Welcome to the North American Subaru Impreza Owners Club Friday March 29, 2024
Old 03-27-2008, 08:40 AM   #76
Mulder
Trust no one
Member#: 11170
02 RAV4 MT
15 WRX/11 CRZ
Originally Posted by reinhard79 View Post
does somebody know if you disable the drl would appear any warning light in the dashboard?? and somebody can send me the pictures of how to disable the drl please i will receive my hids this weekend so i need to doit this weekend thanks folks!!
Rather than bumping an ancient thread, you can just search for the necessary information which has been posted here multiple times. You also must add your vehicle information to your profile for an accurate response, since the DRL disable information is different depending on what model/year you have.
Old 03-28-2008, 12:25 AM   #77
reinhard79
Member#: 175726
hi there i have a wrx tr 2007 i couldn't find which one is the switch that i have to unplug in order to disble the drls under the globebox can somebody send me pictures to my email it will be really appreciated my email is [email protected]
thanks
reinhard79 is offline   Reply With Quote
Old 03-28-2008, 12:38 AM   #78
crzyazzpolak717
Member#: 174768
under the hood there is one but i dont recomend it, so ill tell u about the module in the cabin
on the pass side remove the glove box, all u need is a philips screw drive, unscrew all inside and two under it and one clip on the side, it will then come out
on ur right side of the car ull see 2 relays in plain site directly (one inch at most) behind these relays is the module just unplug it and ur fine :-)
crzyazzpolak717 is offline   Reply With Quote
Old 03-28-2008, 07:43 AM   #79
Mulder
Trust no one
Member#: 11170
02 RAV4 MT
15 WRX/11 CRZ
Too bad this won't work because he has an 07, they are different.
Old 04-07-2008, 03:41 PM   #80
mycarsux
Member#: 32049
2010 sti
sorry to add on to the noobness, but can anybody post pictures of the drl thingi behind the glove box?? i searched and everything, but all of the pictures are red xs to me. maybe the pictures are too old and got deleted?
i went to my car and saw a brown one, and a green pluged into a white. i haven't removed the glove box yet. thanks in advance.
mycarsux is offline   Reply With Quote
Old 05-13-2008, 10:33 AM   #81
AaronCompNetSys
Member#: 144848
05 WRX, 17 M2
01 S2K, 16 Fozzy Turbo
Apparently all the photos died, and I was too lazy to take one. Here is the lost photo I found on archive.org
DRL connector module in the glove box on 2004 2005 04 05 Impreza WRX Daytime running lights
AaronCompNetSys is offline   Reply With Quote
Old 01-25-2009, 03:03 PM   #82
PelvaanAli
Member#: 190157
2003 WRX
i wanted to pull my DRL because my HID's would flicker with the DRLs...pissed me off
i pulled the harness from under the engine bay for now. Ill plug it back in and do the glove compartment one later. too cold outside.
PelvaanAli is offline   Reply With Quote
Old 01-25-2009, 03:58 PM   #83
ravenlunatic
Member#: 180601
2003 PSM WRX
(>")>==HADOKEN==<(o)
i did my 02 a few weeks ago. it looks very similar to the 04 and 05's
Very easy to do, took me all of 10 minutes and that was including lunch!
ravenlunatic is offline   Reply With Quote
Old 07-31-2009, 07:33 PM   #84
red_rex_rally
Member#: 216607
RED
I did this and it made my fogs go off and they wouldnt come back on until I plugged her back in...hmmm
red_rex_rally is offline   Reply With Quote
Old 11-04-2009, 09:37 PM   #85
OoBUGEYEoO
Member#: 228832
2002 Outback Sport
Tried the one behind the glovebox and it worked except the low beams wouldn't turn on. Couldn't figure it out so I then moved onto the one under the hood that is on the strut but I guess the third clip I pulled under the hood seemed to be the charm because it worked. This thread is so ancient that the pictures are no longer here so I wasn't sure which one of those bastards to pull. So what are the other two clips right there by it that I disconnected because it threw a check engine light... Now I have to go to Auto Zone and check out the trusty OBD II and see if I just effed my new(ish) car...
OoBUGEYEoO is offline   Reply With Quote
Old 11-05-2009, 09:50 AM   #86
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
front o2 sensor, up pipe egt, and boost control solenoid.
edit: noticed your car make/model... not sure what's there. obviously not the boost control solenoid!
