10-12-2009, 09:21 AM | #1276 | |
Member#: 146287
BAIC
Vehicle:2011 Impreza WRX 5D Satin White Pearl |
I have a '09 2.5i, and I know what Catback I want to get, but I am having a hard time finding a header. I want to get a UEL header so I can get the rumble out of my car. Anyone have any suggestions on headers for the 08+ 2.5i?
10-12-2009, 10:20 AM | #1277 |
Member#: 2234
SCIC
Vehicle:2019 Outback 3.6R ISM |
The 'needed' backpressure is a myth.... It has more to do with scavenging than anything else... Especially if you go too big of a diameter of an exhaust pipe...
10-13-2009, 01:03 PM | #1278 | |
Member#: 201277
Vehicle:2008 08 QSM 5MT LGT QSM |
10-14-2009, 05:05 AM | #1279 | |
Member#: 146287
BAIC
10-15-2009, 04:33 PM | #1280 | |
Member#: 223032
Vehicle:2006 Impreza 2.5i CGM |
10-16-2009, 02:49 PM | #1281 | |
Member#: 220861
SCIC
Vehicle:2009 2½i N/A Sedan DMG |
what catback are you looking for and whats uel header and how much do they USUALLY run? i have the same car. err i didn't see if u had sedan or not. My friend was talking about since the sedan exhaust is one pipe splitting into two. I can just go to a shop where he got his flowmaster's for his 71 nova, and the guy there can make it two straight pipes taking off the cat if i wanted too. anyone know if that would cause problems? or sounds pretty good?. Last edited by Subie-Zero; 10-16-2009 at 02:54 PM. |
10-16-2009, 03:19 PM | #1282 |
Member#: 227124
GUys Help me! I m streetracer)))) from Moscow Russia!
i need some Spare parts for impreza. Following spare parts are necessary to me - if it a little be second hand - no problem. Please help our special racing team - next competition will be in the 1 of november... Turbines - IHI - VF 36 and IHI - VF 42, TEIN H G 5 - 114.3 For LE STI. |
10-18-2009, 07:48 AM | #1283 | ||
Member#: 146287
BAIC
Spam? Quote:
I am planning on getting a Turbo XS catback. UEL stands for Un-Equal Length. With our Subarus the exhaust goes to one side (passenger) and with exhaust outlets on either side of the engine the driver's side has more distance to cover so the pipe is longer than the piping coming off the passenger side. This set-up of different lengths creates the Subaru Signature "Boxer Rumble" that you hear on WRX's, STi's and older models. On the other newer models Subaru created an Equal Length design by adding pipping to the passenger side to match the length of the driver's side. With Equal Length the boxer rumble is gone and the whole system makes less overall noise. As for how much they run, it was posted above that you can score an RS UEL for $100-$175 on eBay. |
10-18-2009, 03:28 PM | #1284 |
Member#: 205723
W. Canada
Vehicle:2007 Impreza 2.5i se Newport Blue |
2007 2.5i SE Newport Blue
Injen CAI: 280$ Perrin LWP: 80$ Borla UEL Stromung HLC, Midpipe, axleback H&R Springs Perrin 25mm RSB Rallitek 22mm FSB Perrin Endlinks Sounds like a bat out of hell!! People cant believe its a suby haha, Little loss in the low end but the gains above 3500rpm are well worth. The drone at highway cruising can be a little annoying but easly solved by turning up the jams haha |
10-18-2009, 07:27 PM | #1285 |
Member#: 104722
VIC
Vehicle:2006 2.5i - SOLD Gray |
So I've changed my exhaust (AGAIN), probably the 5th time I've changed it during the past 3 years
06 2.5i - SGM Cosmo SRI w/ K&N filter Mr.Josh LWP stock wrx exhaust manifold/headers (modified) 2.5" Midpipe Vibrant Resonator Borla axelback (it's a bit rusted and old, but I picked it up for uber cheap) |
10-18-2009, 09:52 PM | #1286 |
Member#: 227205
NESIC
Vehicle:2007 Impreza 2.5i CGM |
Question about hi-flow cats
i have a 2007 impreza 2.5i.
Will the Random Tech Dual Hi-flow cat have places for my o2 sensors, like the stromung hi-flow cat listed right about says? Also are there any cats on the stock manifold/header of my car?And if i put the borla headers on will i run into any problems with o2 sensors/ passing emission inspection? here the site i was looking at for the hi-flow cats http://www.boxer4racing.com/exhaust.htm#Exhaust Headers Also which would you guys recommend a stromung cat-back or a borla cat-back? Thanks in advance for the help |
10-21-2009, 08:11 PM | #1287 |
Member#: 205723
W. Canada
is the header still for sale?
10-21-2009, 08:35 PM | #1288 |
Member#: 87778
NESIC
Vehicle:2016 Toyota 4Runner TRD Pro |
When I was non turbo...
