05-07-2021, 11:35 AM | #26 | |
Member#: 33782
MAIC
Vehicle:96 3MI Racing search FIRST, then PM!!! |
BTW, if mounted it the heads, the coolant still hasn't cooled the other have of the cylinder bore yet.
05-07-2021, 01:00 PM | #27 |
Member#: 108051
AKIC
Vehicle:2005 WRX STi WRB |
I believe it will be a more accurate reading. I'd drill and tap it into the banjo bolt by the turbo on the cylinder head. Where the higher temperature is.
05-10-2021, 01:36 PM | #28 | |
Member#: 33782
MAIC
Do you suspect pore flow to certain pockets of the head? If so, I'd look at Dom's cylinder 4 cooling video where he actually tested and logged these temps. |
05-13-2021, 03:43 PM | #29 | |
Member#: 108051
AKIC
Well I have and obviously he tested the higher temps in the area. So the sensor would be best in that location obviously!?. |
05-25-2021, 03:55 AM | #30 |
Member#: 524499
Hi....the admission for my 4.0 (and different styles) has no water section at the back. The head has a channel at one or the flip side, which permits widespread fit (left/right). However, this permits coolant to be at a "impasse" with no stream, making either a "hot pocket" or a region to trap "gas bubbles".
So I keep thinking about whether this plan over long haul permits additional warmth at the back, and adds to the HG issues around here. I would assume you could penetrate and string a few little line areolas and join tubing to course this over to the coolant container. The valley dish gasket as of now has a huge pattern for each. pcb assembly Last edited by JethTran; 07-23-2021 at 05:07 PM. |
05-25-2021, 08:25 AM | #31 | |
Member#: 508105
NWIC
Vehicle:Link G4X flex tuned 02' EJ205 20G 6MT wagon |
My brain hurt reading this |