Old 05-29-2010, 09:42 PM   #87
952subaru
Member#: 224473
03 WRX
very old thread, but will pulling the one behind the glove box allow me to only have my fog lights on on my03 wrx? if not does anyone know how to only have the fogs on with no headlights
952subaru is offline   Reply With Quote
Old 05-30-2010, 04:18 AM   #88
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
That has been covered many times in this forum. There's about 5 million ways to do it. Search friend, search!
The short answer: no, DRLs have nothing to do with your fogs.
OrbitalEllipses is offline   Reply With Quote
Old 04-28-2011, 09:31 PM   #89
silver_echo
Member#: 241296
2002 wrx
aspen white
posting in this thread to make it easier for me to find it this weekend when i do this mod...
silver_echo is offline   Reply With Quote
Old 08-21-2022, 06:40 PM   #90
post
Member#: 109772
Originally Posted by johnboy View Post
The DRL can be disabled without permanently disconnecting the DRL module. One of the wires (I believe it is the green wire at the corner of the connector) sends a ground to the module when the parking brake is applied. Use a meter to verify. Remove this terminal from the connector and wrap with electrical tape. If this wire makes contact with the chassis or ground, then the car thinks the parking brake is applied and the dash brake light comes on.
Back to the module: Now that the wire from the parking brake has been removed. The DRL will be on even when the parking brake is applied, so you will need to find a terminal that fits into the module (try Radio Shack). Add this terminal where the other one was removed, run to a switch, then to ground.
Now, the DRL will function as normal, except when the switch is closed to ground, and the dash brake light will also function as normal.
i realize this is an 11-year old post but i wanted to say thanks -- followed this advice and wired up a lighted drl-defeat switch on my 2014 wrx today, mounted where the JDM power mirror folding button would have been.
added a diode in series with the parking brake wire, ran a tap after the diode to one side of switch and another from ground at the power-mirror adjust wire ((because that was where i was putting my switch)). tapped power from there too.
it should be pointed out that the parking brake light is illuminated on the dashboard whenever i turn the DRL off with this method. with DRL on, parking brake light works normally. using this method, there's no way around this -- what i'm doing is tricking the DRL module into thinking the brake is on when it isn't.
someone way-back-then had gotten their illuminated SPST switch wiring wrong, so here is how it should be done ((maybe it will help someone one day)):
switch has two wires for the interrupted circuit that it turns on/off (mine were blue), and a ground & a power wire for the light on it.
since i was interrupting a ground wire, i tied together one of the blue wires with the switch's negative wire and patched it into the parking brake signal -- so when the switch is activated it draws a ground signal from the car and sends it to the DRL relay through the parking brake wire. the other blue wire, i connected directly to car ground.
the power wire of the switch i tapped from the car from a source that is live whenever the ignition is on.
this way my switch is always illuminated. if i wanted it to only be lit when i have the DRL circuit ground out, i would have connected the blue+black wire pair from the switch to car ground and the single blue wire to the brake signal.
similarly if you're wanting to use a switch to send power to something, instead of ground, wire a blue & red together instead of a blue & black.
i soldered in insulated disconnects for all the circuits so i can easily re-wire it either back to stock or to a different signal if i ever feel up to running out to the DRL resistor to interrupt its power instead ((which is the right way to do it but i just didn't feel like going to the trouble of routing something through my firewall into the engine bay... give me a couple weeks with the brake light on and maybe i'll wind up doing it anyway))
kudos to johnboy for the post again. i dug around for a couple weeks to see how i could go about this and his post was the single most useful one.
picture of switch below -- a 12mm red LED SPST i got on amazon. had to cut the back of the mirror module a bit to get it to fit, but no real problem; didn't have to saw anything important away just plastic.
post is offline   Reply With Quote
Day Time running lights Dom Canada Region Forum 2 08-29-2001 04:27 AM
Day time running lights subette Newbies & FAQs 33 08-02-2001 12:27 PM
Disabling Day-time Running lights mcv9802 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-17-2001 03:55 PM
Day Time Running Lights CosmoTheCat Interior & Exterior Modification 1 04-12-2001 12:38 AM
day time running lights rbehny General Forum Archive 15 01-29-2001 07:12 PM
