04-29-2003, 12:29 AM | #26 |
Member#: 26361
TXIC
Vehicle:My shenanigans are cheeky and fun |
Thanks for clearing that up Paul, I didnt know that our front bar was bigger then Japans. If thats what is causing the understeer then I have no problem changing that out since I will still be legal for stock competition in scca autox.
04-29-2003, 12:31 AM | #27 | |
Member#: 17887
Vehicle:05 LGTW Ltd AT 05 Evo RS |
The STi has a TINY edge in lap times, but I wonder what C&D means by "the STi trailed the livelier-handling Evolution on ... the Streets of Willow road course" I'm guessing they are talking subjectively? For me personally, the subjective feel of a car is WAY more important than the numbers, so from a purely journalistic point of view, this comparison tilts the balance in favor of the EVO. Obviously, I won't really know till I drive them both. This is getting really exciting and I cannot wait. EDIT: I stand corrected, it is the EVO that got the best lap and since the driver was Rod Millen, I definately trust his ability to push the cars to their limits. I am really glad C&D choose a PRO to do the lap times. Last edited by 97itr153; 04-29-2003 at 01:12 AM. |
04-29-2003, 12:32 AM | #28 |
Member#: 13095
It seems like dccd doesn't so much kill the WRX tendency to understeer as complicate it. That's the only disappointment I see with C&D's numbers for the STI..... the skidpad number is equal and in their slalom equivalent is actually significantly better than the Evos.
I have to say in fairness to Shiv's remarks though....I think Car and Driver's comments about the handling of the STI are very similar to his, and completely vindicate his comments. The fact that the Evo can come out ahead on the track testing, when it is obviously battling a power deficit with the STI says volumes about how fast the car is and can be driven on a track. Same with braking where the Evo has been consistently a little bit better albeit on wider tires, in every comparison i've seen. Although the differences on the track and courses were only a fraction of a second, they obviously speak to a handling advantage of the Evo, because if you look at all the acceleration times...it is perfectly clear that the STI is significantly faster throughout the rev range and in every gear (MotorTrend is either being misquoted or on drugs) The STI is 1/2 a second quicker to 60 1 second faster to 100 and 4 seconds faster to 130, faster in every top-gear measure,....street start of almost 1 sec. better than the Evo, and so on. All while being more street (as opposed to track) friendly. Car and Driver's times are typical for the Evo, so I only hope they are equally representative for the STI, and I have a feeling they will be. Last edited by strangerq; 04-29-2003 at 12:40 AM. |
04-29-2003, 12:33 AM | #29 |
Member#: 26361
TXIC
What do you mean?
The evo had a slight edge in lap times because they could get it to handle better, the sti made up time powering out of turns and straights. |
04-29-2003, 12:43 AM | #30 |
Member#: 8351
Vehicle:2002 WRX Wagon |
To clarify:
C&D road course, Rod Millen driving Evo 1:04.18 STi 1:04.34 .16 seconds difference Obviously, some tracks will favor the STi's power and some the Evo's handling edge. With a difference that small, alignment settings and driver skill (and style) will make the difference on a track more than anything. TRS |
04-29-2003, 12:45 AM | #31 |
Member#: 5489
NWIC
Vehicle:2013 FR-S AVO Orange |
The STi would make up it's time in the straights - if there were any of significance. A 1.1 mile long track isn't going to have much of a straight in it, unless it's only got two turns. I've never driven Streets of Willow, but if it's anything like Tsukuba Circuit (which is actually a bit longer), then the Evo would make up for it's power deficit with cornering speeds.
The DCCD-A does help for power distribution, but as I've noted before, most of the changes came from different suspension geometry and tuning, not only the DCCD-A system. And Subaru has changed it around a tad from the cars I've driven. Little stuff that could add up to .5 of a second around a track. Now, this is the point where I add in "but when you get down to it, there's no way the better driver is going to lose if he's in either of these cars. Their times are so close that it will easily swing either way". BTW - those lap times are indicative of what I've been saying all along - despite the subjective "evo must be faster because it feels faster" comments, the cars are actually incredibly close in times. Cheers, Paul Hansen www.apexjapan.com |
04-29-2003, 12:46 AM | #32 |
Member#: 2258
Vehicle:1999 gc8 ver7 6mt GT35R 504.7whp;) |
just to note, yes streets of willow is rather tight, and rod millen is known for driving Evo's.
