Welcome to the North American Subaru Impreza Owners Club Wednesday June 3, 2020
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Old 06-28-2019, 11:38 AM   #7826
JIB
Member Sales Rating: (1)
Member#: 135051
2006 WRX Waggy
Originally Posted by Clark Turner View Post
I would recommend NGK2309 plugs for this setup. A 3 port is a good idea. By now your stock boost control lines are probably worn and need replacement anyways and with a 3 port, the lines will be new. When you are ready just order the custom protune map on my website. Or let me know if you need the parts and I can send you an invoice for the plugs, 3 port and tune.
C
Thank You Thank You for the advice and recommendation!! I will be using a GS 3 Port EBCS on this setup for sure. Youíre absolutely right. May as well upgrade...itís all 13 year old components to say the least. I do already have the boost controller in hand but will need an invoice for the plugs and tune if you donít mind sir. I know youíre busy...no rush at all.
JIB is offline   Reply With Quote
Old 06-28-2019, 11:43 AM   #7827
JIB
Member#: 135051
2006 WRX Waggy
Hey Clark...just realized I forgot to tell you I am located in 70591 Southwest Louisiana...and will be using 93 Octane Fuel. (-:
Old 07-15-2019, 12:01 PM   #7828
Clark Turner
Vendor Sales Rating: (68)
Member#: 178047
02 WRX STI Spec C
All maps sent out.
__________________
Clark Turner Tuning
480-695-2898
Send TXT message for faster response.
[B]PLEASE "LIKE" "Clark Turner Tuning" On FACEBOOK for dyno charts and daily updates[/B]
Clark Turner is offline   Reply With Quote
Old 07-16-2019, 12:59 PM   #7829
Clark Turner
Member#: 178047
02 WRX STI Spec C
All maps have been sent out
C
__________________
Clark Turner Tuning
480-695-2898
Old 07-22-2019, 11:20 AM   #7830
Clark Turner
Member#: 178047
02 WRX STI Spec C
All maps sent out
C
__________________
Clark Turner Tuning
480-695-2898
Old 08-02-2019, 02:03 PM   #7831
Clark Turner
Member#: 178047
02 WRX STI Spec C
__________________
Clark Turner Tuning
480-695-2898
Old 08-14-2019, 11:30 AM   #7832
Clark Turner
Member#: 178047
02 WRX STI Spec C
All maps sent out
__________________
Clark Turner Tuning
480-695-2898
Old 08-19-2019, 01:43 PM   #7833
Clark Turner
Member#: 178047
02 WRX STI Spec C
__________________
Clark Turner Tuning
480-695-2898
Old 08-22-2019, 11:39 AM   #7834
Clark Turner
Member#: 178047
02 WRX STI Spec C
__________________
Clark Turner Tuning
480-695-2898
Old 08-23-2019, 11:57 AM   #7835
ej22twagon
Member#: 320805
Just ordered a customer tune for my 03 wrx! You did great on my 1995 impreza wagon with 07 sti swap. Didn't even think of going anywhere else with my new car! I am running the cobb stage 3 map for now so no rush. Thanks for your work!
ej22twagon is offline   Reply With Quote
Old 09-01-2019, 11:13 AM   #7836
Clark Turner
Member#: 178047
02 WRX STI Spec C
All maps sent out
C
__________________
Clark Turner Tuning
480-695-2898
Old 09-03-2019, 10:40 AM   #7837
Clark Turner
Member#: 178047
02 WRX STI Spec C
All maps sent out
__________________
Clark Turner Tuning
480-695-2898
Old 09-05-2019, 12:47 PM   #7838
Clark Turner
Member#: 178047
02 WRX STI Spec C
C
__________________
Clark Turner Tuning
480-695-2898
Old 09-09-2019, 04:00 PM   #7839
Clark Turner
Member#: 178047
02 WRX STI Spec C
All maps sent out
__________________
Clark Turner Tuning
480-695-2898
Old 09-10-2019, 12:36 PM   #7840
Clark Turner
Member#: 178047
02 WRX STI Spec C
All maps sent out
__________________
Clark Turner Tuning
480-695-2898
Old 09-13-2019, 12:53 PM   #7841
Clark Turner
Member#: 178047
02 WRX STI Spec C
All maps sent out
C
__________________
Clark Turner Tuning
480-695-2898
Old 09-16-2019, 12:48 PM   #7842
Clark Turner
Member#: 178047
02 WRX STI Spec C
All maps sent out
C
__________________
Clark Turner Tuning
480-695-2898
Old 10-10-2019, 02:36 PM   #7843
Clark Turner
Member#: 178047
02 WRX STI Spec C
All maps sent out
c
__________________
Clark Turner Tuning
480-695-2898
Old 10-16-2019, 12:25 PM   #7844
Clark Turner
Member#: 178047
02 WRX STI Spec C
all maps sent out
__________________
Clark Turner Tuning
480-695-2898
Old 10-17-2019, 08:03 PM   #7845
Clark Turner
Member#: 178047
02 WRX STI Spec C
__________________
Clark Turner Tuning
480-695-2898
Old 10-18-2019, 11:04 AM   #7846
Clark Turner
Member#: 178047
02 WRX STI Spec C
All maps sent out
__________________
Clark Turner Tuning
480-695-2898
Old 10-19-2019, 09:08 PM   #7847
Koulbreeze
Member#: 499465
2011 STI
WR Blue
Default Need direction...
