05-12-2003, 10:53 PM | #51 | |
Member#: 26361
TXIC
Vehicle:My shenanigans are cheeky and fun |
I know torque can change when a wheel looses traction but I did not find what you are saying in those articles.
05-12-2003, 10:59 PM | #52 | |
Member#: 13095
FREE: Front to rear power distribution = 36:64. I'm not sure what you are asking unless you are distinguishing power distribution from torque distribution, in which case you've lost me again. |
05-12-2003, 11:01 PM | #53 |
Member#: 26361
TXIC
I was asking in what thread you found ^^^this and who posted it.
05-12-2003, 11:04 PM | #54 | |
Member#: 13095
05-13-2003, 12:29 AM | #55 | ||
Member#: 8193
Vehicle:2008 WRX STI Blue |
05-13-2003, 04:24 PM | #56 |
Member#: 3683
Vehicle:2007 Corvette Black |
Perhaps what it's saying is that as the load distribution (or weight distribution? are these synonymous?) changes, the torque distribution changes. More *load* to the front, more power to the front. More *load* to the rear, more power to the rear.
At least that's how I interpret it. So this doesn't equate to 50/50 torque (power) distribution. Edit: Having given it more thought, I think Load Distribution may refer to the torque load at the wheels, that is, the amount of traction. Still trying to figure this out. Not that it matters, since I won't likely be getting an STi (not for a few years anyway). Last edited by brainrally; 05-13-2003 at 05:33 PM. |
05-13-2003, 04:31 PM | #57 | |
Member#: 856
International
Vehicle:2123 JDM STi Black |
The DCCD-A doesnt affect the way the centre diff works, all it is doing is using sensor inputs to alter the % lock of the centre diff, it's just replacing your index finger on the dial with something more inteligent. So the fact it measures throttle position etc has no relevence whatsoever to how the diff unit works. Add to that the bumf from SOA says there are 6 positions, again that is wrong, the DCCD-A is infinately variable from 0-100% locked, there are 6 LED's on the dash to give you an indication of roughly where the settings are, but that doesnt mean it has 6 distinct positions, the dial you adjust is a potentiometer, not a 6 position switch. Having spent some time with the first comercially available active centre diff controller, way before the DCCD-A came out, i know how the DCCD electromagnet control ECU works too. What manufacturers release to the public isnt always technically correct, they are just trying to explain things in a manner that is easily understandable. |
05-13-2003, 06:21 PM | #58 | |
Member#: 13095
Just a taste and I quote....... "Taking A Curve With DCCD As the driver releases the throttle and applies the brakes approaching a turn, the center differential locking force is minimal. As the driver turns the car into the apex of the curve, the lateral g force increases. As a result, DCCD begins to lock the differential, transferring power to the front wheels. As the car exits the corner and the driver applies the throttle, DCCD continues to progressively lock the differential to help prevent oversteer and maintain stability." Now according to you...the act of locking the dccd does not transfer power (ie - redistribute torque), and therefore locking the DCCD based on G force is irrelevant to to the issue of torque distribution. I still don't know how DCCD works, but either you or Subaru are completely wrong about its functionality. |
05-13-2003, 06:29 PM | #59 | |
Member#: 13095
ie - the car is front heavy, approx 59/41 but under acceleration it is less front heavy, under braking it is more so. Don't lose sight of the issue though......we are discussing whether the effective torque distribution changes or remains fixed......., the manual's explanation clearly implies the torque distribution is not the same when diff locked as it is when diff free.....the whole paragraph is dedicated to that premise. |
05-14-2003, 05:42 PM | #60 |
Member#: 3073
Man... I have been banging away at this for a while trying to get my head around it but... I think I have something. After doing a bunch of reading on SAE articles, TBR definitions, differentiating LSC and LSD (man the Audi Haldex people are uptight), it took one look at the trusty AutoZine article on differentials to make it click. Basically, I forgot that Subaru uses a Viscous Coupling Differential Lock system for their AWD centre differential. This is basically an open diff with a viscous coupler at one of the output driveshafts.
