![]() Brakes & Suspension Forum sponsored by The Tire Rack |
#1 |
Member#: 16980
![]() Just noticed that when i take a corner "slightly faster than usual" and hit a bump or uneven surface during the turn... there is a weird noise and rattle that can be felt in the steering wheel. its hard to explain ...
this might sound funny ... but if you want to listen exactly to what it sounds like ... simply take a plastic ruller, leaving 3/4 of it on a desk, and slapping the 1/4 that isnt touching the desk. it sounds exactly like that ... any ideas on the cause of this ?? thanks
#2 |
Member#: 37962
Vehicle:2006 CGM STI 2000 Outback & 05 BMW M3 |
![]() ![]() Seriously though, I haven't noticed anything like this. I do notice when I'm going around a turn fast and hit a bump the front wheels will start to spin faster than the rears and the car feels a little jerky for a second until it evens out. I've found that different settings on the DCCD will alter that effect though. Are you talking about that? |
#3 |
Member#: 31948
Vehicle:2004 STi Aspen White |
![]() suretrac lsd?
#4 | |
Member#: 37962
![]() Quote:
#5 | |
Member#: 16980
![]() Quote:
i'll try taking a videoclip today to let you guys know what im talking about. i will also play around with the dccd to see if it changes something Last edited by Extraze; 09-14-2003 at 11:59 AM. |
#6 |
Member#: 40328
South East
Vehicle:2004 WRX STi BSP #728 |
![]() Same thing here! Only on uneven or rocky surfaces. It goes away right when things even out.
#7 |
Member#: 31948
![]() i ve never took it to a rocky surface.
been on some bad streets tho.. i immediately slowed down and didn't notice anything. only on 2 occasions where i was pulling into a parking area, the entrance had a very steep rise and followed by a ditch.. i heard noises coming out from the steering, but i assumed that was natural |
#8 |
Member#: 11316
Vehicle:1988 E30S52 DD S14VQ35 & S13KA racecarzz |
![]() I notice it all the time and actually posted about this in June.
Member Glenn Wallace mentioned that it was the suretrac making the noise. I question if it really is that. Sounds more like there's something loose. |
#9 |
Member#: 12455
Vehicle:02 WRX |
![]() My 02 WRX does this too. Rattling when turns on bumpy surface. I never found out why.
#10 | |
Member#: 16980
![]() Quote:
#11 |
Visiting NASIOC Timeout
Member#: 40648
Vehicle:2004 STi Blue, of course |
![]() I haven't noticed that, but I do get an annoying buzzing noise
sometimes while cruising. I found out that it was the cruise control lever, as when I touch it lightly the noise stops. Anyone else find this ? -Sporty |
#12 |
Member#: 29831
![]() I found the same thing with my STi, when taking a ramp with uneven surface, divider etc, I can hear a clunk and some disconnected feeling in stering wheel, don't know what it is thou
#13 |
Member#: 31556
Vehicle:2018 Type RA Black |
![]() I have the same clunk. It's not because of the mac strut is it?
#14 |
Member#: 1847
Vehicle:Team Broken: V6 GF rallyarmor.com |
![]() this is a common 'problem' accross the subaru line.
Jay |
#15 | |
Member#: 37678
SCIC
![]() Quote:
The sound is a loose rattle that transfers through the steering wheel: I can definately feel it. It is not brakes, it might be suspention, but I suspect steering. HELP! |
#16 |
Member#: 23341
Vehicle:04 Rex STi WRB/Gold |
![]() Ditto! I asked the question of others before without a good reason for it.
I still don't like it...but at least it isn't an isolated condition. |
#17 |
Member#: 29669
Vehicle:2004 Impreza WRX STi White |
![]() Are we talking about bump steer or just a noise?
#18 |
Member#: 37678
SCIC
![]() No, not bump steer. It doesn't pull the steering wheel, I just feel a rattle through the steering wheel like some suspension component is loose (kind of like if the tolerances were not to spec and there was unwanted movement between 2 parts).
#19 |
Member#: 29669
![]() Ohh ok, I'll have to play with that some.
#20 |
Member#: 47455
Vehicle:2004 WRX STi silver |
![]() Anybody figure this out yet?
Happens to me all the time. |
#21 |
Member#: 16980
![]() forgot about this thread...
i changed my steering rack bushings... it helped alot ! |
#22 |
Member#: 33249
South East
Vehicle:2003 WRX white |
![]() Funny, I put the whitelines in and never noticed it till I did it, very slight rattle when turning. Not over bumps but all the times. Just a slight shimmy in the wheel.
#23 | |
Member#: 16980
![]() Quote:
might be the endlinks then ... i changed the endlinks and the steering rack bushings at the same time... i figured the steering rack bushings would solve the steering rattle ... but it might be the endlinks ... or a combination of both. |
#24 |
Member#: 40328
South East
![]() same here
#25 |
Member#: 72022
Vehicle:2005 WRX Wagon WR Blue |
![]() I found what I called the "cricket" in the steering area. I found the buzing was coming from the cruise control button on the lever. Never had the buzz with the old cruise lever without the button on my MY03.
I put a piece of tape on it for now, but if anyone has a better solution I'd sure like to hear it. |
Found the dash / steering column rattle on new '05 STi | powerslide23 | General Community | 12 | 09-01-2004 08:33 AM |
minor rattle in steering column/dash on new wrx? | hys420 | Warranty Issues & SOA Problems | 3 | 05-27-2002 05:32 PM |
('93-'01) Steering wheel rattles?? | AScooby25rs | Impreza Forum | 9 | 04-26-2001 10:52 AM |
steering wheel is rattling on hard right turns | scootr | Normally Aspirated Powertrain | 10 | 02-17-2001 12:02 AM |
steering column rattle? | Zeta | General Forum Archive | 6 | 02-04-2001 12:45 AM |
