Old 10-06-2020, 12:03 AM   #2251
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Originally Posted by subydude View Post
Something a lot of people don't consider using bagged ice is how your neighbors will feel in grid having a bunch of water constantly dumped on the ground with tools, helmets, whatever sitting on the ground next to you.
Also, 3 bags of ice is $6ish, which isn't a ton, but it's just another expense and logistic to track.
I'm honestly surprised by the number of people who are worried about inlet temps. As long as you're below like 180ish on E85 and 150ish on pump gas (assuming forged internals) it's fine. Don't worry about it and just keep going. Even above that it's fine for short stints.
Do you remember that I used bagged ice for YEARS in running XP, with never a complaint. I was always aware of the potential issue though, and at regional/ national events I would dump hot water into a bin under the car via a dump valve, then walk it away from grid a ways to dispose of it. It was nice having IAT's in the 90F range on boost. The funny part was in grid when people would notice condensation on my A2W intercooler and it was cold to the touch. I should have had it insulated, but never got around to it. Will do in the next iteration. Also, for full disclosure, I did run a radiator in the loop with a fan on it to pull a lot of the heat out. At some small events I never added any ice. The tune was very important, and very good.
Old 10-06-2020, 09:11 AM   #2252
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
Sparkly
I wasn't pointing fingers at you Sean I was referring to a few people that were local to me that did what I said.
I don't disagree that the air to water route can work very well. I just think it's a lot of added complexity in a system when it's not needed
Old 10-06-2020, 12:33 PM   #2253
T-37
Member#: 175624
0304 WRX WRX
SY WRB
Has anyone here tried the FZ-201? There's a soft 40UTQG and a medium 100UTQG. They're significantly cheaper than 200TW options. Size options seem limited 265 is the widest for the Soft and 285 for the medium. I'm currently running 255 RE71s though.. It seems like these could be faster than the 200TW street tires, based off a couple limited reviews. They're not going to beat Hoosiers, but they could be a cheap fast tire.
Old 11-25-2020, 11:30 AM   #2254
smoky
Member#: 221439
2004 STI
For those running surge tank what is your setup looking like? What brand and size surge tank do you use?
I'd like to be able to run low fuel level and easily empty my fuel tank to swap fuel type between Ethanol and Pump (car is still use in street). I was thinking installing 2 lift pump (DW makes nice one) on each side of the saddle tank and using the current Walbro 525 in the surge tank. Radium makes a nice single walbro plug and play one.
smoky is offline   Reply With Quote
Old 11-25-2020, 01:02 PM   #2255
Aczwild
Member#: 71721
98 RSTi, 00 RS
13 Sierra
Personally I went with Radium's triple surge tank with a single pump installed for a few reasons. Increased capacity over the single hanger and the fact I can have at least 1 unconnected pump sitting in the surge tank incase the first craps out during an event, track weekend or when I'm driving it on the street and when I spend $$ on modifying my racecar I like to "future proof" it as well for when and if I need to run more pumps in the surge. I'm running a DW200 lift pump in a modified STi hanger in a STi tank (this is in my swapped '98 RS) with a Radium venturi jet pump kit and then a Walbro F900000274 pump in the surge.
As you can see in the pic below I'm also running a pre-surge tank Radium fuel filter (100 micron) and then I also have a post surge tank, pre engine 10 micron filter in the engine bay. Lines are Goodridge G-line XF 811 6AN braided stainless lines for complete SCCA/NASA compliance and there is no fuel smell whatsoever. Like you mentioned as well this setup made it super easy recently to "completely" drain the main tank and surge to switch to E85 while on the dyno.
Aczwild is offline   Reply With Quote
Old 12-31-2020, 11:09 AM   #2256
smoky
Member#: 221439
2004 STI
Quick question on surge tank. I'm installing one in the trunk near the passager seat (see picture). Does the requirement for a "metal bulkhead" in section 3.3.3.B.27 applied or not?
Picture:
Old 07-01-2021, 10:46 AM   #2257
T-37
Member#: 175624
0304 WRX WRX
SY WRB
I remember some rocket ALS discussion here in the past. This is Robert Thorne's S2000. To be honest, it looks like a complete nightmare in almost every aspect.
Old 07-01-2021, 01:55 PM   #2258
subydude
Member#: 80649
Sparkly
Originally Posted by T-37 View Post
http://www.youtube.com/watch?v=qpJYQ9Fydso
It was, and it almost burned the car down several times. When I was on the rules committee we talked about banning it several times but in the end (IIRC) we left it legal. Robert didn't own it either so had to give it back to the owners.
Having access to a real race shop has it's benefits.
Old 07-01-2021, 02:37 PM   #2259
T-37
Member#: 175624
0304 WRX WRX
SY WRB
Yeah, I remember seeing that Prepared had banned external combustion around that time, but never saw anything about SM. I could see where the effort was worth it for Subaru back in the day since they were falling behind the competitive curve in WRC. But for an autocross car - while hugely impressive - it's absurdly expensive and borderline insane.
Old 07-02-2021, 11:02 AM   #2260
subydude
Member#: 80649
Sparkly
That was really the kicker. It's cool, but turbo tech today kind of negates the need for it. Granted, it makes a 2.2 or 2.0 act like a much bigger engine with basically no downside. After you work out the kinks, build a fuel and air injection system outside of the engine and an inconel chamber that happens to have a lot of intricate parts, have an ECU that can manage that and control it using PID control of turbine wheel speed, package it in the car, and not burn anything down at the same time.
