03-04-2003, 01:26 PM | #1 |
Member#: 15854
Vehicle:2002 WRX VF34'd... |
WRX's most common problem .... way to remedy it?
Hesitation, jerky motion.... most noticeably in low gears.... what can be done to remedy WRX's most common/major problem beside ECU reset, ground mod, which seem to work only temporarily. Can WRX be driven as smooth as let's say Acura CL-S 6sp?
03-04-2003, 01:34 PM | #2 |
Member#: 15459
Vehicle:CRG w/ KX125, pmp'd |
vishnu ( or your favorite tuner ) REFLASH!
03-04-2003, 01:43 PM | #3 |
Member#: 15854
any other way? something inexpensive?
03-04-2003, 01:51 PM | #4 |
Member#: 25038
Vehicle:2002 PSM WRX sedan |
$750 for 40hp and new found smoothness doesn't really seem expensive. But, I know what you mean.
03-04-2003, 01:54 PM | #5 |
Member#: 15854
that's after core exchange I will buy it for $750 though....
03-04-2003, 01:55 PM | #6 |
Member#: 15106
ive read in the past that the catless uppipes provide smoother
response. but this is just hearsay. |
03-04-2003, 02:33 PM | #7 |
Member#: 24621
Vehicle:2006 Legacy GT 2015 WRX STi |
My car runs smoother than ever now that there are no cats. An uppipe was the first thing I installed in my car and it seemed to have smoothed things out a bit on my mostly stock car. Maybe you should try a different brand of gas. I use Sunoco 94. Hope this helps
03-04-2003, 03:16 PM | #8 |
Member#: 13634
NESIC
Vehicle:2002 WRX WRB |
looking at your specs in your sig, an uppipe will help you out in terms of driveability. you using an mbc? a better boost controller would help also - but might as well go with engine management because it's really not that much more
03-04-2003, 03:30 PM | #9 |
Member#: 16879
SCIC
if the MBC/EBC is causing the problem, i would recommend the Vishnu EMI adapter. it smoothed out the low rpm lean condition "jerkiness" for me. also, if you are running higher than stock boost, a catless uppipe is always a good idea.
03-04-2003, 06:44 PM | #10 |
Member#: 27335
Vehicle:2005 Forrester XT OBS |
IIRC, I've heard lightened crank pulley's also help the jerkiness. Pls correct me if I'm wrong.
03-04-2003, 10:38 PM | #11 |
Member#: 22290
TXIC
Vehicle:2002 STI Ver 9 Spec C Wagon |
I usually notice jerkyness when the car isn't warmed. The only other times I get it is in the 60% throttle changeover from ECU to UTEC operation. In some situations when I'm trying to smoothly apply throttle and gradually increasing application it will make the changeover abruptly and kinda jerks the car. -Bolster
03-04-2003, 10:46 PM | #12 | |
Member#: 13634
NESIC
03-04-2003, 11:29 PM | #13 |
Member#: 9827
Vehicle:2002 WRX Wgn 292whp Alex Performance |
STI tranny and motor mounts make the jerkiness much less. Because there is much less slop, the engine torque gets transfered into forward motion much more efficiently instead of engine slopping to a stop and then the car moving.
Alex... |
03-04-2003, 11:31 PM | #14 |
Member#: 15667
RMIC
Vehicle:2004 STi Alpine White |
I have an ECUTek reflash, an up-pipe and a pulley. I still get a "jerking motion."
Maybe it's just part of the character of the car, one of the comprimises that we make for this level of performance at $25K. Just a guess... |
03-04-2003, 11:40 PM | #15 |
Member#: 15854
I also have a jerkiness in 1st and 2nd gear with lightened crank pulley. Anyone out there with a WRX that drives as smooth as let's say Lexus ES300?
03-05-2003, 12:29 AM | #16 |
Member#: 19776
VIC
Vehicle:2012 GVF SWP Ninja Lime Green |
the jerkyness is cool!!
nah...j/k...it pisses me off sometime and especially when there are passengers on my car...haha...they would think i can't drive.. |
03-05-2003, 01:21 AM | #17 |
Member#: 8221
NESIC
Vehicle:2018 Tesla Model 3 Midnight Silver Metallic |
Figured I add that I have the reflash as well and the jerkiness is still there... although not as bad as before when I had my unichip and avc-r controlling things.
03-05-2003, 09:19 AM | #18 | |
Member#: 10821
NESIC
Vehicle:2008 WRB STi |
IMO, another way to minimize the jerkiness is just use your gas pedal more gently... |
03-05-2003, 11:34 AM | #19 | |
Member#: 10972
South East
Vehicle:2004 STi (fuxor3d!!) 2004 Forester X |
werd! uppipe, downpipe, pulley, STi motor, tranny and pitch(useless) mounts. The mounts really make the car a pleasure to drive.
Common problems/what to look for when buying used | zyntax | Newbies & FAQs | 10 | 11-18-2008 05:32 PM |
what is the most cost effective way to advertize??? | azn2nr | Off-Topic | 56 | 01-26-2006 07:29 PM |
CEL: common problem due to snow? | Impreza01 | Warranty Issues & SOA Problems | 4 | 01-12-2005 09:28 AM |
most cost effective way to better ratios? | geronimo66 | Transmission (AT/MT) & Driveline | 8 | 05-07-2004 02:16 PM |