Hi Clark, been going over your thread and was looking to do a build on my 11 STI. Well must do it now because it spun a bearing and the shop put wiseco .020 over and eagle rods in for me. Now i've always read that you should contact a tuner about build specs before buying parts. So this is it and you are he. The car when I bought it had a cobb v2 AP, cobb cold intake and I assume cobb exhaust. The stock turbo has cracked so it needs to be replaced. I bought the Tomioka Racing Top Feed Fuel Rail Kit because its parallel and that's all so far. Good fuel is hard to find in my area but at least it's ethanol free. I'm looking for around 500hp
I was looking at
AMS Front Mount Intercooler Kit
Blouch Dominator 3.5XT-R
Torque Solution Top Feed TGV Deletes
Radium Engineering Fuel Hanger w/wal 400lph
What injectors do you think I should get and if a fuel surge tanks recommended.
Any other recommended parts?
What your fuel map tune will cost?
Should I or do I need to get the AP v3 for your maps?
Or should I just buy whatever I want and give you the final specs for the tune?
Koulbreeze is offline   Reply With Quote
Old 10-20-2019, 08:29 PM   #7848
Clark Turner
Member#: 178047
02 WRX STI Spec C
I was looking at
You will need a V3 accessport for this setup. The v2 is no longer supported. I kept old v2 maps so I can sell you one, but I highly recommend you get the v3. Otherwise, you cant run flex fuel or any of the new CCF features. I can bundle one with the protune. Cobb/ID1300x would be a good choice, or FIC1200. I stock both. Just email me if you need the parts and I can try my best to make a deal on the tune.
C
__________________
Clark Turner Tuning
480-695-2898
Old 10-20-2019, 08:41 PM   #7849
Koulbreeze
Member#: 499465
2011 STI
WR Blue
Default AP v2
The AP v2 can't be updated because I don't have an older OS than windows10 so its somewhat useless. I can't get E85 and the closest 93oct is 70 miles away from my house. I was looking at those Cobb 1300x's and just need to make a finale decision on the turbo but the fuel rails are on the way. I OTR drive and will be on the road for a couple of weeks and I'll send that email a week before I return so it can be here when I get home.
Thanks Clark
Old 10-21-2019, 10:29 AM   #7850
Clark Turner
Member#: 178047
02 WRX STI Spec C
Thanks Clark
Sounds like you need a V3. Just drop me an email or a text and I can get it worked up for you man. Clark at Clark Turner Tuning com or 480 695 2898
C
__________________
Clark Turner Tuning
480-695-2898
vf39, Clark Turner map...still need more Mark11 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 40 09-01-2009 10:29 PM
clark Turner mizer map vs OTS Cobb Leggy_09 AccessPort 6 08-22-2009 12:26 AM
Clark Turner mizer map vs OTS Cobb Leggy_09 AccessPort 1 08-18-2009 10:23 PM
No Cobb Vf39 - Protune Map Release? Need BB Engine Management & Tuning 14 11-08-2005 12:39 PM
Cobb PROTUNER Release? aspenwhitewrx Engine Management & Tuning 4 03-15-2005 04:19 PM
