Welcome to the North American Subaru Impreza Owners Club Friday March 29, 2024
Go Back   NASIOC > NASIOC Subaru Models > 'Old School' Subaru Forum
Old 02-16-2020, 01:14 AM   #1
Toh79DL
Member#: 510928
1979 DL
Red
Default 1979 DL Swap EJ22T
So I have been working on this for a couple months now. I will do my best to keep it updated. I have a 1979 subaru wagon. I am putting a EJ22T from a 91 legacy with a 5speed into my wagon. Including full drive train. Its definitely a project. Here is a link to my photos. I will update them when I have more along with adding them to this post.
http://s38.photobucket.com/user/88ub...bile%20Uploads
Toh79DL is offline   Reply With Quote
Old 02-16-2020, 07:30 AM   #2
D-Rodman
Member#: 110078
02 Bugeye JDM STi
OBP BLACK
Subscribed
Old 02-17-2020, 01:53 PM   #3
car_freak85
Member#: 13530
EA63 , EA81T, EJ20G,
EJ205
Very cool! I've got a '75 4WD wagon that I plan to swap a 12A into, so I'm interested to see what you've got planned!
car_freak85 is offline   Reply With Quote
Old 02-17-2020, 10:40 PM   #4
Toh79DL
Member#: 510928
1979 DL
Red
Working on the cross member right now. The left one is from the 79 and the right is out of the 91 legacy donor car. I am hoping to shorten the 91 x-member so I can use the power steering and then the mounting locations for the A arm's. If not the 79 x-member will need to be notched and re strengthened so the up pipe will be able to fit.
Old 04-03-2020, 10:49 PM   #5
Toh79DL
Member#: 510928
1979 DL
Red
Default Custom X-member done.
Finally got my cross member back. Its started as a 91 legacy turbo cross member and was shortened to fit into the 78 frame rails. About 1 3/4 inches needed to be cut off of each side. Using the 91 legacy cross member will allow me to use the 91 suspension and the power stearing from the 91. I am able to use the stick motor mounts from the 91 also. It's a snug fit. But it doens fit. I'm going to have to notch the frame rails a tiny bit so the valve cover bolt doesnt sit on it. If anyone needs measurements or help. I would be happy to help. This project has been a handfull to say the least.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 04-07-2020, 02:19 PM   #6
car_freak85
Member#: 13530
EJ205
The folks over at www.ultimatesubaru.org/forum would eat this up!
Old 04-24-2020, 07:50 PM   #7
Toh79DL
Member#: 510928
1979 DL
Red
I've tried logging into my account there. But it's not letting me. Even changed the password and still says incorrect password. also every time I try to explain to someone what I'm doing they just look at me like I'm crazy. So idk. Lol. I'll just document what I'm doing here and hope I can get this finished sometime soon. Being stuck at home cause of covid does help though. Haha.
Old 04-24-2020, 07:52 PM   #8
Toh79DL
Member#: 510928
1979 DL
Red
Finally got the frame rails notched and welded back together. Pretty much my first weld job ever. It's not perfect but it should work. Next up Is to pull the transmission from donor car and fit into this one. Also I have alot of 75-79 parts if anyone is looking for anything within those years.
Old 07-08-2020, 11:17 AM   #9
TurboneX
Member#: 21676
RX 03Foz89RX85Brat
RedBlackBlue
Following...
Send me your log in info and user name for USMB, I'll see if I can get your account fixed (I'm a mod there)
TurboneX is offline   Reply With Quote
