![]() Brakes & Suspension Forum sponsored by The Tire Rack |
#1 |
Member#: 41800
Vehicle:04 WRX STI White |
![]() Ok finally today I received my lowering springs for the STI, anyone that has installed these is there anything I need to know before installing them, did you run into any trouble? Also did you have a 4 wheel alignment done after installing the springs?? Thanks!
#2 |
Member#: 18384
Vehicle:2004 STi: 580 AWHP Java Black Pearl |
![]() Hi T1,
Where did you get your springs? Thanks, Russ |
#3 | |
Member#: 41800
![]() Quote:
They just got a shipment in from Japan, don't know how long they will last!! |
#4 |
Member#: 18384
![]() They're already gone!
Russ |
#5 |
Member#: 18384
![]() T1, please install these ASAP and tell us how they work.
Thanks! Russ |
#6 |
Member#: 5231
Vehicle:2004 STi W/G |
![]() T1
No Problems installing those spring. They are as easy as can be, if you have the right tools. With out the right tools, you cn find yourself using more muscle than needed. The rear Bolts were a pain in butt to get of, cause they were on VERY tight, the fronts came of easier. Make sure you take note of the the Strut Tops and how they are in relation to the body of the Strut. You will see that there is a particular way it is aligned. I would take all 4 struts out and as you install the springs, and complete the assembl, check it against the stock set, and make sure everything is aligned, that will save you tons of headaches, when you are putting them back into the car. Took me about 3 hrs by myself. One cool thing you might want to look at is how thick the Struts are when you have it apart, take the plastic boot off and look at the piston on that thing. WReX'N |
#7 |
Member#: 3960
![]() Anyone install H&R springs on an STi yet?
#8 |
Member#: 19467
SCIC
Vehicle:04 WRX STi WR Blue - original owner |
![]() please make sure to take well illuminated pics and closeups (somewhat closeups but capturing the entire wheel) of the gap left between the fenders and tire. I wonder if the H&R will level out the STi? We know that the STi springs will still retain that odd looking gap up in front.
#9 |
Member#: 39180
NESIC
Vehicle:2006 Ford E350 Parked in a school zone |
![]() The H&R's lower the STi 1.4" front and 1.3" rear, so my guess is that there will still be more gap in front than in the rear.
#10 |
Member#: 3960
![]() The H&R's lower my WRX very nicely. Think I'll save them for my STi.
#11 |
Member#: 23341
Vehicle:04 Rex STi WRB/Gold |
![]() Why would you put WRX springs on an STi? If they aren't of a spring rate high enough to go with the stock STi shocks, you're killing the suspension.
#12 | |
Member#: 3960
![]() Quote:
#13 |
Member#: 19392
Vehicle:2006 Forester XT Steel Gray |
![]() How much do the MY04 STi Springs lower by?
#14 | |
Member#: 18384
![]() For one thing, the tops of the rear springs are different. You'd need to swap the STi upper spring perch for a WRX one.
Russ Quote:
#15 | |
Member#: 41800
![]() Quote:
#16 |
Member#: 19467
SCIC
![]() I wonder when prodrive will have their STi springs ready???
#17 |
Member#: 18384
![]() Too late for me... that's when. I ordered a set from Rallispec as well.
You could probably save $25 to $70 bucks waiting for Prodrive, but I prefer not to wait an indefinite amount of time. Russ |
#18 | |
Member#: 7370
Vehicle:2013 5.0 SGM |
![]() Quote:
![]() It's all really a compromise in strut life anyway, as soon as you start dropping the car you're most likely going to shorten the life of the struts by some amount. Seriously though, as far as fitment goes you might have an issue with the spring perches as mentioned above. Last edited by ForceFed4; 09-15-2003 at 10:26 PM. |
#19 |
Member#: 36645
![]() I did the springs, trailing arms and lateral links...do a search in this forum for pics...GET AN ALIGNMENT ASAP...mine was not right before the install, any time you lower a car its a good idea to get an alignment.
#20 | |
Member#: 18384
![]() Was this on your WRX or your current STi?
Russ Quote:
#21 | |
Member#: 41800
![]() Quote:
Ultimate STI lowering springs RCE or STI Pinks | jasonsti06 | Brakes, Steering & Suspension | 10 | 02-22-2007 12:27 AM |
Spring comparison, JDM PINK for STI vs. Prodrive STI lowering spring for STI | SubyWRXSti | Brakes, Steering & Suspension | 0 | 02-14-2006 09:25 PM |
STi Adjustables w/STi lowering springs | WillysPU | Brakes, Steering & Suspension | 1 | 03-01-2004 01:37 AM |
JDM STi Lowering Springs installed on USDM STi | rlavalle | Brakes, Steering & Suspension | 27 | 10-14-2003 01:53 PM |
What are better H&R or STI Lowering Springs? | Lonegunman | Brakes, Steering & Suspension | 12 | 06-08-2001 07:33 PM |
