11-12-2019, 08:55 AM | #4301 | |
Member#: 34935
Vehicle:Dad- Core OG |
11-12-2019, 09:09 AM | #4302 |
Member#: 34935
The 5% power increase is also more than noticeable. It's just plain crazy that they can do that.
11-12-2019, 09:22 AM | #4303 | ||
Member#: 92634
RMIC
11-12-2019, 09:23 AM | #4304 | |
Member#: 92634
RMIC
(Jard already knows this, but with Tesla's setup regen is all with lifting off the throttle. Brake pedal application means actual disc engagement--no blending with light pedal application, just blending in the sense that regen from lifting is still there.) |
11-13-2019, 12:27 AM | #4305 | |
Member#: 7887
Vehicle:2023 Tangerine 2023 3 Cylinder |
Yea, the voodoo blue is ghastly on the FJ Cruiser but I love it on the 4Runner. Weird. I have seen a couple heritage blue FJs here in Japan. That could be the perfect color. |
11-13-2019, 03:35 PM | #4306 |
Member#: 92634
RMIC
New Rivian video. Most of this doesn’t look CGI to me, tank turns possibly excepted. Two screenshots from it of note: Note the two front facing Lidar… A look at the underside. I don’t see a steering mechanism so this is presumably the rear. CNCed control arms show that they’re still a ways from production-intent, but those control arms look nice and beefy with good droop travel. Air bags at all four corners. And note the one motor per wheel layout: the way I parse this image, the motors are oriented with their output shafts near the midline, the power flow going through the gear reduction and flipping 180 degrees to those half shafts then headed out to the hubs. |
11-13-2019, 03:47 PM | #4307 |
Member#: 273629
It's way over budget for what I can afford, but... I may have to, make up for it by not replacing the Genesis until 2022 or so, lol.
11-13-2019, 03:48 PM | #4308 |
Papi Chulo
Moderator Member#: 53794
RMIC
Vehicle:... 2017 BMW M2 2017 F-150 |
I want one. Not a fan of the front end but god dammit, this looks awesome. Sign me up.
11-13-2019, 07:49 PM | #4309 |
Member#: 7887
11-13-2019, 08:05 PM | #4310 |
Member#: 92634
RMIC
70 series are the new, er, old hotness.
:drool: The Rivians are really looking quite good thus far. 2021 or so will be a good time to be in the market! |
11-14-2019, 09:47 AM | #4311 |
Member#: 149617
RMIC
Isn't Toyota still producing a limited number of brand new 70 series? Definitely cool, but probably couldn't sell enough here to justify certifying it.
11-14-2019, 12:03 PM | #4312 | |
Member#: 52314
South East
Vehicle:... 02 and 04 WRXs! 2020 G70 3.3T RWD |
11-14-2019, 12:10 PM | #4313 | |
Member#: 92634
RMIC
Sorta. No portal gearboxes at the hubs so the halfshaft angle and A arm clearance will just be normal. |
11-14-2019, 12:17 PM | #4314 |
Member#: 52314
South East
But geared hubs with straight cut gears are awesome!
11-14-2019, 12:47 PM | #4315 |
Member#: 124113
NESIC
Vehicle:Pura vida! Yellow V standing by |
I could have sworn we were still getting those here in Costa Rica but I don't see anything listed online. Just the 4dr Hardtop Land Cruiser. Starting at $67k.
11-14-2019, 04:29 PM | #4316 |
Member#: 92634
RMIC
So the Rivian R1S really does look great from a technological standpoint. I even like how it looks. And I am the target buyer 100%... but I don't see myself pulling that particular trigger, because math. The R1S will start at $72,500 + destination + TTL, for the 105 kWh version. For my skiing uses I'd definitely want the 130 kWh version, but could pass on the 180 kWh monster. Let's call the 130 kWh version $85,000 + the above fees. The CO and Fed tax credits in 2020 or more likely 2021 would probably cover sales/use tax, so let's work with an even $85k here. How much your $100K car will depreciate over time gives some decent blanket rule figures on depreciation: 25% in first year, 9% in second, 7.9% in third, 8% in fourth. I don't know why it jumped in this year--I didn't come up with this. Let's assume that I'll keep it for four years, to be generous to me. Anyway, back to the numbers: at the end of 4 years projected residual for a generic gas powered $100k vehicle would be 49.9%, and I have no reason to believe that EVs will depreciate at a lesser rate. So $85,000 * 50.1% / 48 months == $887/mo in depreciation. (At 36 months it'd be $994/mo, $1,211/mo at 24 months.) That's actually a bit less at 48 months than I'd guessed as a gut reaction from the first two years. The point still stands that that's a fair chunk of change for something capable, quick, and electrified as opposed to the capable, not quick, dino juice powered default option. But what about gas/energy costs? Let's say I drove 10,000 miles per year in the 15 MPG Land Cruiser at $2.75/gallon, ignoring maintenance and oil changes. That'd be $1,833 in gasoline. Rivian is claiming 310 miles of range for their 130 kWh variant, and that works out to be 436 Wh/mile. At 12.5 cents/kWh as a year round average and 90% charger efficiency on the car that's $606 paid to my electricity utility, so over the course of a year I'd save $102.25 per month. (Then again the expensive new car would likely be close to that much more per month to insure...) Cliffs Notes: Expensive vehicles are expensive due to their depreciation. The marginal savings in running such an electric beast do not offset this. |
11-14-2019, 04:53 PM | #4317 |
Member#: 273629
You seem to look at car purchases largely based on needs then the economy of it though.
