10-29-2020, 05:07 PM | #1 |
Member#: 464067
How to align exhaust manifold
Need advice - I have a 2016 Subaru Impreza.
Trying to put back my exhaust manifold - can't seem to align the holes back into the bolts. Been trying to for the past couple hours. See for reference https://imgur.com/a/OH6L119 Any tips or tricks? I managed to fit the left side but the right side doesn't budge, I even tried with a flathead screwdriver and hammer to try to jam it in. Or maybe I should try drilling a bigger hole? Would that mess it up? Any advice is appreciated. Thanks! |
10-30-2020, 08:01 AM | #2 |
Member#: 283429
South East
Vehicle:2016 Fuji Sunfire 03 Silver |
They can be a pain - worse than EJ manifolds. I have had to use a prybay 24" - 48" but I am guessing you are on the ground and not a lift so that won't work for you. I wouldn't drill out the holes.
Maybe put a box end wrench on the shaft of a hefty screwdriver will get you the extra leverage you need. BTW: Looks like you are re-using the old gaskets. Do yourself a favor - put new gaskets on or you will be doing this again to fix an exhaust leak and possible P0171 |
10-30-2020, 08:28 AM | #3 |
Member#: 481754
Vehicle:2017 STi Base Black |
I've use something similar to this on SBC but they only have 2 studs per cylinder, so not sure how good it works on 3. I would imagine it would help just not sure as effective. It goes between the studs and you use it like a turnbuckle
https://www.amazon.com/Performance-T.../dp/B0076EX4S8 |
10-30-2020, 10:27 AM | #4 |
Member#: 21145
NESIC
Vehicle:2002 Enemy of Aku |
Just for clarity, are you saying you can get the left side of the header on but the right side of the header you can't align to install the bolts?
Just want to make sure we are talking about the same thing. As Elbert said, a crowbar is what you need to spread the header open enough to align it up correctly. Even on your back on the ground, you should be able to do this. How is the car supported? - Up on car ramps? - Up on blocks? - Up on jack stands? - Sitting on the ground? Rhino Ramps give a fair amount of clearance underneath. |
10-30-2020, 06:37 PM | #5 |
Member#: 459287
VIC
Vehicle:1998 JDM Impreza STi V4 GF8 White |
Best be careful
10-30-2020, 07:39 PM | #6 |
Member#: 338131
RMIC
Vehicle:2003 wrx wagon black |
Instead of putting one side on and trying the other you might need to try and get both sides on at the same time, probably takes another set of hands. You said you got the left side on and the right doesn't budge, if you do the right side does it look the same on the left as before?
10-30-2020, 08:32 PM | #7 | |
Member#: 283429
South East
I've tried all sorts of tricks. After 200-300 times I've tried everything and putting one end on/pry the other to spread is the easiest, best, and safest way to do it. The main problem is the flange twists some too (you can see that in the photo). |
10-31-2020, 08:15 PM | #8 | |
Member#: 464067
Might be a stupid question, how exactly do I use the pry bar to spread the other side? What's my point of contact on the pry bar? I'm sure I don't put one end of the pry bar on the bolt to spread the header? (as this would probably break the bolt) |
11-01-2020, 01:33 PM | #9 |
Member#: 21145
NESIC
You should buy yourself a set of Rhino Ramps. They are ~ $50 and well worth the investment if you are going to work on your car.
One end of the pry bar goes against the header itself, just under the flange. The other end is some place solid, like the engine block or something. You have to pick what works for you and you get the right amount of leverage as well as being able to push the header onto the bolt. That bar may not be strong enough. You may want something more like a Gooseneck Wrecking bar. That's what I use. |
11-06-2020, 01:19 AM | #10 | |
Member#: 464067
I have another question, the bolt stud to the catalytic broke in half - there's 3 total so I have 2 connected properly. Here's an image for reference, https://imgur.com/a/CDwzTxs. I tried to use an impact to force the flange nut on there but it won't bite, there's not enough thread. So now I have no choice but to replace the stud - do you know if this is like one of the studs to the header where you can just unscrew it or would I have to open up the whole exhaust manifold to replace this stud? Here's a picture of the stud that I would need to replace the one that's broken in half - https://parts.subaru.com/images/uplo...1223280594.png Thanks |
10-30-2020, 08:41 PM | #11 |
Member#: 487057
BAIC
Vehicle:2002 WRX Wagon PSM |
One possible solution is to remove the studs from one side and snug up the other side slightly. Line up the side without the studs, then put the studs back in.
Unfortunately, this opens up the possibility of stripping the holes. If it happens, it's not hard to fix, just a pain. |
10-31-2020, 10:19 AM | #12 | |
Member#: 283429
South East
Most stripped thread "repairs" in aluminum are not very successful unless you have the luxury and expense of a Time-Sert set to perform a proper thread repair (newer modern tech). Just pry it - the manifold will flex, no damaged threads, and you will be on the road in no time. |
