06-14-2011, 01:23 AM | #1 |
Member#: 261239
Vehicle:04 Sti PSM |
Help Car Will Not Start DCCD Blinking
I have a 2004 STI 67000 miles with a turboback exhaust and tune. I try to start up my car after getting off work and it wont start. It will crank but wont start. Also I noticed that the lowest dccd light was flashing green at about 1 second intervals. I checked the fuses hoping for an easy fix but all of them seemed to look fine. Anyone else been in this situation?? I'm thinking its like the fuel pump or spark plugs. Any help would be much appreciated.
06-14-2011, 01:46 AM | #2 |
Member#: 51961
RMIC
Vehicle:2005 STi 2012 WRX |
DCCD light usually lights up when there's a drivetrain problem, like an ABS sensor malfunctioning, etc. It won't light up for a fuel or spark problem.
I can't think of anything that would trigger the DCCD light and prevent the car from starting, but I don't have a ton of experience in that department. My only experience with the DCCD flashing and ABS turning off was when one of my wheels wasn't torqued properly. It didn't affect startup or regular driving though, I just didn't have DCCD or ABS. |
06-14-2011, 03:41 PM | #3 |
Member#: 261239
I got it started today. Heard the fuel pump prime and everything before I turned it on. Then it shut itself off and I'm back to square one again with the flashing light gonna check all my fuses again with a second pair of eyes.
06-14-2011, 04:27 PM | #4 |
Member#: 51684
Sounds like a bad ground somewhere causing this intermittent problem.
06-15-2011, 07:49 PM | #5 |
Member#: 129681
Vehicle:2024 Crosstrek Ltd Ice Silver Metallic |
I apologize if this is not applicable to your STi, but check your ECU main connector in the engine bay, see if the latch is closed.
06-16-2011, 03:08 PM | #6 |
Member#: 193940
Vehicle:2004 WRX STI Black RalliSpec Shortblock |
Check under the car for any wires that might have been chewed up by some animal, cat, dog, rat, raccoon, etc
06-17-2011, 09:40 PM | #7 |
Member#: 261239
Thanks to all those who made suggestions and replys. I swaped the 30amp fuses around in the engine bay and wiggled the spark plug harnesses a little bit and it fired right up drove it for about 20 miles and it seems fine. Gonna do some detailed investigating this weekend when I have time. Thanks again guys.
11-20-2012, 01:02 PM | #8 |
Member#: 178913
RMIC
Vehicle:06 STI WRB |
I apologize about resurrecting this thread. I have the same problem. Green DCCD light blinking. Engine cranks but doesn't fire. Also, the loud walbro fuel pump doesn't prime. Did the OP's fuel pump stop priming? And was there further info after your inspection?
11-22-2012, 03:35 PM | #9 |
Member#: 292532
Vehicle:05 STI PSM |
I had this same issue and the main relay was TOAST. Located behind glove box
02-15-2021, 05:24 PM | #10 |
Member#: 173290
Vehicle:2004 STi PSM |
RISE FROM YOUR GRAVE!
I have the same problem on my 04 STi. The relay seems to be working (I hear it click when I turn the key), and the fuses seem OK (I switched SBF5 and SBF6 with no change). Going to check the grounds; I think I know where they are. What else could it be? Could the relay still be bad even if it clicks? Could it be a bum ECU? (Hope not as it has a speed density tune on it.) |
Similar Threads | ||||
Car will not start! Blown fuse!! help!! | subieracer18 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 5 | 03-17-2006 04:10 PM |
Car will not start! HELP! | GMTarkin | Engine Management & Tuning | 1 | 09-18-2005 10:16 PM |
car will not start need help asap | Sharky NRK | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 23 | 06-04-2005 11:20 PM |
Car will Not start, HELP PLEASE | RandyAndy | Off-Topic | 36 | 03-26-2005 08:50 PM |
Help me my car will not start!!!!! | 4npower | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 4 | 09-01-2003 11:36 AM |
