question
I did a stupid and bought a poorly sized turbo, and I'm working to get it spooling a bit faster.
I've read most of the posts regarding WGDC questions, and one person mentioned logging these things during boost tuning: -Manifold Pressure (aka boost) -Target Boost -Max WGDC -Turbo Dynamics Continuous -Boost Error I've been logging, but not all of those values, so I'll do some more logging this afternoon. My current tune has a max PSI of ~26, but my WGDC is at highest 71% before it gets to the target pressure. Should the WGDC be 100% or close until it reaches my target PSI? My brain is telling me I wouldn't want the EBCS to open the wastegate at all until it's close to target. Side note....how many people have two turbos and swap them for the occasion? If I bought a smaller faster spooling turbo that could be plumbed the exact same way it'd be a somewhat easy job to swap 'em as desired.
03-11-2021, 01:06 PM | #2 |
Member#: 363007
Vehicle:2008 STI Black |
You can set it at 100% but you risk overboosting past your target, because it takes some time for WGDC to affect boost level. You'll want to start lowering WGDC before you reach your target.
03-15-2021, 11:30 AM | #3 |
Member#: 494757
Well....time for a new clutch. I thought it (the stock clutch) would be more of an issue in lower gears but on boost in 3rd and 4th has some really weird RPM surging...I was hoping to do that upgrade last because I really don't relish the idea of pulling the engine again. Boo.
03-15-2021, 12:35 PM | #4 |
Member#: 53558
NWIC
Vehicle:2005 Baja Turbo White/Silver/Black 3tone |
Smaller, faster spooling turbo? You mean, like a TD04? Full boost at 2,250RPM, runs out of breath at around 4,000RPM? Yeah, living that dream.
Which turbo did you get? There are hardware things you can (or, could) do to get faster spool. One is a TBE, another is delete the uppipe cat. Get a better turbo inlet, go with a smaller intercooler, and run silicone hoses everywhere. One you can't do anymore, apparently, is delete the TGV's. >_> MFG, what a lame BS mess this is... |
03-15-2021, 01:01 PM | #5 |
Member#: 494757
Let's just say the turbo is far too big...and I should have listened to others saying I'd enjoy a fast spooling turbo a lot more.
I had to replace the short block a couple of years back soooo....in the process of doing that I did a bunch of other stuff and have been working on it bits at a time... Secondary air pump delete TGV Delete Upgraded fuel pump 1500CC DW injectors DW Rails DW FPR new fuel lines closed deck block with forged internals and 14mm head studs Full turbo back exhaust Grimmspeed uppipe AEM CAI Torque Solutions 3" Turbo Inlet (ffffff that was a bi*** to install) TiAL 44mm wastegate with dump tube (venting to atmosphere) I can't think of any more. Still to do in a general order... Clutch/flywheel FMIC Go Rotated spare turbo, maybe GTX3071 or 3076 Head Work equal length headers air oil separator depending on community feedback and research flex fuel sensor install somewhere in this list Suspension mods exhaust work to plumb ewg into downpipe.... Paint job .....it's a GTX3576R. F. Me. Scary acceleration once it hits but holy f it spools slow. Queue the community laughing :-p Last edited by putrio; 03-15-2021 at 01:09 PM. |
04-18-2021, 09:50 PM | #6 |
Member#: 520219
Vehicle:2006 Forester XT 5mt Crystal Grey Metallic |
I think you'll find this video helpful:
70% WGDC at full boost should be fine (7:20) |
04-18-2021, 10:22 PM | #7 |
Member#: 508105
NWIC
Vehicle:Link G4X flex tuned 02' EJ205 20G 6MT wagon |
I have a GTX 3576 Gen 2 spoolinator kit going on my car soon and from everything I can see the 3576 on a 2.5L should pretty good with AVCS and proper tuning.
Are you rotated? Is it an ATP or stock housing turbo? Gen 1 or gen 2 3576? And if you're running a 3576 on unported stock headers you are in for a tough time. If you want it to spool well and you want to keep the same turbo do the following: Find a GOOD tuner who knows what he or she is doing and ask them to tune your car with spool in mind. Buy Killer B or equivalent headers or port your headers Switch your oem style hotside for a properly sized (A/R) hotside compatible with a quality rotated kit. I suggest a V-band style kit. Run ethanol! Last edited by K3rm1tth3fr0g; 04-19-2021 at 05:36 PM. |
04-19-2021, 09:47 AM | #8 |
Member#: 518830
RMIC
Vehicle:2009 WRX dark grey metallic |
there's some great discussions on this on the Romraider forums. I know for me- I improved my turbo spool about 500 rpm by playing around with my AVCS timing. I'm still in the process of tuning everything, but pretty big differences. the thing I ran into next was compressor surge when coming on boost- so I've had to reduce my WGDC where that was happening which makes my boost curve less of a cliff you climb and more of a curve. But my torque curve looks way better than it did before tuning it. some other tricks to improve spool I've read are playing with your AFR to be a bit leaner (say 12-13:1)when building boost to get the exhaust a little hotter. but really so many things are inter-related that it's a challenge to say "do this" to get better spool. it's more like "experiment with these five variables".
