Welcome to the North American Subaru Impreza Owners Club Friday March 24, 2023
Old 09-16-2003, 01:47 PM   #1
RafalW
Member#: 8193
2008 WRX STI
Lightbulb Strange noises from brakes explained.
After my first track day I started to hear strange noises from my brakes. When I was cruising they were making a noise and it was stopping when I pressed the pedal down a little.
Finally last weekend my brake pads were changed (with some help from two NASIOC members ) and the mistery was explained. The leftovers of brake material was separated from pads metal backplate on all four front pads. So when I did not apply brakes they were loose and touching my rotors making strange sound. The reason? Probably they overheated on the track.
RafalW is offline   Reply With Quote
Old 09-16-2003, 04:08 PM   #2
Mister2cool
Member#: 24261
2004 WRX STi
Alpine White
Default geezzz
How long did the pads last?
Mister2cool is offline   Reply With Quote
Old 09-16-2003, 04:34 PM   #3
WRX 2002
Member#: 11211
2004 STi
Rally Blue
Pictures...?.
WRX 2002 is offline   Reply With Quote
Old 09-16-2003, 04:35 PM   #4
kb3drfsti
Member#: 41507
2004 sti
blue
I find this interesting,a have a couple questions.
1How many miles on the brakes.
2How hard were you running the brakes at the track,was it a break demanding track.
3 Was there still meat left on the pad and just figured to replace since they were off.
4How did the rotors look after that kind of heat up.
5,Finally,What pads did use for replacement
and were they a bitch to do.I always do my own brakes and was wondering about takling
those Brembo's,never did brakes like these before.Also did you break in your brakes before you got to the track.Thanks Matt!
ps could you just replace the metal backs or are they part of the pads?
kb3drfsti is offline   Reply With Quote
Old 09-16-2003, 06:48 PM   #5
RafalW
Member#: 8193
2008 WRX STI
Little over 5K when replaced.
Two drivers at Gingerman so every hour it was going 40 minutes. This track is quite hard on brakes cause they have no time to cool down.
Nope. After this I did some more track days. Replaced cause they were almost gone.
Good. Rotors are in a really good shape.
5,Finally,What pads did use for replacement and were they a bitch to do.
I used Ferodo DS2500. They look good so far. I think better then previous ones. But I need to go to the track to judge better. My friend was doing the swap itself and he had a small problem with one caliper (i did not go back) but he figured it out and everything was actually nice and smooth IMO.
I always do my own brakes and was wondering about takling those Brembo's,never did brakes like these before.Also did you break in your brakes before you got to the track.
I did. These Brembos are easier then WRX brakes.
Do you mean metal platesbehind pads? We kept them.
I can not imagine you could talk about metal backplates cause these are part of every pad.
Old 09-16-2003, 08:28 PM   #6
RafalW
Member#: 8193
2008 WRX STI
Originally posted by WRX 2002
Pictures...?.
I did not take any.
Old 09-17-2003, 11:48 AM   #7
STI_FFY
Member#: 37519
2004 STi JBP/Gold
Helix DP, SMC, Cobb AP
Default Dust??
Have you had time to assess the dust situation yet? Any more or less than stock?
STI_FFY is offline   Reply With Quote
Old 09-17-2003, 04:59 PM   #8
RafalW
Member#: 8193
2008 WRX STI
Default Re: Dust??
For now I think there is less dust on wheels. But I worked late and it was dark so I am not completely sure how much less.
Strange noise on braking from 7-8Mph and lower dexterous Brakes, Steering & Suspension 6 12-01-2007 10:52 PM
Strange BOV behaviors and strange noises from turbo tr3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-09-2004 07:06 AM
Strange noises from rear brakes Diversion Brakes, Steering & Suspension 3 11-25-2003 02:01 AM
Strange noise from engine compartment. JB Normally Aspirated Powertrain 3 04-05-2001 06:35 AM
Strange noise from clutch pedal 555wagon Normally Aspirated Powertrain 7 02-21-2001 12:45 AM
