Old 10-28-2015, 06:58 PM   #51
psppopeye
Member#: 407380
2012 imprezza
Deep Cherry Pearl
Default faq?
This info is amazingly detailed. Along with the pics provided, a beginner such as myself can use this material to not only build his/her work kit but can refer back to its many many teaching points & how to's. Thanks for this. Oh and NASA level solderer..... impressive!
psppopeye is offline   Reply With Quote
Old 12-03-2015, 01:23 PM   #52
mccohens
Member#: 429303
Excellent piece and lots of useful information. Not to start an argument but my training was to avoid soldering twisted wires because they cannot flex with then. The whole purpose of twisted strands instead of solid wire is that they bend without any stress.
Another rule I learned was never to trust an electrical connection for mechanical strength.
Putting tubing over the joint helps a lot. Two layers of shrink over solder joints is even better, and clamping the wire also helps.
However my favorite system for stranded wire is a high grade(expensive) in line splice and my crimp tool with interchangeable dies. And a piece of shrink tube over the top.
But if and when I do solder, I do it as you describe.
mccohens is offline   Reply With Quote
Old 10-11-2016, 03:50 PM   #53
further41
Member#: 428001
2014 WRX 603/520
I have been slowly getting better at soldering over the years, but holy cow at all the information in this thread I have never read before even after many hours searching the interwebz. Bravo.
further41 is offline   Reply With Quote
Old 10-30-2019, 07:35 AM   #54
jhkoka
Member#: 507631
Great write-up! Learned lots of new techniques on soldering!
jhkoka is offline   Reply With Quote
Old 12-03-2020, 10:12 PM   #55
Apex2000Rs
Member#: 399419
Originally Posted by fenderman07 View Post
You are supposed to use only enough to saturate/coat the stranded wire for tinning. Anything that is clumpy is too much solder, and if it starts to drip off the wire. When soldering multiple wires, again avoid making it too clumpy. Bottom line is be conservative, it's easier to add more than to undo it.
It is easiest to confirm a good solder connection when you can observe each part, from clean, un-soldered copper nearest the insulation, all the way to a finished solder job where the individual wires can be seen.
Apex2000Rs is offline   Reply With Quote
Automotive Electrical info and FAQ submissions thread. GLwagon Electrical & Lighting 40 10-28-2015 07:33 PM
You guys need/want a Soldering FAQ? Unabomber Electrical & Lighting 30 06-04-2006 09:34 AM
Electrical Engineers or ppl that are really good with soldering [27] Texas Impreza Club Forum -- TXIC 10 11-23-2003 09:07 PM
Electrical Formulas, Basic Electrical information, FAQs, and threads of note GLwagon Electrical & Lighting 2 01-23-2003 07:33 PM
FAQ on FAQ section? Stubaru Newbies & FAQs 3 02-17-2002 08:08 PM