04-29-2003, 12:48 AM | #33 | |
Member#: 17887
Are you implying that with these cars, it is not a good idea to use trail-braking when entering a corner? Are you suggesting a slow-in, fast-out, deep corner entry with most of the braking completed before turning in? I hope to test drive an EVO in the next month or so and I would like to try out some of the things you suggest. My usual approach in most 2wd cars is to use a good amount of trail-braking to get the car rotated before the apex. However, This type of technique is dangerous in cars like the Lotus 7 replicas. I spun a Birkin (Lotus 7) yesterday at an Autocross Novice school in which I was instructing. It was the first time I had driven a "7" replica and I was a little surprised by the car's behavior during lift-throttle while cornering I wasn't quite as embassased since another Instructor (also a national-level Autocross driver like myself) had spun the same car in the SAME turn earlier in the day. Whew! Any advice is appreciated. |
04-29-2003, 12:51 AM | #34 |
Member#: 35097
RMIC
Vehicle:2002 WRX Sedan PSM |
Holy *****!!! 4 seconds is a HUGE difference in acceleration to 130 mph. Otherwise this seems to be a close competition... only time will tell.
04-29-2003, 12:52 AM | #35 |
Member#: 26361
TXIC
Paul recommended at least left foot braking which is in essecnce trail braking while using some throttle.
BTW dont try left foot brakein for the first time on your test drive for you will introduce you and your salesmans forheads to the windshield. Last edited by afpdl; 04-29-2003 at 12:57 AM. |
04-29-2003, 01:12 AM | #36 | |
Member#: 13095
Still, the STI at this point needs at least one example of a faster track-time to alter the perception that the EVo is simply a fundamentally better track car. Let the reviews roll in. |
04-29-2003, 01:13 AM | #37 |
Member#: 32799
All in all, while I'm slightly dissapointed the STi didn't win hands down, I must honestly say that I like what I'm seeing, at Least from CD... (MT's got problems...)
For my purposes, the STi remains the choice car (I'll take the nicer interior and more power). But mad respect to the EVO. Its a nice market segment, no matter which you drive. This just might get me out to at least Test-drive the EVO before buying, but I honestly don't know If I could live with the looks.. I mean, I don't know why, but I just find them far to... childish I suppose. But you know what, its goes fast, they're going to be good competition, and I look forward to a _friendly_ rivalry with Evo Owners for years to come... Now all I have to do is graduate and go fulltime with Nextel:-D -Scott |
04-29-2003, 01:14 AM | #38 |
Member#: 16371
Vehicle:02 WRX wagon BLACK |
guess went it comes down to it, the best mod for either car is driving school and practice on the track of your preference, that maybe the difference of that 1/2 sec difference.
04-29-2003, 01:18 AM | #39 | |
Member#: 514
SCIC
Vehicle:07 Legacy Spec B Impreza 93 STI |
Conflict
So naturally he would most likely drive the EVO better than the STi. Just validates that the cars are both at the top of the game and personal preference will count most. Performance equality for almost anyone else. My vote is STi! Mike M |
04-29-2003, 01:22 AM | #40 |
Member#: 11316
Vehicle:1988 E30S52 DD S14VQ35 & S13KA racecarzz |
Wow, i think this is amazing. 2 cars couldn't be more evenly matched, incredible.
Couple things that's just really bothering me though and that's the comments about the understeer, and lack of lateral support from the seats for the STI. I was hoping this car would be pretty much void of both. While the seat thing really isn't a big deal at all, the understeer is eating away at my mind |
04-29-2003, 01:25 AM | #41 |
Member#: 26361
TXIC
Funny motor trend both had the times reversed and thought that the sti had great supportive seats Maybe they had a 350 pounder driving the sti, that could have explained alot.
