12-16-2015, 09:59 PM | #3751 |
Member#: 165749
Can't find the IT thread. looking for advice or recommendations...
Aunt moved in next door to grandmother, because she's a saint. xmas gift is a tech upgrade for grandma because she loves that ****. A router that my aunt can host on her IP that will wirelessly connect to devices a house over in suburbia. Brick outside walls, 1/4 acre lots. Is a high gain antenna the best idea. Unidirectional is not an option since everyone in my aunt's house will also use it. Thx for any ideas or suggestions.
12-16-2015, 10:19 PM | #3752 |
Member#: 31016
NWIC
Vehicle:2016 Focus RS (blue) 2005 WRX Wagon (white) |
are they RIGHT next to eachother? I would consider running cat 5e over. Easiest and cheapest solution.
12-16-2015, 10:46 PM | #3753 |
Member#: 17256
South East
Vehicle:18 Outback on the road.... |
12-16-2015, 11:00 PM | #3754 |
Member#: 165749
They are right next door. Is there a wireless option that would be reliable? I'm 1000 miles away and will be home for 7 days over the holiday. Won't have much time to dig a trench, conduit and lay cable, run through walls in and out, etc.
12-16-2015, 11:11 PM | #3755 | |
Member#: 203905
12-16-2015, 11:51 PM | #3756 | |
Member#: 93830
Charge had essentially the same challenge as you've described, and has already deemed the wireless bridging route is simply not reliable enough for his buddy. I'm sure there is something out there that, technically, would work. However the variables would be 1)cost and 2) reliability. Considering you're 1000 miles away and the initial point of contact should there be an issue, the best solution would be to run Cat6 between houses if getting a separate service is out of the question. I doubt you want to spend your holiday breaj doing manual labot but...A handy-man should be able to trench with a machine, lay down some pvc pipe and fish a wire through. |
12-17-2015, 12:44 PM | #3757 |
Member#: 31016
NWIC
You do not need to dig a trench for Cat cable. No conduit needed. hell, just drill a hole through the walls, these wires don't carry high voltage or anything. Seriously, run it along a fence with some staples. As long as there are no sharp bends in the wire, it should be fine. If you have a friend who does IT in the area, have them bring over a crimping tool and test it. Otherwise, you will need to learn how to do this yourself, but its not hard and there are a million guides on the internet.
12-17-2015, 02:19 PM | #3758 |
Member#: 244749
Vehicle:13 BRZ 14 690 Thumper |
Well, the 250D might be short lived. Preordered an NCASE M1 V5. Now I just need the Corsair SF600 to release. Right now the Silverstone 600w SFX power supply does not appear to be the best choice (many negative reviews).
12-17-2015, 02:45 PM | #3759 |
Member#: 82243
Vehicle:13' BMW X3 35i |
Nice to see another Ncase user (or soon to be)! What are the other parts of the build?
Didn't even know Corsair was coming out with an SFX power supply, hopefully they can get the fan to be quiet as that's the most brought up issue people have with SFX. Last edited by ptirmal; 12-17-2015 at 02:54 PM. |
12-17-2015, 02:56 PM | #3760 |
Member#: 244749
12-17-2015, 03:03 PM | #3761 |
Member#: 82243
Very nice. I'm running a 4770k, 8GB Crucial something, Noctua C12p, EVGA GTX 770 with 240GB SSD, 480GB SSD and 1TB HDD (2.5").
12-17-2015, 03:11 PM | #3762 |
Member#: 244749
Very nice. The only part I'm worried about fitting is the H100i GTX. I can't find any pictures of one being used, and only found a forum post. I do have slim fans though, if needed. I've got a couple months to get it figured out though.
12-17-2015, 03:14 PM | #3763 |
Member#: 82243
I remember seeing a few guys do it, shouldn't have much of a problem. You're not using the HDD side bracket so I'm guessing your HDD is 2.5"? Or you're mounting it on the floor?
12-17-2015, 03:22 PM | #3764 |
Member#: 244749
I'll mount the platter drive to the floor, and the 2.5" drives stacked in the front. If I can find another way to mount the 2.5" I'll do that because I'd LIKE to use an optical drive, but if I can't, it's not a huge deal as I'm not using one now.
12-17-2015, 03:36 PM | #3765 | |
Member#: 93830
12-17-2015, 04:06 PM | #3766 | |
Member#: 36838
Vehicle:2001 B50 RSTi Sedan 2011 DGM WRX hatch |
The truth is, for anything I could want to build the M1 for, I could just get a NUC that is even smaller, and it would work just as well (considering I already have a gaming PC and wouldn't be building the M1 for gaming) I could build an M1 as another server, but would still want more storage options if I did that. . Last edited by AcquaCow; 12-17-2015 at 04:17 PM. |
12-17-2015, 04:16 PM | #3767 |
Member#: 244749
I wish I would have discovered it sooner. Wouldn't have bought the 250D. Buuuut I suppose I can use the excuse that I had to house the mITX build in something until the V5 ships.
12-17-2015, 05:33 PM | #3768 |
Member#: 31016
NWIC
Posted it in the Fallout thread, but got my GTX 970 in and experienced my first 4k/60hz gaming last night. My god its beautiful. On Fallout 4 I was able to get 4k/60hz with Ultra/maxed everything except medium God Rays and 8x AF, and that was with only about 10 mins of quick tweaking. Was able to get average of 35-39 FPS in most cases, never saw lower than 33fps, and got up to 60fps in some areas. So freaking clean though.
12-18-2015, 02:02 AM | #3769 | |
Member#: 56232
RMIC
Vehicle:89 325I i don't know |
12-19-2015, 03:49 PM | #3770 |
Member#: 66480
NWIC
Vehicle:2001 Wrx wagon |
putting my old setup for sale. i5-2500k, with Gigabyte GA-Z69AP-D3 mobo, 16gb of G-skill Ripsaw X Ram, and an mSATA 840 evo SSD. Looking for 300$ shipped, OBO Can send pictures at request.
12-19-2015, 04:00 PM | #3771 |
Member#: 247590
TXIC
Vehicle:2020 Corrolla Hatch |
Looking to buy some new headphones. I'm looking at getting the ASTRO A30 or Astro A40. Thoughts?
12-19-2015, 04:53 PM | #3772 |
Member#: 36838
12-19-2015, 05:34 PM | #3773 |
Member#: 244749
Well, with the H100i GTX not fitting the 250D, and likely not fitting the Ncase M1, I sent the H100i GTX to a buddy of mine, and he paid for a new H75 and sent it to me. The H75 is cooling a tad better than my H100 was (but I was using the SP120 Quiet fans), so I'm pretty happy.
12-20-2015, 06:02 PM | #3774 |
Member#: 145105
Vehicle:2015 Honda Accord |
Just curious to see if anyone has some suggestions/ideas...
Built my new setup around Thanksgiving... (i7 4790k (not OC'd), 16GB Corsair RAM, SanDisk 960GB SSD (OS)/Samsung 840 EVO 120GB SSD) Last edited by 96accord; 04-23-2016 at 02:59 PM. |
12-20-2015, 08:43 PM | #3775 |
Member#: 203905
