01-02-2020, 12:51 PM | #26 |
Member#: 33782
Vehicle:96 3MI Racing search FIRST, then PM!!! |
For repairs, I'm currently running a 'filled' head. Had the journals coated, and then I lapped them back down to size, as the peaks in the aluminum....because I was curious how it would work.
02-17-2021, 05:25 PM | #27 | |
Member#: 260314
NESIC
Vehicle:2007 STI silver gray metallic |
At my worst spot (typical spot on the large diameter journal at the front) where metal particles and the belt/gear forces seem to collide) which is about 30°-45° wide, I measure .0012" out of tolerance. The rest of the circumference is barely in tolerance. If they can take a half-thousandth to one-thousandth off both faces, then it should clean up nicely. I'm going to present this info to IAG and see what they say. |
03-01-2021, 11:39 PM | #28 |
Member#: 515308
5 valve Yz450f heads do the same thing bad, the cam will sink and the journal will mushroom out into the bucket area until the valve will not shut. Expensive to repair, expensive to replace.
Boring cam journals for bearings | Splinter | Built Motor Discussion | 36 | 10-01-2012 05:38 PM |
cam journals? | Ds baruuuuu | Built Motor Discussion | 7 | 09-12-2010 11:00 PM |
closed | subydude02 | Engine/Power/Exhaust | 41 | 08-11-2010 08:29 AM |
Cam Journals | Victor1620 | Built Motor Discussion | 0 | 09-17-2009 05:56 PM |
bolts that hold cam journal caps on, ej205 | erice1984 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 07-12-2005 01:13 PM |
