#1 |
Member#: 3550
Vehicle:2002 WRX Wagon Blue |
![]() I have had some odd behavior lately. A few days ago, I was merging on the highway from a dead stop, and did a full throttle run through the gears to get up to speed. In 1st gear, I saw the peak light on the Defi gauge light up, and the needle was WAY past 15 psi. So I short shifted, and again put it to the floor. Same thing happens, except I notice the gauge is reading 20 psi! I grabbed another shift, and stayed out of the boost the rest of the day.
The next day, I was making normal boost ~14psi. Today, I can't make any more than 10 psi. This is with the stock boost controller. The only thing I've ever done to the motor is install the Defi gauges (which have been working for abou 6 months), and the silencer removal. Any ideas as to what the problem is? I'm thinking I'll probably bring it in to Subaru to check it out. Thanks. Eric
#2 |
Member#: 6049
Vehicle:02 WRX & 99 RS Black |
![]() just check your lines where you tapped the sensor. Same thing happend to me about a month after install. One of the lines had worked its way a bit off the T. Tied it down...everything has been good since...
If its not that ... Do you notice a pull difference ... cause you would really notice the difference between 10 and 20 psi ![]() |
#3 |
Member#: 3550
![]() Thanks, I'll check.
With 10 psi, I definitely notice it's slower than normal. 20 psi came up so fast, it's hard to say if it was pulling harder, as I got off the gas fast when I saw it peak that high. Eric |
#4 |
Member#: 13408
Vehicle:2008 LGT black |
![]() You said in your post that for a day you were getting 14 psi normal boost...isn't that more boost than from factory ?
#5 | |
Member#: 15917
Vehicle:2002 teh FastAR rex Black like my soul |
![]() 10 psi? Start your engine up and look for leaks. I had my pressure sensor detach once from the manifold and I only had 10 psi. I opened the hood and I could hear air being sucked into the manifold by the engine. Under boost air would be leaking out because the pressure would be higher in the manifold than 1 atmosphere.
STI+vf22 on stock boost control. What kind of gais we talkin here?? | Davenow | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 14 | 08-04-2004 08:49 PM |
overboosting w/factory boost controler | Jaxx | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 6 | 11-04-2002 07:36 PM |
Going catless on stock boost control = boost spike? | mrtrex | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 7 | 09-15-2002 01:06 AM |
Larger turbo on stock boost control...your results? | Red Rocket | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 08-15-2002 08:38 PM |
Defi Boost Gauge @ 14 PSI Peak? W/O Boost controller... | STi_Pete | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 03-03-2002 09:30 PM |
