11-04-2020, 10:11 PM | #1 |
Member#: 506715
2006 Impreza Security Alarm Issues
So a while ago my key fob was broken and hasn't worked since. The morning it finally went out for good i had to unlock my door with the key setting off the alarm. I was unable to get the alarm to stop no matter what I tried. I disconnected the security system by unplugging the connector from the module behind the dash. I have some replacement fobs ready to be reprogrammed but as soon as I plug in the connector the alarm goes off. How can I get this to stop so I can program these new remotes?
11-05-2020, 01:01 PM | #2 |
Member#: 144044
South East
Vehicle:2006 STI OBP |
insert the key and turn it to the on position (not start) and back to off three times.
11-06-2020, 10:37 AM | #3 |
Member#: 520053
Have you checked all the grounds on the engine? A bad ground or corroded ground could cause some issues.
11-08-2020, 12:17 AM | #4 |
Member#: 506715
SOLVED.
Turns out for whatever reason my car doesn't (or didn't in my case) show any signs it was in program mode. No sounds or indication lights. I just got frustrated thinking I didn't get it that I just ran through the whole cycle anyways. At the end of it my flasher/blinkers flashed on cluster twice. When I saw that i hit unlock on remote and voilá my new remote was programmed. |