Now, having never seen a DCCD equipped STi, I'm taking a stab here but I'm guessing that it essentially replaces the Viscous Coupler with a Electromagnetic controlled wet multiplate clutch system. With the DCCD-A, the ECU gathers data from the various sensors and outputs a current (of various amperage) to stimulate a magnetic field thus causing the clutch plates to be "magnetized" and thus lock. On manual mode, a current at a constant level (but manually adjustable using the dial) is outputted causing various levels/percentage of lock. If this is what it is, John's description makes sense. The torque split, as he refers to it, will be 35/65 since the centre diff will be geared to as such. No amount of adjustment on the DCCD will change the mechanical torque split of the centre diff. The DCCD just adjusts the amount of lock of the multiplate clutch system. So, if the diff is open, then we essentially have an open centre diff that has a torque split of 35/65 with no anti-slip properties. Get both front or rear wheels on glare ice at a standstill, and you're likely not going anywhere. With any other DCCD setting, the torque split is still 35/65 as the clutch system tries to prevent any slip between the two output shafts. Does that make any sense? Ray |
05-14-2003, 06:04 PM | #61 | |
Member#: 8193
Why everybody forgets about treating locked diff as a solid connection? No slip means exactly this. And at this point there is no way to delive different torque to each end of the car so it's 50:50. And this is exactly what Subaru says but some people here think they know better. |
05-14-2003, 06:30 PM | #62 | |
Member#: 13095
What is happening at the various points between full-lock and full-slip? Subaru implies that under cornering situation in DCCD-A the diff moves toward lock. Does this imply that the diff treats the conering scenero as a slip situation because of the differences in wheel speed between front and rear wheels.....and so redistubutes torque? Does it actually require wheel "spin" per se in the rear wheels or is the natural difference in wheel speed under cornering suffice to trigger? What happens when the front wheels are the ones spinning under DCCD-A? Does this cause the diff to close or open? If the diffs functionality can be expressed entirely in terms of wheel slip (odd that Subaru often avoids the term wheel slip in it's DCCD explanations but uses it liberally in it's VCD explanations), then can we express it in terms of a certain pertentage of diff lock allowing a certain amount of wheel slip...... or not? This is why I have a problem with circular explanations that state that DCCD simply progressively locks or unlocks the differential..... and therefore....what? Different amounts of slip between front and rear are allowed? Torque is redistributed to a different degree? It still has not been explained. |
05-14-2003, 06:47 PM | #63 | |
Member#: 8193
Viscous are reacting to a different speed on both ends and this creates a lock but DCCD might even leave it opened or lock more then just reaction to this difference. |
05-15-2003, 11:59 AM | #64 |
Member#: 36869
SOA description notes a PLANETARY gearset
Did you note that the SOA description of DCCD states the center diff uses a PLANETARY gearset? Yes, the same sort of gear system used in automatic transmssions, which allows for the output gearing to be altered simply by applying clutch pressure to various points within the planetary gearset.
An automatic transmission can switch output gearing without meshing and unmeshing any gears, and so could the DCCD. But is this how it actually works? I don't know, haven't done enough research yet. But it would appear that the DCCD could indeed vary torque split by altering the effective gearing, assuming the clutch is acting on the planetary gearset the same way that the clutches in an auto tranny act on its planetary gearset. So is this how the (US version STi) DCCD works? Like a 6 speed automatic tranny, with a thumb wheel 'Tiptronic' mode, and a fully auto mode? switching in 6 possible steps between a gear ratio of 65:35 and 50:50? Or does it (the US STi DCCD) have fixed 65:35 gearing, and all that the clutch does is vary the amount of 'lock-up', or slip, front to rear (as has been posted?) If all the clutch does is vary the amount of slip, why would the DCCD need a planetary gearset? Obviously one doesn't have to have all these answers to drive it, even to drive it well. But that doesn't stop us from wanting, needing, to know. I for one am still wanting for a more thorough understanding. |
05-15-2003, 02:04 PM | #65 |
Member#: 9567
Vehicle:2005 Legacy GT Wagon Silver |
I thought torque distribution and slip were two different things.