Intake: Started off with an Injen short ram intake, was really loud and throaty at WOT, sounded really NA and comparable to a honda. Was a typical 4 cylinder NA sound. Converted it to a Cold air intake by taking my friends cut up cold air off his wrx, cutting it up some more, added a 4 inch SS extension and it fit snug right behind the vent next to the fog light. This thing sounded mean, not as loud as the short ram, but you could hear the engine just sucking in loads of air at WOT. Sold it to someone on RS25, they have a sweet sounding car now. Exhaust: Honestly went through atleast 10 different exhaust setups, from stock headers to borlas, and from stock cat to track pipe. The track pipe made it louder, but not hella louder, it really depended on the muffler. Best rumble was from a custom exhaust fabbed up using a magnaflow muffler, that thing shook the ground. My favorite was the HKS superdragger, a rare bird, had this 3 inch monster fabbed up and my car sounded like a rally car, but NA. The Stromung was beast also. Power The track pipe plus an aftermarket catback gave a ton of high end power. I was almost convinced my RS was a pure breed since I was able to light up all 4 from a dig and I was putting stock WRX's to shame???? With a highflowing muffler, low end was a bit, ehhh. I could throw a stock muffler back on an regain the low end but loose that insane top end. I miss how fun it was to drive NA, it was the ideal daily driver. I couldn't even imagine 200 or more whp from a 2.5 NA. My swap is doing me good though |
10-29-2009, 02:18 AM | #1289 |
Member#: 220394
South East
Vehicle:93 Shinku no akumu shinku |
93 L
ebay uel (160) custom 2.5 to 2.25 pipe 05 sti axel back no power difference when i drive cars quiet at low end but when i get mid to high range, heard it sounds like a tommy gun...tryin to solve that problem now |
11-03-2009, 06:20 PM | #1290 |
Member#: 228887
Vehicle:2010 Impreza 2.5ix2 Camellia red and Black |
Maybe i missed it but highly doubt it. I have a 2010 Impreza 2.5I and looking for a CAI and a cat back and a short shifter. not looking for performance to race just improve sound and MPG
11-08-2009, 07:15 AM | #1291 | |
Member#: 146287
BAIC
You can get a new catback from anywhere between $375-$800 and a used one for a little less. You can get a new Short Shifter from anywhere between $70-$140 and a used one for a little less. I don't know much about CAI's As far as I have heard there isn't one out yet that won't throw a CEL. But I could be wrong. If you just want to improve fuel economy, have you thought about changing your oil to full synthetic? |
11-08-2009, 05:31 PM | #1292 |
Member#: 136919
W. Canada
Vehicle:2005 Legacy GT Wagon ABP |
Car: 1998 Legacy Wagon
Engine: EJ22E Header: MS3 Single Port UEL Cat: Magnaflow HFC Midpipe: Stock 2" with baby resonator Muffler: Magnaflow universal Polished Stainless Relevant Mods Affecting the Video: Hybrid intake [youtube]http://www.youtube.com/watch?v=UaZufdx_lvM[/youtube] |
11-09-2009, 09:42 PM | #1293 |
Member#: 220861
SCIC
Ok so just to imporve and gain that "Boxer RUmble" I just need to get UEL Headers on my O9 impreza?.
11-09-2009, 09:51 PM | #1294 |
Member#: 220861
SCIC
11-18-2009, 11:45 PM | #1295 | |
Member#: 166091
NESIC
Vehicle:1998 Outback Limited Green |
11-25-2009, 08:27 AM | #1296 |
Member#: 146287
BAIC
Does anyone know if there is a difference between the 06-07 headers and cat pipe and 08+ headers and cat pipe. Are they the same?
12-01-2009, 12:17 PM | #1297 |
Member#: 194775
RMIC
Vehicle:2000 2.5 RS Blue |
I know the question has been asked in this thread, but I haven't seen an answer. Where can you find UEL headers for an 08+ 2.5i? Will the ones on ebay work eventhough they are for other years? or will some modifications have to be made? I'm looking for that boxer rumble but need the UEL for it!! Any ideas?
12-12-2009, 08:59 AM | #1298 |
Member#: 208427
Vehicle:2009 impreza 2.5i silver |
12-18-2009, 01:05 AM | #1299 |
Member#: 232642
AKIC
Vehicle:Cree http://bulletpr CreermVox |
The official CAI/Exhaust thread for N/A scoobies
ok if its all about brand and not how long the intake tube is then how do the following do:
aem cai or srii will be getting the v2 in the future so we will just skip the talk about this k&n injen ebay sri or caipossibly what ill have to get for now due to no cash any im missing? looking for deepest sound and performance |
12-24-2009, 10:43 AM | #1300 |
Member#: 232638
hey i brought a 99 outback limited edition , but it needs a tranny what kind of tranny will bolt up 2 it? its a 2.5 motor
****Official '80s Freestylin' thread****for the old guys!!! | MyRad25rs | Off-Topic | 21 | 12-09-2011 10:39 PM |
The Official "Things I Hate For No Good Reason" Thread. | RaceCarRiot | Off-Topic | 109 | 02-14-2006 10:00 AM |
The Official Pittsburgh's DILLIGAF Racing for Mod Thread | Mancini | Mid Atlantic Impreza Club -- MAIC | 11 | 09-20-2005 10:29 PM |
The official 2005 volleyball thread for NOVA | slim speedy | Mid Atlantic Impreza Club -- MAIC | 57 | 04-12-2005 04:51 PM |
The OFFICIAL no rain/snow for the learning curve thread | Bart | Mid West Subaru Owners Club Forum -- MWSOC | 8 | 03-27-2003 02:22 PM |
