10-18-2004, 09:13 AM | #1 |
Member#: 23717
Vehicle:2005 Big red |
I haven't posted a stupid ? in a while
So here it is:
Why is a lot of boost at low RPM bad? I can see if you are surging the compressor that high boost a low RPM is bad. Not that it is possible but why is running say 20psi at 2000rpm or lowwer bad. I know you will run into torque limits on the rods. Other than those two things(surge and torque limits) what is so wrong in getting high boost as low in the rpm range as possible. What caused me to ask is that a subie guru just said that it was bad. I thought that one of the greatest chalenges with a turbo is to get boost as low as you can. I could just be very confused. TMS |
10-18-2004, 11:41 AM | #2 |
Citizen Mick
Member#: 27646
Vehicle:2003 Sleeved 2.5 Oil Dry Sump Goodness |
IMHO boost at low RPM is not bad, actually it's good if you can get it.
Typically the above statement is made in respect to the part throttle full boost issue. this is where the car stays in closed loop fueling mode and you are running 14.7:1 AFR at lower rpms and full boost. Which as you know is very bad. IMO if you have correct fueling and timing then having boost at lower rpms is a good thing. I would like to see other comments on this issue as their maybe aspects of lower rpm boost that I have not thought about. |
10-18-2004, 11:42 AM | #3 | |
Member#: 23717
TMS |
10-18-2004, 01:35 PM | #4 | |
Member#: 7922
Vehicle:04 CTS-V b/b/b 99 GMC Highrider |
10-18-2004, 12:29 PM | #5 |
Member#: 40501
Vehicle:2005 Decathalon 21sp One WheelSeanPower |
The Subaru WRC car hits something ridiculous like 3.5bar of boost at less than 2500 rpm. Lots of diesels max out boost (which might well be 4 or 5bar+) below 2000rpm (hell, 1200 in the case of Semis) and fall off from there.
I think what the Scooby Guru must have meant is that the stock EJ205 is likely to have breathing issues down there, leading to det, pre-ignition or something else ranging from mildly to massively catastrophic. The EJ205 also has cute, cast, pencil-thin rods that will happily snap if cylinder pressures are too extreme. If you got 3.5bar of boost at 2500rpm in an EJ205, you would no longer have moving pistons. You would have a box of snapped aluminum. Now, if it was a specific situation, it's very possible that the poster was referring to surge at a very high PR but low flow situation, or the added det risk caused by running way, way out of the efficiency range of a given turbo. But unless the poster you refer to elaborates, we're just guessing. If you have sufficient force on the turbine and a sufficiently efficient compressor, combined with a strong engine, I don't think low boost would ever be bad. -Sean |
10-18-2004, 01:44 PM | #6 |
Member#: 56468
Vehicle:04 Improved STI Dirty White |
It's not bad as long as nothing breaks (rings, rods, gaskets). Might make for a pretty touchy throttle if it's real low. I saw a old Cobra once that was basically undrivable on the road because the car lurched forward if you touched the throttle.
That WRC article was amazing, the car must snap your head head back. |
10-18-2004, 01:49 PM | #7 |
Member#: 40501
The really funny thing about the WRC cars for Subie and Peugeot this year is that, while restrictor-plate limited to 300hp, both somehow made something like 450lb/ft of torque at 4K-4.5K rpm. Do the math - that's a good bit more than 300hp. Hmm...
10-18-2004, 02:42 PM | #8 | |
Member#: 36528
Vehicle:2002 Impreza Wrx Silver |
peace |
10-18-2004, 03:16 PM | #9 |
Member#: 32792
Vehicle:2003 GGA MBP 12.9 / 105+ |
well, along those lines... it is essentially the same question as to why it is "bad" to "lug" the engine in a too-tall gear at too low of an RPM.
and the answer to that question has been, in my experience, that it puts a LOT of cylinder pressure in the chamber. now, why does that occur? i think it has to do with the speed of the receeding piston during the power stroke. if the cylinder pressure peaks quickly and the piston does not have time to absorb that pressure and convert it to downward movement, then very little of that pressure will be used to perform actual work. instead it will be dissipated in the piston/rods/bearings/headgasket/rings, etc. in other words, it's a matter of matching the rate of chamber volume expansion due to downward piston movement to the rate of the combustion event. jm2c ken |
10-18-2004, 03:48 PM | #10 | |
Member#: 23717
My train of thought was like this: At low RPM the pressure and heat generated have more time to do damage. It takes time for the heat to get into the metal parts so at lowwer RPM you have more time for the heat to get into those parts. Also the pressure or force has more time to do damage at lowwer rpm. So it is not really BAD. You just have limits on the strength of the components. That is why it is bad. Same thing with RPM limits on rods they will only take so much and then boom. Am I way off here? TMS |
10-18-2004, 08:17 PM | #11 |
Member#: 37731
i get a lot of knock at low rpm in high gear. in 6th gear, at highway speeds, the turbo is ready to go at anytime...i can get 10psi by 2500...then i see the CEL flash.
...so ive just learned to not floor it <3k in 6th. haha. ive taken out a good amount of timing from those load sites, but i figure i might as well just drive around it...since the car doesnt like that apparently. i had the same problem with my stage 2 setup, but i tuned it out. i wish my laptop harddrive didnt crap out, so i can see how much timing i actually pulled out. ah well. |
Similar Threads | ||||
Vicky: clsmooth's '00 BRP RS Coupe | clsmooth | Vancouver Impreza Club Forum -- VIC | 311 | 09-30-2022 05:30 PM |
My Pants Just Shrunk - Haven't Been This Amped In A While | OriginalSin | Off-Topic | 35 | 05-13-2008 10:25 AM |
haven't posted up pics in a while | benya29 | Member's Car Gallery | 2 | 02-24-2008 02:03 PM |
I haven't posted anything WTLW in a minute so here; Ballad of the Beard | scaryfastskier | Off-Topic | 5 | 09-25-2007 02:03 PM |
Haven't made a post like this in a while | JewPac42 | Off-Topic | 13 | 09-26-2003 05:29 AM |