Follow my example: Let's say I put 100lbft of torque through a differential that is 35:65 split. Let's say both sides have traction and can transfer the full amount of torque. On one side I will measure 35lbft of torque and on the other I will measure 65lbft of torque. This is what the 35:65 split means. Now let's say I take that same differential, leave the differential completely open and put the 35% side on a slippery surface. The amount of torque being applied to the slippery surface is 0lbft. It's slipping: no torque is applied. Now we need to calculate how much torque is being applied to the other end. Since this is an open differential, the same amount of torque is applied to the other end (by percentage). This is effectively 65% x 0 or 0 torque. Now if we lock the differential fully, 65% of the full 100lbft of input torque or 65 will be transferred instead of the fully open case (which is 0). I would propose that incrementally moving through the DCCD locks would provide for increasing/decreasing amounts of slippage. The effect you would see is less power being provided to the rear if the front is slipping and vice versa. The amount of fall off would vary in proportion to the openness of the DCCD setting. For example, let's say DCCD is set to 50% slippage. I would expect to see 50% x 100 x 65% or about 32.5lbft of torque on the 65% side if the 35% is fully slipping. In this way controlling the slippage of the DCCD will control the amount of effective torque being put down by the wheels which are NOT slipping. You have no way of varying the torque of wheels which are slipping. They are slipping after all and the amount of torque they put down is dependent on the tire and the surface. Nor can you vary the base percentage of the input torque that either side will receive. However, you are varying the *effective* amount of torque that makes it to the ground. So, if you wanted to get really layman you could say that the DCCD differential is a 35:65 torque split with the ability to put more torque forward or aft as needed (read: when the wheels are slipping). Now the auto setting of DCCD checks various sensors and adjusts the amount of lock for you. That's pretty tricky and you would need to know exactly what sensors they are looking at and exactly what they are trying to do to figure out how it works. But it must work pretty well because most reviewers seems to think that Auto is a good setting if you're not 100% sure what you're doing. Note that this is much different from most clutching systems. These systems usually employ a disengaged clutch giving 100% of the power to the front wheels (FWD). When there is slippage the clutch can fully engage giving a 50:50 locked torque distribution between front and rear. The advantage of this system is fuel economy under 'normal conditions' at the expense of response time to slippage. Incidentally, most 4x4 setups use fully locking differentials. Since there is no slip in these systems, they recommend against using them on dry pavement. I would imagine that subaru would recommend against using full DCCD lock if no slip is antcipated. Then again, 'full' DCCD lock might allow for some slippage (not 100% locked) which would make this less stressful. Anyway, there's my conjecture and explanation given the stuff that I've seen and my rather limited understanding of the mechanics involved. Last edited by reks; 05-15-2003 at 02:09 PM. |
05-15-2003, 03:21 PM | #66 | ||
Member#: 3073
Autozine's article on diffs See the open centre diff and the separate viscous coupler attached to only one output driveshaft? The centre diff provides the torque split via the side gears or, the gears that are connected to the driveshafts within the differential. The VC is a 1 input, 1 output device that provides the anti-slip function. The VC does not alter torque split. It can't as it has no gears to apply a different torque ratio. At the same time, the centre diff cannot change torque splits because there's only one set of gears. This applies to the STi's centre differential as I believe (based on John's comments about removing the electromaget and the centre diff is still there) that the STi's DCCD comprises an centre open diff like in the diagram, but replaces the VC with a electromagnetic wet multiplate clutch system. The electromagnetic setup still has no gears to alter torque split as this is derived from the centre diff's gears. Quote:
This is the way I see it. STi's DCCD centre diff uses a planetary gearset to achieve a 35:65 rear bias torque split. However, I still think its an open centre diff that has a planetary gearset at one end of the side gears. It would use the standard side gear as the input, the planet gears as the stationary medium and the ring gear for output. However, that's all it will do. There is no changing of gears at the planetary gearset. To do so smoothly would require building the smoothest, non shuddering, in an extremerly small package mini auto transmission within a differential that is the size of a hand. The planetary gearset just provides a gearing increase for one end thus giving it a higher torque bias. Ray |
05-15-2003, 03:26 PM | #67 |
Member#: 34627
Vehicle:2006 Evo IX GSR Graphite Grey |
Nice try guys.... I'm totally lost. Anyone else, or am I such a noobie that I'm just too dense?