So yeah, cool, but definitely more in the realm of full motorsports.
Old 07-09-2021, 01:09 AM   #2261
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
"absurdly expensive and borderline insane"
Best explanation of this system I've seen yet.
Old 09-09-2021, 10:20 PM   #2262
Suba_Roo
Member#: 5691
2001 2.5 RS
Silverthorn
Some of our old school NASIOC SM peeps are representing pretty well at Nationals today. Tim just needs to find about 3 10ths on the west course to get into the trophies. Pray for rain?
Suba_Roo is offline   Reply With Quote
Old 09-13-2021, 11:34 AM   #2263
smoky
Member#: 221439
2004 STI
Good job to Tim!
Old 09-13-2021, 08:55 PM   #2264
subydude
Member#: 80649
Sparkly
Thanks guys! The data showed the car had a 3rd or 4th place in it, but a catch can failure day 1 and me just not driving it well enough day 2 led to 6th. Still good to get a trophy after 4 years of down time. SM has gotten deep too. 1st in SM was 3rd in pax out of 1,100+ people, and even in 6th I was 94th in pax over all.
Car is back in the shop and I've got some ideas to make it faster now.
Old 09-13-2021, 09:55 PM   #2265
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
NICE job!!!
If you need any help with those ideas let me know. I wish I was back out there, but life is, well, life.
Old 09-13-2021, 10:50 PM   #2266
k-dogg
Member#: 115961
2005 Wide STi Wagon
WR BLUE
Congrats! Nice work!
k-dogg is offline   Reply With Quote
Old 09-13-2021, 11:30 PM   #2267
Suba_Roo
Member#: 5691
2001 2.5 RS
Silverthorn
Are you actually using the hood scoop? My car got a lot more stable at highway speeds after I got rid of the scoop. Damn near free mod.
Old 09-14-2021, 12:12 PM   #2268
subydude
Member#: 80649
Sparkly
No, it's my inner ricer showing through. It's an MRT hoodscoop and I always liked how it looked on the car vs the much smaller OEM one, so I left it. It's blocked off though so it's not pressurizing the engine bay in any way. With the additional hood venting in front now it wouldn't even matter if I made it a vent IMO.
Old 09-14-2021, 10:47 PM   #2269
Suba_Roo
Member#: 5691
2001 2.5 RS
Silverthorn
Do a test with a block off plate instead of the scoop. I'll betcha you have less front end lift.
Old 09-15-2021, 01:33 AM   #2270
Kostamojen
Member#: 2272
2019 Macan 4cyl
1993 Impreza FWD WRX swap
Grats!
Just saw this was bumped, figured it was someone at Nats.
Looking at the results, I'm curious to see how they will class the 2022 Twins for competition...
Old 09-15-2021, 10:03 AM   #2271
subydude
Member#: 80649
Sparkly
Grats!
I'd guess CS to start, then down to DS. Likely a year to figure out it's an STX car, then DSP, and SM.
Old 09-16-2021, 06:07 PM   #2272
Suba_Roo
Member#: 5691
2001 2.5 RS
Silverthorn
I saw that someone ran a Tesla Model 3 in SML.
At local events a good driver in a Model 3 that is well prepared for Street is just destroying everyone. I'm really hoping that Tesla doesn't realize that their cars are really really good at autocross and release some sort of Autocross mode. Basically some combination of all the power you can use in 60 seconds, and motorsports grade traction control with no stability control. It'll instantly ruin Autocross for any ICE car.
How long till EVs and ICEs are in separate classes?
Old 09-17-2021, 10:28 AM   #2273
subydude
Member#: 80649
Sparkly
SCCA is already looking at EV classing. And while the power is great they still have to overcome the weight and suspension stuff. I do think eventually they'll win, but the lady driver in SML in the Model3 is pretty good, yet came 3rd. My car had issues day 1, but day 2 the good driver set fastest time in SML.
I see it becoming something more, but for a while it's nothing to worry about, and even when it is, it'll likely be classed in a way that keeps ICE competitive for a while.
Old 09-17-2021, 02:24 PM   #2274
whozatguy
Member#: 179775
03 WRX/15 FXT
14 BRZ/ 92 SVX
I'm sure this has been part of the discussion, but as aftermarket EV drive systems are becoming more widely available and easily integrated, that would give a whole other wrinkle to the situation. I'd love to plop a motor on all 4 corners of my wrx
whozatguy is offline   Reply With Quote
Old 09-18-2021, 12:57 PM   #2275
subydude
Member#: 80649
Sparkly
SM has had a rule in for EV’s since the Prius came out. They’re legal, but must weigh the max weight in the class. Since they’re so heavy from the factory that’s not a problem, but if you add EV to an ICE car it would need to weigh 3,100 minimum in SM.
Will my trans swap put me automatically in Street Mod? RebelINS Autocross 6 07-22-2013 05:24 PM
I'm still legal for Street Mod right?(list inside) Davenow Motorsports 4 05-24-2003 03:21 AM
street mod tire question Jaxx Motorsports 2 02-20-2003 07:59 PM
Autocross class... Street Mod? Motohead1 South East Region Forum 11 06-26-2001 10:11 AM
Street Mod news Eric Technical Forum Archive 5 05-31-2000 02:33 PM