It's no surprise that cars depreciate like rocks. I think my Genesis is at around $600.00/mo last I checked and that's a $55k car I paid $42k for. But there's more to the equation than just dollars and cents. For the electric vehicle, you also have to consider what your motivation is, if it's squarely to save money, then a used leaf or Bolt of something is obviously the better choice, but there's tons of other potential factors. Environmental, performance, preferences, desires, interest in tech innovation etc. For me, the draw of the Rivian is that it's well designed, seem like the thoroughly thought out car with an electric vehicle tech (4 motor, large battery) I like, not to mention 3 second 0-60 in a freaking truck with 700+ hp. The giggle factor there is worth at least $200.00/mo EDIT: Also I'd get to enjoy a stupid fast car without participating quite as heavily in the continued destruction of our climate. Last edited by TheViking85; 11-14-2019 at 05:00 PM. |
11-14-2019, 04:54 PM | #4318 |
Papi Chulo
RMIC
$85k for a vehicle that I'd be surprised you keep and take it in the shorts for depreciation. Sounds like a smart financial decision.
Btw: Tahoe's and trucks have a pretty damn high resale value. You could buy one towards end of year with killer discounts and be well ahead of the depreciation curve. The Rivian is pretty ****ing sweet and I want one but if you're trying to have this purchase make financial sense instead of simply just wanting it, you're kinda being silly. |
11-14-2019, 04:57 PM | #4319 |
Member#: 92634
RMIC
I'm with you that the intangible factors are worth something. They're roughly worth what my Model 3 is costing me--I'm ok with it and the wife and I certainly always choose to drive it when we don't need to cart around kid #3.
But my post was an exercise to quantify how much those intangibles must be worth it to me in order to justify a Rivian... and I don't think lack of using gas, performance, interest in tech for tech's sake etc. add up to probably $750/mo in additional depreciation beyond that of my Land Cruiser. |
11-14-2019, 05:17 PM | #4320 | |
Papi Chulo
RMIC
That said, I flip vehicles every 3 to 4 years max as I’ll rack up 100k in that time and knowing I’ll likely take a 50% hit if not more is just painful and doesn’t make it financially beneficial. My other concern which can’t be accounted for is the fact that technology will likely continue to accelerate at a faster pace each year making whatever I bought obsolete and as things scale, likely drive down costs. Lastly, I can just see myself getting tickets out the ass doing tank spins because I can, which would also mean I’m buying tires often. |
11-14-2019, 05:19 PM | #4321 |
Member#: 92634
RMIC
Tank spins would be awfully fun. Perhaps I should reserve judgment until I take a 3.0 second 0-60 pull and do a tank spin.
11-14-2019, 05:30 PM | #4322 | |
Papi Chulo
RMIC
1: Perform tank spin from dead stop and exit tank spin with a sprint to 60mph 2: Sprint 0-60 and perform tank spin at 60mph. I’ve decided I should not own a Rivian for reasons above |
11-14-2019, 06:22 PM | #4323 |
Member#: 64196
RMIC
Vehicle:2010 Family Sedan |
That Rivian. Yes.
Perhaps a smaller, cheaper version like old Taco-sized, plz? |
11-14-2019, 06:48 PM | #4324 |
Papi Chulo
RMIC
11-14-2019, 08:55 PM | #4325 |
Member#: 90804
SCIC
Vehicle:2021 Ascent 2012 Accord |
2001 Taco size please....
