Welcome to the North American Subaru Impreza Owners Club Friday March 29, 2024
Go Back   NASIOC > NASIOC Subaru Models > Forester Forum
Old 07-31-2020, 10:47 AM   #1
qtr_wrx
Member#: 109567
Default 27.5 inch tires on stock 16 inch wheels
Gents,
I have looked it up in google but most I found were with lower offset wheels. I have my 2 inch ADF kit coming on the way and I want to keep the oem steelies (I like the base look) but I'm really not sure since I see all the guys go with aftermarket low offset wheels.
Will I run into rubbing issues with stock 16 inch steelies with 27.5 tires and 2 inch lift?
qtr_wrx is offline   Reply With Quote
Old 07-31-2020, 11:53 AM   #2
GalaxyWide
Member#: 383291
2004 Forester XT
Cayenne Red
That depends on which generation of forester you have, the older you go the less room there is in the wheel wells.
GalaxyWide is offline   Reply With Quote
Old 07-31-2020, 01:31 PM   #3
qtr_wrx
Member#: 109567
Ah my bad I totally forgot. Its 2004 2.5x.
Old 07-31-2020, 01:48 PM   #4
GalaxyWide
Member#: 383291
2004 Forester XT
Cayenne Red
In that case you should be fine, I'm running a 215/70/16 tire on stock FXT wheels and a 2" lift no problem. I sometimes have very minor rubbing at full lock if the suspension is compressed in the front, and I do remember having to slightly trim my fender liners before I got trailing arm spacers. But my tire is nearly 28", so you ought to be fine with 27.5
Old 07-31-2020, 05:52 PM   #5
qtr_wrx
Member#: 109567
Thats great Thank you Sir