05-15-2003, 04:10 PM | #68 | |||
Member#: 8193
WRX has voscous in center and rear. Only front is open. Quote:
Did you ever drive a MT car? Do you know what is a clutch? Can it vary torque without any gears? Quote:
Why do you need AT in a center diff? Answer my question I already asked: How it's possible to have a different torque delivered to front then rear when diff is fully locked? |
05-15-2003, 06:22 PM | #69 | |
Member#: 31892
Vehicle:2004 STi Silver |
05-16-2003, 03:54 AM | #70 |
Member#: 35871
SCIC
Vehicle:2003 WRX Wagon MBP Spun Bearing @ 176k |
Pertaining to differentials in general, I don't see how a locked diff can have a 35:65 torque distribution. A locked diff has a 50:50 distribution. If "gearing" were to give it anything but 50:50 you'd have wheels going different speeds, and a lot of tension on the diff while cruising. At 65mph, a 35:65 split in a "locked" diff would give you 34.45 mph on one end of the car, and 65 mph on the other. I don't find that believable.
The basic function of a differential is to allow the shafts at opposite ends to turn at different speeds. The limited slip, variable, torsen, locker, and other features only enhance the basic function. This basic function is achieved through slippage (of some sort) inside the diff. Controlling this slippage, ie. DCCD, controls the amouont of torque/power applied the each shaft. With some slippage occuring, both shafts can turn the same speed, but the torque applied to each can be different. Without slippage, the shafts must turn the same speed, hence a locked situation would yield a 50:50 distribution. I don't think I need to go into specifics regaridng the STi or anything else similarly equipped, but if there's questions or contradictions, of course post them. |
05-16-2003, 08:54 AM | #71 |
Member#: 13095
I think the argument that locked diff = approximately 50/50 torque, and is distinct from open diff's 35/65 is fairly clear and persuasive. It is consistent with the manuals on DCCD and no one has presented any argument directly to the contrary. (ie - explaining how diff can be locked and still transmit variable torque front to rear; notwithstanding issues of traction loss, etc..)
Now, let's deal with settings other than open and locked. If the dccd clutch is in an intermediate postion allowing some slip, does that imply that torque distribution is generally somewhere between 50/50 and 35/65? Is the analogy that has been offered of an manual tranny clutch, which of course does vary torque distribution between the engine and the transmission by varying slip, appropriate, or is it flawed? If the tranny clutch analogy is appropriate then i'm satisfied that we've answered the most pressing question about DCCD's funtionality. If it isn't, uh.....then we're still lost. |
05-16-2003, 01:00 PM | #72 | |||
Member#: 35871
SCIC
A fully open diff (ie. FWD) still has some natural resistance to slippage. The specific amount, or 35:65 possibly, would be determined by the design of the diff. If the diff were designed to have a different ratio, say 0:100 or 15:85, then the DCCD would have to have the electromagnet energized all the time to achieve the default 35:65 ratio, but that's entirely possible. I think it'd be a much simpler design to have the 35:65 built into the diff and use the elctromagnet to adjust it tighter from there. Quote:
05-16-2003, 02:49 PM | #73 | |||
Member#: 3073
Well, there is a way but it results in a part time AWD system like that of VW's old Syncho system. Let's take this a bit further and describe it. The syncro system works like this: The front diff gets power all the time. The driveshaft to the VC is driven in step with the front diff. Then, the power goes into the viscous coupling, where the viscous fluid is stable unless there is a great difference in speed of the input and output. Since its stable, it means no torque is transferred to the rear end. In the case of front diff wheelspin, the input and output shaft speeds of the VC are very different. This causes the viscous fluid to quickly heats up in the VC which stiffens up the coupling between the input and the output. Now, torque is being transferred. So, in this situation, there is no way for full time AWD system and certainly not a normally operating 50:50 split of the WRX. So how does Subaru do it? It adds a open differential to work alongside the VC. So, the WRX has a viscous coupler alongside an open