06-05-2009, 02:45 PM | #1 |
Member#: 181396
Vehicle:99 Razor Scooter |
Classic Daisy BB Gun Help
I was rifling through my grandmother's basement before she moved to Florida and found this in there. The exterior of it is in nearly perfect condition with only a few scratches and wear marks. It has the original box, warranty card, scope advertisement, receipt for $5.75, and I even have the original cylinder case of BB's that came with the gun. It's a Daisy Model 32 Number 106 with the plastic stock. I've found them go from anywhere between $90-$150 for good working condition ones. The only problem I have is that it doesn't work. The lever will **** but when I fire it, it will not expel any BBs or air. I've tried oiling it but I dont know the inner workings of these well enough to get it working.
I don't want to sell it. I'd like to get it working again and hopefully pass it on to a future family member someday. Does anyone know anything about the inner workings of these and could possibly help to get it working again?
06-05-2009, 02:49 PM | #2 |
Member#: 6590
There is a place in SW florida that repairs old Daisy BB guns....can't remember the name right now, but you might be able to find them on Google.
06-05-2009, 02:50 PM | #3 |
Member#: 140529
TXIC
Vehicle:01 Ferrari 360 spy |
You'll shoot your eye out kid.
06-05-2009, 02:52 PM | #4 |
Member#: 68407
South East
Vehicle:A.D. Volvo V60 R Outback 2.5i 6MT |
That looks exactly like my old Daisy PAL from 1985. That invoice looks way older than that though.
06-05-2009, 02:55 PM | #5 |
Member#: 181396
Ive found they were made from "Years Produced 1936-1978 minus the war years"
I cant narrow it down exactly when though, I wish the receipt had a date. |
06-05-2009, 03:03 PM | #6 | |
Member#: 6590
I can't find any listing for that model/number combination. |
06-05-2009, 03:11 PM | #7 | ||
Member#: 76596
NESIC
Vehicle:2012 |
http://www.daisyking.com/history/daisy.htm Last edited by Speedinticket; 06-05-2009 at 03:14 PM. Reason: Added URL |
06-05-2009, 03:18 PM | #8 |
Member#: 79498
SWIC
Vehicle:2020 XV |
Probably mid-50's, since it has a plastic stock.
It's a Daisy Cub Looks great though, probably just needs some seals. |
06-05-2009, 03:37 PM | #9 |
Member#: 122980
South East
Vehicle:2010 F150, 2013 CX-5 92 Miata 15 TTF/PTF/E3 |
06-05-2009, 03:41 PM | #10 |
Member#: 127138
NWIC
Vehicle:2015 Nissan GT-R 2000 2.5RS Sedan |
I used to play with one of those when I was little! So much fun. GL getting it working
06-05-2009, 03:41 PM | #11 |
Member#: 181396
A lot older than I thought. I figured $5.75 back in the 30's, 40's, 50's would be like over $100 today and I never thought these cost that much.
Thanks for all the help thus far. I'm still searching for a repair place locally before I go sending it out. Does anyone know if this is a spring powered or air powered rifle? If it's air, it definitely isn't holding any when the lever is pulled and the tirgger fired. |
06-05-2009, 03:50 PM | #12 |
Member#: 68284
NWIC
Vehicle:2017 Backout Rally America Blue |
I'm pretty sure those were spring powered.
06-05-2009, 03:51 PM | #13 | |
Member#: 79498
SWIC
Vehicle:2020 XV |
There's no fine print on the box, like a copyright date? Last edited by richde; 06-05-2009 at 03:57 PM. |
06-05-2009, 03:52 PM | #14 |
Member#: 6590
I have an older Daisy Powerline 717 pistol that I need repaired too...good luck.
Jeebus, just realized it's going for around $200 now. Last edited by Grap; 06-05-2009 at 03:57 PM. |
06-05-2009, 04:01 PM | #15 |
Member#: 21543
Vehicle:2018 1LE White |
Looks just like the one i had as a kid in the mid 80's, except mine had a wooden stock.
Nice find! |
06-05-2009, 04:04 PM | #16 |
Member#: 68284
NWIC
06-05-2009, 04:06 PM | #17 | |
Member#: 89165
Vehicle:Poop Stuck Survivor -=C=- & subari87 FOREVER! |
That's a cool find, glanga. Good luck getting it up and running again.
I think I paid ~$50 for my 717 back in '82 (or thereabouts). Mine still works. It has been stored for years and years, but every few years or so I pull it out and add a drop of oil if needed. I still have my old Powerline 880, too. That was a good gun. |
06-05-2009, 04:13 PM | #18 |
Member#: 135762
Vehicle:2059 Venturi Skimobi transparent aluminium |
learning to repair it yourself is definitely one of the best choices you can make.
06-05-2009, 04:26 PM | #19 |
Member#: 181396
I'd like to learn to repair it and I've done so with paintball guns but I'm afraid I'll take this apart and either break off an irreplaceable piece or permanentely screw it up beyond repair.
I dont see any fine print on the box. The gun has a serial number (which could hold build date information) as well as the model number. I scoured everything it came with to find a date so far. When I pull the lever back the trigger moves slightly back and it does c0ck itself. It's been a months since I found it and tried using it but if I remember right, when it's fired, the BB just sort of rolled out or went about 1ft then dropped off. |
06-05-2009, 04:28 PM | #20 | |
Member#: 6590
I bought it off some kid for $20 back in the late 80's. I never had a manual or anything and would pump it 10 times. |
06-05-2009, 04:36 PM | #21 |
Member#: 68284
NWIC
Interesting that you found a rifle while rifiling. Like catching a fish while fishing.
06-05-2009, 05:13 PM | #22 | |
Member#: 89165
In the fall of that year, Jerry tried taking his gun apart for some reason, and it didn't work when he putit back together. Our friendship crumbled shortly after that. I always thought it was because we started heading down different paths as we got into 9th grade, but maybe it was the 717 bond that held our friendship together. My 717 and the holster I made: |
06-05-2009, 05:28 PM | #23 |
Member#: 92776
SWIC
Vehicle:2004 VF48 Wagon 6 gear speeding |
Cool little piece of history, neat find.
O_ |
06-05-2009, 05:31 PM | #24 | |
Member#: 121470
Vehicle:2008 WRX Satin White Pearl |
Sweet find. |
06-05-2009, 05:39 PM | #25 |
Member#: 171717
Vehicle:02 wrx srp |
^that same part made me lol
FS MO:6 Round Burst BB Gun and Paintball Guns/Gear! | puggsley | Non-Subaru Stuff | 7 | 02-28-2009 10:11 PM |
OT: airsoft bb guns | imprezaboi | Vancouver Impreza Club Forum -- VIC | 7 | 11-28-2002 12:13 AM |
OT: bb guns | Yang | Vancouver Impreza Club Forum -- VIC | 4 | 07-31-2002 01:29 AM |
OT: BB guns. | Sam_P | Vancouver Impreza Club Forum -- VIC | 50 | 06-30-2002 12:42 PM |
Airsoft/BB guns | INiTiAL33 | Vancouver Impreza Club Forum -- VIC | 14 | 07-27-2001 03:54 AM |
