12-15-2017, 11:17 PM | #8726 | |
Member#: 150289
SWIC
Vehicle:2006 SV650, 05 CTSV 1972 Travelall |
12-16-2017, 10:13 AM | #8727 |
Member#: 274028
Vehicle:2018 WRX + EcuTec |
12-16-2017, 11:12 AM | #8728 | |
has never eaten a strawberry
Member#: 60106
Vehicle:I eat pieces of * like you for breakfast |
https://www.amazon.com/Medium-Profil...dp/B001WJ4Y28/ https://www.amazon.com/Leapers-Accus...dp/B001BR4TJY/ Also, not to knock on the whole $10 air rifle scope thing because I've been there and done that (have a couple sitting on a shelf collecting dust ), but here's a better scope recommendation: https://www.amazon.com/Hammers-3-9x4...dp/B0099XIJKC/ |
12-16-2017, 11:26 AM | #8729 |
Member#: 58504
South East
Vehicle:2004 STi Aspen White / Silver |
This was the one I got...
CVLIFE Hunting Rifle Scope 2.5-10x40e Red & Green Illuminated Gun Scopes with 20mm & 11mm Mount https://www.amazon.com/dp/B00PRVLMK4..._hIunAbFS2AG6K The original scope came with a 1-piece mount. I may see if I can swap the new optics to that. |
12-16-2017, 12:13 PM | #8730 |
Member#: 60106
Hmm. Yeah, the mounts I posted aren't going to help you here. I assumed it was a standard style tube, but that's obviously not the case here. You're probably stuck with the mount that came with that scope. When all else fails, there is always threadlocker.
12-16-2017, 12:46 PM | #8731 |
Member#: 60106
Btw, here is the Hammers scope I linked earlier mounted on my Hatsan. It has 4 mount screws which is even better than the 3 screws that you'll find on the Leapers 1-piece. Of course, my rifle also has a "backstop" built into it to prevent the scope from walking back so that probably helps as well.
/Airgunning up the gun thread. |
12-16-2017, 02:41 PM | #8732 | |
Member#: 58504
South East
I used my drill press to make a hole for a vertical stop pin. And then went through my vast collection of random hardware and found a long set screw to thread into the new hole in the base and adjusted it to protrude into the corresponding recess on the barrel. I had indeed stripped the dovetail mount fasteners by over tightening them. So I had to knock those out and put some new fasteners in to clamp up on the dovetail. Got it all back together and thought for sure it would require a sight re-adjustment. I took it out for a few test shots at my most challenging target. Much to my great pleasure, it was right where it had been...no adjustment required. I went 3 for 3 on it and decided to quit while I was ahead. The backstop on you rifle makes more sense...I'd like it better I think. And hey...it's a gun thread, not a firearms thread! |
12-20-2017, 09:40 AM | #8733 |
Member#: 93830
Deal alert: $39.99 PSA lowers, NON-BLEM. Deal expires at noon today.
http://palmettostatearmory.com/psa-a...fire-1728.html Note: they're advertised at "high-shelf" lowers...whatever that is. |
12-20-2017, 09:53 AM | #8734 | |
Member#: 167010
South East
12-20-2017, 10:08 AM | #8735 |
Member#: 93830
12-20-2017, 10:38 AM | #8736 |
Member#: 4103
Vehicle:2016 Mazda6 Red |
I've got both high and low shelf lowers in my collection. Not that I'll ever be able to afford a giggle switch.
12-20-2017, 11:37 AM | #8737 |
Member#: 52314
South East
Vehicle:... 02 and 04 WRXs! 2020 G70 3.3T RWD |
I searched, but surprisingly this isn't in this thread at least.
The Franklin Armory Binary Trigger. I heard of it from a conversation I had with a guy in another unit here, he said he has it in his 300BLK AR. After, a couple of YouTube videos and reviews, I'm kind of interested, tho it is a little expensive for basically a type of fun switch. https://www.franklinarmory.com/produ...i-trigger-pack |
12-20-2017, 11:41 AM | #8738 |
Member#: 140147
That is pretty friggin neat.
12-20-2017, 02:08 PM | #8739 |
Member#: 93830
Obviously another product in that 'gray' area of legality (like Slide Fire). Cool, but I don't know if it's $500 cool.
12-20-2017, 03:04 PM | #8740 |
Member#: 140147
I feel that way about a lot of AR stuff (cool but too much $$$).
12-20-2017, 03:35 PM | #8741 |
Member#: 228961
Vehicle:2016 4Runner TRDP White |
Has anyone installed an APEX AEK in an M&P (2.0 compact) and now have a click sound just before hitting the "trigger wall"? I installed one last weekend and have this click sound. I found 1 place that referenced the same thing and it might be caused by how the trigger bar interacts with the new USB (when looking through the gap between the slide and frame I can see the trigger bar move laterally at the time of the click). The click also sometimes happens right before the trigger reset click (and you can see the same trigger bar movement).
12-20-2017, 07:09 PM | #8742 |
Member#: 52314
South East
12-20-2017, 09:02 PM | #8743 |
Member#: 93830
12-20-2017, 09:27 PM | #8744 |
Member#: 141952
Vehicle:2023 M340i |
spent a few hours pulling parts off my old .40 p-07 that i didnt care for and installed them on a new 9mm suppressor ready p-07.
all cajun gun works parts: short reset kit extended firing pin and spring billet hammer stiffer sear spring softer trigger return spring 13# hammer spring (should set off all primers with the extended firing pin) also stoned the trigger bar and reduced trigger bar tension and put a light coat of slide glide lite on the sear surface, d/a roller and back of the trigger bar. went from 10#8oz/4#2oz and mushy to 6#10oz/3#8oz and fairly crisp. |
12-20-2017, 09:30 PM | #8745 |
Member#: 141952
also, selling a couple of triggers im not using. the ruger 452 was taken out of the package and played with but never installed. i measured it at 3#9oz and its pretty damn crisp, worth more than they sell for. if you arent familiar with them, check out a review. the safety and grip are also 100% usable on an ar-15. the geissele hi speed national match has never been opened.
ruger $100 shipped geissele $225 shipped |
12-20-2017, 09:36 PM | #8746 | |
Member#: 141952
12-20-2017, 09:59 PM | #8747 | |
Member#: 52314
South East
12-20-2017, 10:03 PM | #8748 |
Member#: 141952
12-20-2017, 10:10 PM | #8749 |
Member#: 52314
South East
I get that. That was the reason why any improved trigger was more enticing, you can keep your sight picture the same unlike a bump stock anything.
12-20-2017, 11:57 PM | #8750 |
Member#: 178811
Vehicle:2011 White Corolla Over 400hp |
SD3G is the single worst product in their catalog.
