#1 |
Member#: 31986
Vehicle:2004 wrx sti wrb |
![]() iam always drooling over aps stuff and just noticed this cant wait to see the rest. it seems to me that everybody else is slacking on the sti vishnu is slow godspeed is the only one i have heard about and thats going slow too whats going on ? pruven performance has 11.6 evo wheres the sti ?
http://www.airpowersystems.com.au/us...i/2004_sti.htm
#2 |
Member#: 152
Vehicle:2002 Impreza WRX WRB |
![]() Give them time; the major hump is that the STi's ECU is totally different from that of the WRX and is giving tuners major headaches in cracking/understanding it.
#3 |
Member#: 13095
![]() Interesting, this is the first engine dyno I've seen for the STI, or is it just a software based estimate?
They also dynoed the Evo which makes for interesting comparo. http://www.airpowersystems.com.au/us_spec/evo/evo.htm Doesn't say at what Octane level though. Last edited by strangerq; 09-16-2003 at 11:01 AM. |
#4 |
Member#: 717
NESIC
![]() It says the STi was running 94 octane.
#5 |
Member#: 34997
Vehicle:99 Miata 10AE |
![]() Below the STi chart it says they used the equivalent of 94 octane.
Glad I'm not paying $2 a gallon for nothing! ![]() |
#6 | |
Member#: 26361
TXIC
Vehicle:My shenanigans are cheeky and fun |
![]() Quote:
Im sure that if the evo had debuted at the same time as the sti with a brand new engine both cars would be in this learning stage that the sti is in. |
#7 | |
Member#: 2997
![]() Quote:
#8 |
Member#: 15953
TXIC
Vehicle:04 Impreza WRX STI Aspen White/Gold w/Stg2 |
![]() Vishnu and Godspeed have both hit 300whp with the research, testing and development. OK this isn't stock but both did it with very little in upgrades.
#9 | |
Member#: 13095
![]() Quote:
Also...my question about octane pertained to the Evo. I saw where it said 94 octane for the STI. It's not clear to me how crank HP is derived here, but still....it is fairly impressive. |
#10 | |
Member#: 4764
TXIC
Vehicle:2004 STi sold :( forizzle |
![]() Quote:
#11 |
Member#: 2997
![]() ![]() They state: "APS has imported a left hand drive North American Lancer Evolution to Australia for product development". They did not import a seperate motor for testing. Also, under description, for the Sti it lists the motor "US25", for the Evo it lists the car "Evo8" (not 4g63 or US20). |
#12 |
Member#: 38898
TXIC
![]() That could be adjusted crank horsepower for the EVO considering Mitsubishi claims 274 bhp. Also, it has been stated that the USDM STi could be producing more horspower than claimed at the crank because of the high numbers (at the wheels) that certain tuners have achieved on their dynos. I just think it is great that they imported both the car and the engine to develop products for the US.
#13 | |
Member#: 13095
![]() Quote:
The STI chart says it is a dyno dynamics dyno in shootout mode. I believe that is a software mode designed to derive crank hp from wheel hp. quote: "APS has fully imported a US specification STI and complete engine for engineering and development purposes." That doesn't answer the question about how the crank figure was derived; from an engine dyno, or a wheel dyno in shootout mode. That's why I asked. Also....your statement that the Evo is wheel horsepower is also fuzzy to say the least. The Evo dyno also says....shootout mode. Read the graph in the upper left it says S_HP. That's shootout horsepower which = estimated crank horsepower...not wheel horsepower. Frankly: it looks like both cars were subjected to similar if not identical testing procedures. Could be wrong though...if so, feel free to clarify. Last edited by strangerq; 09-16-2003 at 03:07 PM. |
#14 |
Member#: 3767
SCIC
Vehicle:2015 WRX Limited WR Blue |
![]() There's no reason why APS would or should use two different methods to get dyno numbers for the STi or EVO. Seems pretty obvious to me...
#15 | |
Member#: 2997
![]() Quote:
The Evo shootout power was derived and shown as whp and the Sti shootout hp was shown as crank. That's all. APS is being contacted though to get more info and clarify a few things ![]() Whp for an Evo on a Dyno Dynamics dyno isn't that high, I've typically seen around 240awhp. BUT, I think the Evo chart shown was an Evo with pre-production Unichip (tweaked a/f ratio). |
#16 | |
Member#: 8351
Vehicle:2002 WRX Wagon |
![]() Quote:
Also, I doubt your last statement since it says "Power and Turbo Boost Pressure of the stock Mitsubishi Lancer Evolution." right under the graph. A unichiped Evo is not a stock one. APS puts "Unichip" in the customer block in a lot of their web dyno sheets. TRS |
#17 | |
Member#: 8351
![]() Quote:
For example, if I had a DD dyno at my house (9200ft) and you didn't use any correction factors, I'm pretty sure my readings will always be lower than someone at sea level...makes it hard to compare to any DD dyno in the world. TRS |
#18 | |
Member#: 13095
![]() Quote:
"For those who want to know the facts, Shootout mode is a Dyno Dynamics software feature that estimates flywheel horsepower. That's what the S_HP stands for... Shooutout HP. It basically multiplies actual wheel hp by some predetermined driveline loss factor (1.3-1.4, depending on car and output). While there is some science to it (DD does a lot of engine and chassis dyno testing), it's still an estimate. "cheers, Shiv. http://forums.evolutionm.net/showthr...eel+horsepower |
#19 |
Member#: 2997
![]() Shiv was incorrect. Here is a note direct from Dyno Dynamics.
