09-24-2021, 08:39 AM | #1 |
Vendor Sales Rating: (43)
Member#: 198281
MAIC
Vehicle:2005 WRX/STi WRB of course |
FS: Fake 2007 Forester STi
We all know you can't get a Forester STi here in the US, but what if you put EVERY known Forester STi part on a USDM car. Would that count? Not really, but it still has all the proper feels
Solid car with a lot put into the STi conversion. The chassis does have 135K miles so it is not perfect. Original paint, but no Rust! There are many imperfections as you would expect with a car that has 135K miles, but you have to be close to see. I have documented every ding, scuff and scratch. So please feel free to reach out to me if you are a serious buyer. Dates, unless otherwise stated as NEW, are the installed dates. More pictures available upon request. 2007 Forester STi JDM Conversion, Upgrade, andNew Parts List: Engine: Precisionengine machining and assembly performed by AR Fab Installed 5/2020 all NEW Parts - New 705 cast block. - CNC Bore/Hone with torque plates. - CNC Vertical Line bore with torque plates. - Balance rotating assembly. - Polished crankshaft: OEM/Modern Salt Bath Nitrided.(Black in color) - Blueprinted engine. - 10MM oil pump. - ARP case bolts. - ARP2000 head studs. - Pistons- JE Perfect coated pistons. - Rods- Manley H-tuff. - Connecting rod and main bearings- ACL w/Coating. Reconditioned cylinder heads: - Valves-GSC intake and exhaust. - Bronze valve guides. - Springs/retainers- GSC beehive springs, Ti retainers. - Camshafts- OEM STI Single AVCS. New cam phasers andAVCS solenoids. - 6/2020New oem 07 FXT engine harness. - 5/2020 New A/F ratio sensor. - 6/2020 New oem WGDC Solenoid. (wastegate duty cycle) - 6/2020 New oem MAF sensor. (mass air flow) - 6/2020 New oem CKP sensor. (crankshaft position) Oiling: 9/2019 OEM STi water pump and oil cooler system. 9/2019 Killer B Motorsport 2.5L Cast Oil pan, Pickup and Bafflecombination. Killer B Motorsport M20 to 1/8" NPT adaptor. ½" NPT Fumoto Drain valve. 9/2019 Killer B Motorsport Air/Oil Separator with Cold Weather Package. Cooling: 9/2019 Killer B Motorsport Upper Turbo Coolant Reservoir V2. 9/2019 Get-A-Dom-Tune- Cylinder 4 Combustion chamber mod. Elec./ECU: 9/2019 Cobb Accessport V3. 7/2020 BrenTuning Flex fuel tune. 9/2020 Engine block heater for cold weather. 3/2020 New 12volt battery. Exhaust: 9/2019 Killer B Motorsport 4-1 Holy Header & up-pipe combo. 9/2019 JDM Forester STi SG single cat downpipe. 9/2019 Reworked TurboXS catback, with Helmholtz tube for sound resonance. Fuel system: 5/2020 ID1000 injectors- top feed w/ oem TGVs 10/2019 Cobb Tuning Flex fuel kit. 2/2020 Fuel tank- New rollover/emissions check valves and gaskets (3 total). 2/2020 New oem fuel tank pressure sensor. 5/2020 Fuel pump- AEM 15-1200 340 LPH E85 compatible. 6/2020 New oem fuel pressure regulator. 10/2019 Intake manifold vacuum reference for FPR- CENTER. Turbocharger: 6/2020 New MY 2019 VF48 Intercooler: 9/2019 JDM Forester STi SG top mount. 4/2020 HPS 2" 45 degree elbow coupler. JDM Forester STi BPV. Interior: 11/2019 JDM Forester STi SG front seats, both with height adjustment. *USDM Driver's seat base and rails. (LEFT) *UDSM STi seatback frame and airbag module. *JDM/RHD Driver's seat base and rails. (RIGHT) *USDM STi seatback frame and airbag module. Oem seat heaters no longer equipped. AIRBAG system fully operational. 9/2019 JDM Forester STi SG rear seats with seat bottom sliders (recline). 9/2019 JDM Forester STi Sill Covers (factory plastic protective cover still in place) · Drive side Sill Cover includes JDM factory Optional Flare 10/2019 2005-2007 USDM GD STi steering wheel. 1/2020 New OEM headliner. 1/2019 New OEM sunroof. 1/2019 All driver/ passenger window & door seals replaced. 1/2019 Both front ¼ window gussets replaced. 8/2020 New A-pillar trim- L & R. 8/2020 New 2007 Forester XT Sport front outer seatbelts. 8/2020 2007 Impreza STi 6MT shifter boot, bezel ring, hardware. Steering: 10/2019 New 2004 USDM Impreza STi steering rack 10/2019 New 2004 USDM Impreza STi steering universal (knuckle) [Not equipped with a rag joint]. Suspension: 7/2020 New JDM Forester STi SG Inverted struts, top hats, coil springs, 4wheel alignment. 9/2019 2004 Impreza STi 19mm rear sway bar/sway bar bushings/end links, and sway bar mounting brackets. Driveline: 9/2019 Forester STi Front and rear crossmembers. 9/2019 Forester STi 6MT transmission (TY856WL4CC 3.90:1FD) and propeller shaft AKA driveshaft. · AP Suretrac Front diff. · Viscous couplerAKA center differential. · AP Suretrac R180 Rear Differential (3.90:1FD). 9/2019 OEM STi release bearing/flywheel. (and pilot bearing) 8/2020 South Bend Stage 2 disc and pressure plate. (not installed) 9/2019 Forester STi SG 5X100 hubs and axles 9/2019 Forester STi SG JDM/OEM short shifter. 3/2020 Beatrush driveshaft center support bushings. 9/2019 Group-N Engine mounts. 9/2019 Group-N 6MT transmission mount. 10/2019 Cobb Tuning Pitch mount. 9/2019 Braided/stainless clutch line. Brakes: 9/2019 Goodridge stainless brake lines- All. 9/2019 Forester STi SG Front/rear 4pot/2pot Brembo. 8/2020 New 04 Impreza STi OEM brake rotors/ Hawk Street 5.0 pads- All. Exterior: 9/2019 JDM Forester STi SG9 HID headlights. LED marker bulbs. 9/2019 One-off/custom made HID leveling harness, HID leveling switch TBD. 10/2019 JDM Forester STi SG9 Taillights, black housing, LED reverse lights. 10/2019 JDM Forester STi SG9 front bumper with OEM STi lip. 11/2019 JDM Forester STi SG9 rear bumper. 11/2019 JDM Forester STi SG9 side skirts (rocker panels) with spats. 1/2020 JDM Forester STi SG9 rear gate with STi spoiler. 9/2019 JDM Forester STi SG9 hood. 3/2020 ProDrive P1 18" Gold Wheels (professionally refurbished) 3/2020 ContinentalExtremeContact DWS-06 225/45/18. All SPARES I have go with the car; shipped at buyers expense. This includes the original XT Sport fenders, front bumper, hood, hatch, front bumper, Side skirts, original XT long block (in good working order), and what's left of the JDM Front Clip. PM me for more details or pics...
__________________
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. vs. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
11-04-2021, 01:43 PM | #5 |
Member#: 198281
MAIC
Sold!
__________________
