Welcome to the North American Subaru Impreza Owners Club Friday March 24, 2023
Old 09-16-2003, 12:32 AM   #1
markpaco
Member#: 33743
2004 Impreza WRX STi
WRB/Silver
Default 2.5RS mudflap on STi (pics)
I installed my set of 2.5RS mudflaps after someone's post that said that you can do it. The modification needed to fit it was not as easy as I had thought but was able to get it to match up pretty well using a heat gun. If I didn't have the heat gun I would of been SOL. The rear bolts up fine. But because of the side sill the front mud guard obviously did not match up. And there is a gap inside the wheel well because of the side sill. The mud guard has drain holes but I could imagine mud and leaves getting jammed up in there over time. Here are some pics.
I just wish I had them a week ago! It is hard to see but the inner bumper cover is chewed up from gravel impacts.
markpaco is offline   Reply With Quote
Old 09-16-2003, 11:02 AM   #2
jagcars26
Member#: 2394
2005 Legacy GT wagon
2009 Forester X
Nice job,,,,That was my thread on the RS mudflaps.After i posted i realized it was a bit easier fr me with the fronts.Having a black car,although my trimming was not as exact as yours,,you dont notice any small gaps as much as you would on the other colors.
Still a good alternative flap that doesnt cost an arm and a leg and still protects the car some.
Rudy
jagcars26 is offline   Reply With Quote
Old 09-16-2003, 05:19 PM   #3
Mister Toro
Member#: 9792
04 Blackwing
Without the Wing
Part numbers, please?
Are you using the J1010FE230 that was used on the 02-03 RS? I would assume these are different because of the shape of the rear, but I can't find part numbers for the 04 RS.
Mister Toro is offline   Reply With Quote
Old 09-16-2003, 07:38 PM   #4
wgknestrick
Member#: 32576
04 STI
Nice pics. How about one that shows the whole car with the flaps, so we can see what they add (or detract) from the car.
wgknestrick is offline   Reply With Quote
Old 09-16-2003, 10:56 PM   #5
markpaco
Member#: 33743
WRB/Silver
The part number is J1010FE270 as posted by 'jagcars26'. $79.96 from www.allsubaru.com + $5 shipping.
Old 09-21-2003, 01:09 PM   #6
DrBiggly
Member#: 11482
02 WRX
Acute Stickeritis
Thumbs up
Looks good!
DrBiggly is offline   Reply With Quote
Old 09-24-2003, 12:23 AM   #7
nate49509
Member#: 22452
2018 STi
Has anyone seen the mudflaps for the Forester. It looks like they might fit the RS side skirts.
nate49509 is offline   Reply With Quote
Old 09-28-2003, 02:23 AM   #8
markpaco
Member#: 33743
WRB/Silver
The part I listed is supposedly for the 2.5RS
Old 10-19-2003, 11:46 PM   #9
markpaco
Member#: 33743
WRB/Silver
Here's a pic of the car with the mud flaps
Old 10-23-2003, 08:51 AM   #10
lupohki
Member#: 3457
2008 STi
I mistakenly ordered the 03 RS mud flaps. While you don't need to trim anything to have front or back be able to attach, neither side is flush, but I'll live with it.
lupohki is offline   Reply With Quote
Old 11-14-2003, 03:25 AM   #11
team23jordan
Member#: 48132
2011 STi
markpaco- hit me up on email ([email protected])
i wanna ask you some Qs where you got your STi from
and mudflaps
Did subaru made Mudflaps for 2004 impreza??
team23jordan is offline   Reply With Quote
Old 11-23-2003, 09:24 PM   #12
bleat
Member#: 48730
2005 WRX
and mudflaps
'04 outback sport has mudflaps.. but they are the 2nd tone color.. dunno if they would match a "normal" impreza
bleat is offline   Reply With Quote
Old 12-03-2003, 10:19 PM   #13
happysti
Member#: 49597
2004 STI
Default 2.5 RS splash guards on sti
I ordered a set of the 2.5 RS splash guards and was wondering what you did to get the front bottom side bolt installed. It is under the side sill, and the only way I can see to get the mudflap on is to cut the plastic body side sill to get at the bolt. Is that what you did? Or did you leave that bolt off?
I have the Subaru part number J1010FE230 version. Does anyone know what the difference is for the J1010FE270 stock number? Thanks for any additional info you may have on these installs.
happysti is offline   Reply With Quote
Old 12-04-2003, 08:48 AM   #14
markpaco
Member#: 33743
WRB/Silver
I cut a hole in the plastic side sill (body kit) but realized that the bolt was too short to go through both the plastic sill and mud flap and into the body. So I ran the bolt from the inside out such that you could see the end of the bolt stick out from the hole. I then put a nut and washer on it. Ideally, I would have gotten a longer bolt that would go throught the mud flap and plastic side sill
Old 06-17-2004, 07:34 PM   #15
skalarakis
Member#: 26434
2004 Imreza WRX STI
Hi
I got the same splashguards J1010FE270 from subaruparts.com and the sales person told me that I have use a heat knife to modify the front splashguard. I did not really understand how to modify them. Any instructions I will much appreciate.
skalarakis is offline   Reply With Quote
Old 06-17-2004, 09:47 PM   #16
skalarakis
Member#: 26434
2004 Imreza WRX STI
Hi
I got the same splashguards J1010FE270 from subaruparts.com and the sales person told me that I have to use a heat knife to modify the front splashguard. I did not really understand how to modify them. I will appreciate if you have any instructions. Thanks
Old 11-01-2007, 03:10 PM   #17
nexus sw21
Member#: 139711
2004 sti
psm
how come i cant see any pix.?
nexus sw21 is offline   Reply With Quote
Old 11-08-2007, 05:24 PM   #18
kimball
Member#: 144465
2004 STi
black
for my 2004 sti,i used the base sedan guards-use a stanley or exacto knife to trim the fronts to curve around the rockers(small gaps are unavoidable) and to trim off the plastic in front of the bottom bolt hole-it looks good and works well, esp with wide wheels/tires
kimball is offline   Reply With Quote
Old 11-29-2007, 07:52 PM   #19
|Disso|
Member#: 155515
OBP pignose
IG-KuostA
Because you bumped a damn thread from 2003.
|Disso| is offline   Reply With Quote
2000 2.5RS windows on a 06 STi? mxracer Newbies & FAQs 8 06-17-2006 03:20 AM
Tech article on my USDM 2.5RS -> JDM STi swap in HCI magazine Kotir Subaru Conversions 9 06-22-2005 03:05 PM
2.5rs heads on STI shortblock 2.5rsDOHC Normally Aspirated with bolt-on Forced Induction Powertrain 12 08-24-2004 02:35 AM
FS: 2.5RS mudflaps for STI vapore0n Private 'For Sale' Classifieds 6 07-20-2004 12:09 PM
99' 2.5rs spoiler on 02' 2.5rs ? 2.5MATEO Newbies & FAQs 3 09-03-2002 07:11 AM