differential for its AWD. Those two devices work in conjuntion to create the LSD. Incidentally, the open front diff of the WRX is located in the transmission. The centre open diff and VC is located in the transfer case. Two separate devices. So how does it all work? The engine spins the ring gear of the open differential and the two side gears of the diff are part of the front and rear driveshaft. One input, two outputs. The centre diff allows for rotational differences but it always outputs equal amounts of torque since the side gears are geared as such. The VC then receives as an input, the front or rear driveshaft to create the anti-slip function. I think, the VC is connected to the front driveshaft. If the front wheels begin to slip, the VC will try to slow the wheels down masking the fact that the front wheels are slipping to the open diff. Since the open diff doesn't sense wheel slippage, it happily continues distributing torque to the rear. But what happens if both the rear wheels slip (on ice)? Well, in this configuration, the rear end just spins like mad since there is no VC unit to mask the rear slippage to the open diff. Quote:
But onto your last question, if the diff is fully locked, how is it possible to deliver different torque splits front and rear? Well, if you believe my explanation that the AWD of Subaru's WRX comprises both a VC and an open centre differential, its quite easy. Since the VC is external to the open centre diff, we can see that regardless of whether the VC fluid is shearing or stable, the ultimate torque split is determined by the gearing of the open diff. Let's take an example. Assume the standard WRX with its 50:50 distribution. On normal traction filled conditions driving in a straight line, the VC fluid is stable and the open diff distributes 50:50 torque split. In a turning situation, the rear end wants to travel slower since it is travelling a shorter distance than the fronts. The centre diff compensates for the difference in rotation speeds by letting the pinion gears turn but it still applies torque 50:50. Now right here, you might say this doesn't make sense. If the speeds are different, then torque must be delivered somewhere else. First, remember what torque is: torque is rotational force. You can generate the same amount of torque at different rotational speeds. Look at car engines. With a two different car engines, you can have engine A develop 150 lb-ft of torque at 5000 RPM while engine B develops 150 lb-ft of torque at 3500 RPM. Different speeds but same values of torque. So ultimately, how is torque defined within a differential? By the gearing of the differential. The pinion gears within the diff allow for different rotational speeds but it still applies a 50:50 torque split. As for the VC, well it could be stable or shearing but it doesn't change the gearing of the diff. So now, change the gearing within the diff to accept a 35:65 split and my statement still holds. It's the gearing of the diff that determines the split. Not the VC or electromagnet. Ray (who after all the research, lights are coming on) |
05-16-2003, 05:08 PM | #74 | |||
Member#: 8193
05-16-2003, 06:27 PM | #75 |
Member#: 856
International
with no power to the electromagnet the diff is open, it is in that state when the diff is set to open or if the power to the centre diff ECU fails.
A little picie to keep you going, this is me with the car set to an open centre diff, the rears are spinning hence the tyre smoke, yet still providing a large forward/sideways force, the fronts are freewheeling. If it were raining i could show you how having the diff fully locked i could still get the car in that angle, but the front wheels would be pointing straighter with all 4 wheels spinning, still with more power to the rears than the front in a 65:35 split. |
Come on i-clubbers, what's one thing that you are ashamed of actually liking. | Eric SS | Off-Topic | 72 | 01-02-2009 07:42 PM |
The ONLY thing that will be on the news for the next 4 weeks | tacomaprime | Off-Topic | 11 | 11-14-2007 12:56 PM |
New, 2005 2.5RS or used, 02-03 WRX for a first-time Subie driver? | live- | Newbies & FAQs | 19 | 02-10-2005 02:29 AM |
haha that new Neon...first time ive seen one yet | yzfrone | Mid Atlantic Impreza Club -- MAIC | 33 | 12-19-2003 07:24 PM |
One thing that is wrong with the world (music related) | JGard | Off-Topic | 18 | 03-05-2003 07:19 PM |
