Old 01-02-2020, 12:51 PM   #26
Homemade WRX
Member#: 33782
96 3MI Racing
search FIRST, then PM!!!
Originally Posted by Techninety9 View Post
So like said in the thread above subarus don't have cam bearings. The aluminum surface is what the cams ride on. That being said, how long have you guys gotten out of your welded and shaved journals?
For repairs, I'm currently running a 'filled' head. Had the journals coated, and then I lapped them back down to size, as the peaks in the aluminum....because I was curious how it would work.
Old 02-17-2021, 05:25 PM   #27
Scargod
Member#: 260314
2007 STI
silver gray metallic
How has this worked out? I may send a set of heads to IAG, as they say they can fix them by honing if they are not too bad.
At my worst spot (typical spot on the large diameter journal at the front) where metal particles and the belt/gear forces seem to collide) which is about 30°-45° wide, I measure .0012" out of tolerance. The rest of the circumference is barely in tolerance. If they can take a half-thousandth to one-thousandth off both faces, then it should clean up nicely.
I'm going to present this info to IAG and see what they say.
Scargod is offline   Reply With Quote
Old 03-01-2021, 11:39 PM   #28
benflynn
Member#: 515308
5 valve Yz450f heads do the same thing bad, the cam will sink and the journal will mushroom out into the bucket area until the valve will not shut. Expensive to repair, expensive to replace.
benflynn is offline   Reply With Quote
Boring cam journals for bearings Splinter Built Motor Discussion 36 10-01-2012 05:38 PM
cam journals? Ds baruuuuu Built Motor Discussion 7 09-12-2010 11:00 PM
closed subydude02 Engine/Power/Exhaust 41 08-11-2010 08:29 AM
Cam Journals Victor1620 Built Motor Discussion 0 09-17-2009 05:56 PM
bolts that hold cam journal caps on, ej205 erice1984 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-12-2005 01:13 PM