Here's an email I got from Dyno Dynamics this morning: --------------------------- Dear Shiv, Steve passed on the link to the EVO forum which I read with interest. First of all ShootOut mode is not just for flywheel power calculation. Although it does a super job of that. Much better than Coast Down. The prime objective of ShootOut is to create uniformity of readings from all DD dynos. This is done by causing uniformity of dyno settings (this is done by the software selecting the most appropriate drivetrain inertia and ramp rate for the class of vehicle being tested). The rest is acheived by training our customers (eg. you) in the correct methods of tie down, tire pressure, fan positioning, good ventilation neccesities etc, the list goes on. If you set up the car and the dyno the same and the car is repeatable, the readings will be repeatable, world wide! One of the members doubted the reality of our readings, because our atmospherics are entered manually. That is why ShootOut prints these manual inputs on the dyno graph. If the operator enters figures that are "slightly" inaccurate, the power variations will be extremely minimal. If howeverthe operator inputs unrealistic figures large enough to significantly effect the power readings, then this will be obvious to anyone who studies the graph. The principal of ShootOut is to ensure that there is no difference between your dyno, Dyno-Comps dyno, Axis's dyno, or any other Dyno Dynamics dyno run correctly in ShootOut mode. There will always be some small variations in readings because of the difference in locations therfore conditions that can effect the way the engine management system behaves and it turn the turbocharger system behaves (their behaviour is inherintly linked). No dyno can automatically compensate for this. |
#20 |
Member#: 13095
![]() It would be interesting to read Shiv's reply, although I'm not sure if anything said in the DD response actually contradicts him. It almost sounds like DD is dissembling. Whatever other value it does/does not have it seems clear that shootout mode is being used to estimate flywheel horsepower. It's whp multiplied by some factor. DD didn't deny that at any point in their reply.
#21 |
Member#: 2997
![]() You can get flywheel hp with or without shootout mode. It is just a simple calculation that they use to estimate it. This quote says it: "First of all ShootOut mode is not just for flywheel power calculation. Although it does a super job of that. Much better than Coast Down."
They are telling Shiv that shootout mode is simply a different mode and it was inaccurate to say it was a mode that gives flywheel hp. Shiv said himself that he hadn't used the software...I'm sure Dyno Dynamics knows best ![]() |
#22 | ||
Member#: 13095
![]() Quote:
His point was that if you take the 185-190 whp that he has measured on several Evo's and multiply it by 1.4 -> you get 265 S_hp. And low and behold if you take the 220+ whp that he has measured for some STI's and do the same, there's your 311 hp. Quote:
![]() Are you saying that the STI was dynoed on an engine dyno, whereas the Evo was dynoed on an awd wheel dyno? Does Dyno Dynamics even make an engine dyno? Last edited by strangerq; 09-16-2003 at 05:06 PM. |
#23 | |
Member#: 2997
![]() Quote:
![]() Think about it a little. I'm done debating though ![]() ![]() |
#24 |
Member#: 8351
![]() http://www.vishnutuning.com/lancer.htm
and "Using Shootout Mode on our dyno, most EVOs are putting down 260-270 hp. And WRX are making 220-230 hp. So, it can be quite accurate. cheers, shiv" Looks like the shootout mode does what it was intended to do here, as Shiv's results match APS'. TRS |
#25 | |
Member#: 2997
![]() Quote:
![]() http://www.dyno.com.au/shootout.htm |
Which injectors needed for 500 hp at the crank. | AntonioS | Normally Aspirated with bolt-on Forced Induction Powertrain | 4 | 11-02-2003 02:59 PM |
Max HP at the wheels - Stock turbo? | robvas | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 5 | 10-14-2003 05:31 PM |
Looking for 200+hp at the crank... | Spenk | Normally Aspirated Powertrain | 7 | 07-07-2002 12:17 PM |
70 hp at the crank! | mcu81 | Proven Power Bragging | 7 | 07-01-2002 08:53 AM |
correction - its 390 hp at the crank ! | alfriedesq | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 68 | 10-31-2001 11:54 AM |
