10-31-2020, 01:54 AM | #1 |
Member#: 451109
AZ: 2004 Subaru WRX Wagon
For sale is a 2004 Subaru WRX. This car is in meticulous condition for its age and its 215,000 miles. I am the fourth owner and majority of its life was spent in Minnesota. The chassis has no rust. Some of the suspension components have some surface rust such as the sway bars, struts, and some other suspension components. Very minimal interior and exterior wear and damage. It has a sleeper look to it on the outside but under the hood there's some noticeable differences. Mod list below. I have the Carfax. Im selling because I have fell into a new hobby with dirt bikes and don't need 3 cars as well.
Recent Maintenance The engine is not original. I do not know the mileage but it is a JDM 2.0. It was serviced and inspected by Reliable Subie Garage on 9.24.20. Engine was compression tested and one step colder plugs were installed. Compression Test Cylinder 1 - 125 psi Cylinder 2 - 125 psi Cylinder 3 - 128 psi Cylinder 4 - 125psi On 10.06.20 it was retuned by Snail Performance. It makes reliable power and dynamometer test came report showed a very linear torque curve. Maintence Alignment 10.16.20 Brand new A/C compressor. System was fine clutch just went out 10.16.20 New front brakes 10.15.20 Coolant flush 10.11.20 Oil change on 10.11.20 Tires have good tread but there is a little cracking from the sun. Mod list STI pink Injectors Stage 2 exedy clutch AEM intake Aftermarket top mount intercooler Mishimoto Radiator with hoses Full Turbo back Invidia exhaust Grim Speed Boost Controller Cobb V3 Accessport Short throw shifter STI lowering springs Sway bars and end links Located in Phoenix AZ Asking $8,500
11-06-2020, 10:31 AM | #3 |
Member#: 338863
Vehicle:PSM 05 WRX WGN 5MT 95 Caprice 6spd Track Rat |
Very nice! Very clean! Us northerners are super jealous of such a pristine shell, haha.
Made 307/260 on the dyno with just injectors/IC/tune??? |
11-06-2020, 12:39 PM | #4 |
Member#: 302236
Vehicle:2005 STi WRB - sold :( |
If it's a JDM EJ207 that's pretty much stock numbers. Very very clean wagon, would never think it had those kind of chassis miles.
