#1 |
Member#: 64581
NWIC
Vehicle:2004 STI Black |
![]() List of Mods:
APS SR55 Turbo DR725 FMIC CAI Blitz SBC-ID Worx Tuning BOV I have checked all of the hoses for the intercooler. No cracks or breaks in the couplings. I can adjust the boost down but nothing doing past 19PSI ( I was pushing 23). Is there anything else I should check?
#2 |
Member#: 85421
Vehicle:92 EG all mota |
![]() are you running and external or internal gate? is the gate blowing open? Is the bov blowing open. You may need bigger springs? Not sure though
#3 |
Member#: 64581
NWIC
![]() Internal, Nither is blowing open as far as I can tell.
#4 |
Member#: 85421
![]() you used to be able to run 23 and then all of a sudden you couldn't go past 19? That sounds wierd, can you explain this further?
#5 |
Member#: 64581
NWIC
![]() Doing a 4 gear pull on a strip. I got up to 4600RPM at 15.7 PSI. At that time, I heard a small pop like a intercooler hose poped off. I decelerated and got it home with limited boost (under 5 PSI max). I checked all of my hoses (I used C-clamps on all of my intercooler hoses). I checked my BOV.. it was a little dry so I reoiled it and slid it back in. Checked my hoses going to and from the BOV. Got it back out and noted that I was only getting 19 PSI max.
#6 |
Member#: 64581
NWIC
![]() Figured out what the issue was. On the Worx BOV, the top portion was slightly warped. Prob due to the cold air on the inside of the BOV and hot air outside from the engine compartment. The warping caused PSI on top of the piston was out of balance with the bottom. The air leaked along the side in the gap between the piston and the piston bore and out the holes to the atmosphere. The spring was the only thing holding the boost. I am going to see if I can get a replacment or mod my stock one. TBC...
#7 | |
Member#: 49461
NESIC
Vehicle:2003 350Z Touring Redline Red |
![]() Quote:
PM me if you want it. Erik |
#8 |
Member#: 64581
NWIC
![]() nah...Still doesn't solve the issue of the air leaking...just a stop-gap around the real issue. Might look into the APS BOV or another WORX altogether....
Reporting Live from Hawaii....... Anyone want anything!?!?! |
#9 |
Member#: 40328
South East
Vehicle:2004 WRX STi BSP #728 |
![]() dump the WORX bov. go back to stock valve. You should be able to hold boost again.
#10 |
Member#: 64581
NWIC
![]() What about the stock valve mod?
#11 | |
Member#: 40328
South East
![]() Quote:
it works well. put it in a vice and crush the cap a few mm. |
#12 |
Member#: 64581
NWIC
![]() What does that do?
Boost pressure starting at -20 psi, peaking at 5 psi...whats wrong? | prophet03 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 8 | 01-21-2010 07:26 PM |
P&L won't tune over 20 psi?? | jason miller | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 40 | 03-01-2009 10:18 AM |
no boost over .5 bar | blkrex04 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 05-22-2006 09:57 PM |
STI.. AVO450...no boost over 6k | GRoceryTurbo | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 46 | 04-06-2005 10:33 AM |
Did an up-pipe, now no boost over 15lbs. | drunkguy | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 9 | 07-03-2004 08:01 PM |
