#101 |
Member#: 110648
PRSIC
Vehicle:2005 Hydramist 35R82 93oct 479whp 456tq |
![]() Tap water is fine, but you must check the jets more often for minerals buildup. Thats why distilled water is preferred.
#102 |
Member#: 57871
NESIC
Vehicle:2004 WRX 13.4 @ 102 |
![]() Thanks for the feedback guys...yea, I'll def. be using distilled water to be safer.
#103 |
Member#: 101607
South East
Vehicle:06 Subaru STi Aspen White |
![]() How about more info running Meth vs Denatured Alcohol.
Meth is harder to find. Meth is cheaper. Meth has a higher octane rating. Where as Denatured Alcohol not as corrosive as Meth. Denatured Alcohol could be found more locally like at a hardware store. It is also found to be more expansive. please, anyone, correct me if im wrong on any of this. also add any other info that is missing or useful. |
#104 |
Member#: 47145
Vehicle:2012 Gas Saver |
#105 |
Member#: 141994
Vehicle:06 STi obp |
![]() wow i just installed my perrin progressive system this helped alot... is it ok to run a product called heat? its a 90% methanol and 10% alci mixture no water?
#106 |
Member#: 141994
![]() yea heet thats it .. is it ok to run just heet or do i need to add water to the mix?
#107 |
Member#: 47145
#108 |
Member#: 57871
NESIC
![]() ^^^seems like that would get quite expensive....isn't heet like $2-3 per small bottle??
#109 |
Member#: 47145
#110 |
Member#: 90354
International
Vehicle:2018 STI WRBP |
![]() I really recommend www.alkycontrol.com custom made kits and Julio is great to deal with. Had mine installed by him last year when I had the STi and getting it done on my Cobra soon.
#111 |
Member#: 78022
NWIC
Vehicle:PdxT built 2.5L 6sp 30R.82, 274/276, H2O+meth |
#112 | ||
Member#: 8512
South East
Vehicle:2002 WRX chassis... stage-infinity.com |
![]() Quote:
With all due respect, I recommend leaving the answer generic instead of providing misinformation: Quote:
#113 |
Member#: 81352
Vehicle:2003 '03 EJ257 wagon Green |
![]() jblaine - So from what I gather from what you're saying, water injection by itself without methanol works too.
#114 |
Member#: 8512
South East
![]() It most certainly does.
#115 |
Member#: 48831
SWIC
Vehicle:2002 Protuned Wagon Bugeyes Forever |
#116 |
Member#: 139485
Vehicle:2004 16g WRX DomTune Java Black Pearl |
![]() Denatured alcohol is NOT methanol, it's ethanol that has been denatured with things such as Bitrex and Methanol.
Isopropyl IS NOT methanol. I would be careful just dumping anything labeled "alcohol" into my injection system. |
#117 |
RIP 3/18/1965 to 1/10/2008
Scooby Specialist Member#: 91500
Vehicle:hmmm sr-30+640cc=? I has teh Endless BBK. |
![]() noOb to this conversation, but with a gt/30-sized snail in the garage, this is looking good. *subscribed*
#118 | |
Member#: 18987
NESIC
Vehicle:2014 Forester Dark Grey Metallic |
![]() Quote:
DP |
#119 | |
Member#: 102013
Vehicle:2002 WRX |
![]() Quote:
OK I see he is talking about the Actual AFR ratio not fuel map values.... In Speed Density using the UTEC I use 0's for values for my modded stock 850 cc injectors in my fuel map to get a slightly rich base map to start tuning with a 650/420 settings in parameters for injector size....... What would be my new starting point using injection? How much fuel must be pulled? Any Ideas? Last edited by plus plus plus; 05-14-2007 at 10:15 PM. |
#120 |
Member#: 143372
Vehicle:Many All Different The rainbow |
![]() For all you users of spray (nitrous) users, if you run water/alky injection you won't need to retard your timing as much and you'll have much cooler combustion chamber temps. It makes spraying much safer. I swear by it.
#121 |
Member#: 23676
NESIC
Vehicle:. |
![]() denatured alk works 100***37; fine and is no worse for your car/system than methanol is.
You dont get the same effect that you would on meth, however the difference is pretty small and denatured will still yeild huge gains. I ran 50/50 distilled water/denatured alk in my alk cars (and will be doing the same again in this one once I hook it up) and it was awesome. 4+ degrees of timing, 12.5-1 a/f and 23lbs of boost on the stock STI turbo. no knock, ever. |
#122 |
Member#: 45173
Vehicle:1999 2.5 RS White&Gold All-Suspension |
![]() You only lean the AFR out with between 100***37; water and about 70% water, 30% meth. With pure meth you run MUCH richer.
Stoich on gasoline = 1 Lambda = 14.65:1 AFR Peak power on gasoline "near" 11:1 AFR = 0.75 Lambda Stoich on methanol = 1 lambda = 6.47:1 (yes six and half) Peak power on methanol = 0.8 lambda = 5.2:1 AFR (yes, vehicles that run straight methanol run in the FIVE to ONE Air to Fuel Ratio at WOT) So adding 100% methanol to gasoline = moving from 11:1 AFR toward 5.2:1 AFR = getting richer. With more than 30% water, the water is absorbing so much energy that you have to lean it out to make power... with more/straight meth, you actually run richer than you did on pump gasoline. (flame suit on) SS |
#123 | |
Member#: 47145
![]() Quote:
#124 |
Member#: 45173
![]() The World's Fastest Stock Block Stock Tranny EJ205 WRX runs 10.2 to 10.4 AFR on an Innovate Wideband... Granted that's near 0.5 AFR richer than other wideband's might show, but it's still sub 11.0... At 10.5 AFR it pings...
SS |
#125 | |
Member#: 8512
South East
![]() Quote:
We've all heard it before: Every single car has a single unique tune best suited for it. At any rate, a 50/50 mix injected at a 1:5 water+meth:gas ratio (20% as typical) has a whopping 10% meth combusted. Given straight water tunes that run fine at 12.5:1 (with no power gained by richening, BTW), it's damn safe to play around 11.5:1 with a 50/50 mix at 20% spray. |
water / methanol injection kit -new or used | blazin sti | Private 'Wanted' Classifieds | 3 | 05-27-2006 08:01 PM |
Water/Methanol Injection or Race Fuel or Both | ejh25 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 7 | 03-28-2005 06:35 PM |
Derek Devises Water/Methanol Injection | mistaboosta | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 11-01-2004 05:52 PM |
Derek Devises Water/Methanol Injection | mistaboosta | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 0 | 11-01-2004 04:51 PM |
