04-29-2021, 03:46 PM | #1 |
Member Sales Rating: (7)
Member#: 140036
ST Coilovers for 02-07 WRX, 04 STi
SOLD!
ST Suspension ST X Coil-overs (02-07 WRX, 04 STI) p/n: 13245004 $775 CDN or $600 USD These ST coil-overs are the best value, totally reliable, year round use non- damping adjustable coil-overs made by KW suspension. They commonly are sold for ~$950 USD + import fees and shipping to us up here in Canada. These are my take-off low mileage, no leaks, perfect street damping, easily adjustable, 100% functional coil-overs. Not from a daily driven car. The front cartridges have only 2000 km's of summer use. The rears were on the car for 6850 km, They strut cartridges were sandblasted and then zinc primed and painted and clearcoated for updated corrosion protection. I have now upgraded to a 3 way KW track suspension that is fully adjustable. From KW/ST Suspension Listing: Need to get low? ST coil-overs feature a continuous thread construction for height adjustment from moderate to eXtreme! Each coil-over is manufactured by KW Automotive and their expertise and know how ensures maximum quality and fantastic driving dynamics. Lowering with Style: the ST X coil-overs Individual lowering within the TV-tested adjustment range Front and rear axle thread adjustment (when possible) Galvanized coil-over struts with additional coating for optimized corrosion protection Complete solution with adjustable spring plate, race spring system and bumpers with dust protection Powerful twin-tube dampers with high-quality components for maximum longevity Lowering Front Lowering: 1.0" to 2.1" Rear Lowering: 1.0" to 1.8" Once installed, the ST X coil-over can be easily adjusted using a polyamide ring on the galvanized, multiple-sealed strut. Adjustment is different for each car, but typically you can expect between 35 and 65mm of lowering on both the front and rear axles. For lowered cars as standard (such as the BMW E9x 3-series) the ST X coil-over features a range of 30 to 60mm (front axle) and 25-55mm (rear axle). Improved driving dynamics and handling Designed in conjunction with KW Germany, ST X coil-overs deliver a sporty handling by reducing the car's body roll during compression as well as improving agility when driving fast. The high-quality production of each ST X coil-over includes a low-friction and pressure resistant housing alongside a chrome-plated piston rod for maximum longevity. A mono block guide and ST seal package ensures the twin-tube dampers remain free of dirt particles in all weather conditions.
