03-01-2021, 06:22 AM | #26 | |
Member#: 197520
Vehicle:2020 WRX STI Magnetite Gray Metallic |
I have a loop I do if I don't drive all week; starts out nice and slow, gets it up a bit in temperature. Then a 'backwoods' route, where I can legit beat the **** out of it, then a return route, and some stop and go; the stop and go will legit let the oil temperatures rise more than a lot of the 'faster' stuff. I return home after ~25-30 minutes, and everything is nice and warmed up; oil temps 190+, etc etc. If you don't have an oil temperature gauge, you're basically flying blind, but assume 20+ minutes of actual 'driving' to get the oil up to 190+. This isn't a Subaru specific thing, either. All cars, from my wife's Mini Cooper S to my mother's boring Mazda 3, need to get up to temperature; charges the battery, burns off **** in the oil, etc etc. The EJ motor is not special.
03-01-2021, 08:57 AM | #27 | |
Member#: 428511
Vehicle:2016 STI |
I have a 1950 vehicle with that set up. Probably doesn't give the best reading being down in the pan with all that air passing over the pan, but it still comes up to temp as expected. It would still give you a decent reading and no doubt easiest. My sensor just came from the gauge company I used, which was Classic Instruments. Temp gauge, pan bolt, that's basically it. The bolt has a tiny electrical connection where you just put a ring terminal on it that goes to the gauge and the gauge needs 12v, done. Probably the most annoying part is having to take off the wire for an oil change because I don't like twisting up the wire again and again. Otherwise it's been working now for over 15 years trouble free. |
03-01-2021, 09:02 PM | #28 | |
Member#: 212389
Vehicle:2009 WRX 5-door DGM |
03-01-2021, 09:40 PM | #29 | |
Member#: 508105
NWIC
Vehicle:Link G4X flex tuned 02' EJ205 20G 6MT wagon |
Perrin makes what you are looking for |
03-03-2021, 12:02 AM | #30 | |
Member#: 519868
Vehicle:2010 Impreza WRX Satin White Pearl |
I had a short drive today that was just barely 20 mins. Late at night so not much traffic but still lots of stop and go. Was getting on her a bit to warm things up. Not sure if that even helps vs driving like a grandma. I guess as long as some longer drives are thrown in the mix throughout the week it should be fine? |
03-06-2021, 09:33 AM | #31 |
Member#: 212389
In case someone missed this thread's bottom line - the consensus is unequivocally YES, it is a bad idea to block off my hood scoop in cold weather. And presumably any weather.
Instead, I should avoid short trips, which don't allow the engine oil to get hot enough to get rid of the water in the blowby. Sounds like the AOS didn't so much cause my issue as contributed to it. I've already extended my commute, and ordered a block heater, sandwich plate, oil temp and oil pressure gauges. Oh, and discovered this gauge faq late in my process - https://forums.nasioc.com/forums/sho....php?t=1193843 |