04-29-2003, 01:43 AM | #42 | |
Member#: 13095
If it was any other magazine, you'd know the joker who posted just transposed the remarks for laughs...... However, Motortrend is just wacky enough so that you can't know for sure until someone scans.... |
04-29-2003, 01:43 AM | #43 | |
Member#: 5489
NWIC
View understeer as a number. 100 is extreme Oversteer. 0 is extreme Understeer. Now, a rental Corolla has an rating of 1. A Camaro with two spare tyres on the back is around 95. Now, the Evo may be at 68, and the STi at 66. In comparison to the Corolla, you wouldn't describe the STi or Evo as having any understeer. In comparison to the Camaro, the STi or Evo wouldn't have any oversteer. But in comparison to each other in a back to back test, the STi understeers in comparison to the Evo. Cheers, Paul Hansen www.apexjapan.com |
04-29-2003, 01:47 AM | #44 |
Member#: 31656
gills,
keep in mind that with cars this similar and the fact that this is a comparison article, they have to favor one car over the other to some degree and the most miniscule differences are going to be mentioned. I'm sure that with the numbers this car is posting the understeer is relative to the handling of the evo, which appears to be quite good. Don't make the mistake of thinking understeer in the sti is going to be anything like a typical front driver. |
04-29-2003, 02:03 AM | #45 | ||
Member#: 5489
NWIC
Left-foot braking, or in my case, side-of-the-right-foot braking, is quite a useful technique for balancing a AWD or FWD car in corners. But, I must add, it's easy to over-rely on it and use it too much, which will actually be slower than the fastest way through the corner. However, it's safer, and when I'm learning corners (and the car I'm in), I'll use it heavily until I know the corner well as far as entry/apex/exit speeds, then I'll just use it lightly on entry and balance with the throttle the rest of the way. There is no way I'll be off the throttle at any point past entry, though, that's a good way to snap oversteer. And snap oversteer may be an option for some people to rotate the car, but if you are going fast enough and near enough to the traction limits, snap oversteer is rolling the dice way too often. If you find yourself needing to rotate the car that much, then a review of the entry/apex/exit points that you are using for that corner is probably in order. Quote:
Also, do keep in mind that I am not a professional instructor nor professional race driver. I have a fair knowledge of what's going on, I do well on the course, but back to back with professional race drivers, I get my rear-end handed to me. I love racing against them, though, because it always improves my times and skills each and every time, I'm a very competitive person. But it also means that I'm not the ultimate authority on the matter - though I've yet to actually meet an ultimate authority, because every professional racer that I have met has a different style and way of going about things. Shimizu-san, who is a very good driver of Subaru's and well-placed with them, goes for the chuck it in sideways method. Reallllly sideways. According to another good Subaru driver/tuner, this is the preferred method for STi's - always keep the front wheels in the direction you want to go and simply keep on the gas, it'll eventually pull itself together and go there. To be very honest, I've yet to go as deep and hard as Shimizu and Ross go, and I'm not the type to abuse a car that much, so I'll just nod and pass their information on. Cheers, Paul Hansen www.apexjapan.com |
04-29-2003, 02:06 AM | #46 |
Member#: 11316
I know what you guys are saying and i already knew that. I just needed it to be reiterated The difference is so miniscule that it doesn't even matter. My god, look at the difference in lap times!!!! That right there is all driver.
04-29-2003, 02:16 AM | #47 |
Member#: 18709
hey paul, would you say that the JDM spec STi and US spec STi are similar, now that you've driven both? what would be the small differences between the two?
04-29-2003, 02:25 AM | #48 |
Member#: 26361
TXIC
Umm when did paul drive a US sti? And I believe we have a diffent supension then the standard sti as well as more weight.
04-29-2003, 03:00 AM | #49 |
Member#: 18709
oh yeah, i forgot, he's in japan, my bad. well, he seems to know quite a deal about the Japan spec STi. I was just wondering if he could come up with a comparison with the JDM STi and the US STi. i'm assuming they're pretty close in terms of performance. thanks for the heads up.
04-29-2003, 05:34 AM | #50 |
Member#: 7852
Vehicle:03 White Lan EVO 8 97 Techno-Violet BMW M3/2 |
Paul..
I thought I remember a bit back someone posted the suspesion spec for the USDM STi (I believe it was Jon)... If I remember correctly.. it's 19mm front & 19mm rear... which should've been a very neutral set up??? In comparison... EVO uses 24/22mm.... which explains the complete lack of body roll that many claims... |
Drag and Slalom STI vs Evo | IflyanSTI | Off-Topic | 15 | 01-21-2008 11:40 AM |
Road and Track: STi vs. EVO (Video)... | jsavage | General Community | 41 | 11-20-2005 07:26 PM |
Winter driving: STi vs. Evo article | ewt | News & Rumors | 1 | 01-24-2004 04:40 PM |
Car and Driver / Road and Track: STi vs. EVO | cky3396 | STi Forum Archive | 3 | 04-21-2003 02:48 AM |
