Welcome to the North American Subaru Impreza Owners Club Friday March 24, 2023
Old 08-18-2003, 02:33 PM   #1
essogas
Member#: 35703
2004 WRX STi
Blue/British Black 18's
Default Things not explained in wheel FAQs...
First thing I never read in wheel EAQs is the performance trade off (or gain) when plus sizing your wheels. Every tune shop has told me that 18's are not as good as 17's for the STi because the contact patch is bigger with 18's so turn-in and handling is sacrificed. If this is the case wouldn't logic dictate that 16's would be better than 17's then. Anyway, they all said 18' are for show, not performance.
The next question is what about tire widths? Going from 7.5 to 8.5? What is gained or lost here? I'm thinking of going 7.0 for winter (narrower) but I will need new rims...
essogas is offline   Reply With Quote
Old 08-18-2003, 06:51 PM   #2
Silver-Bolt
Member#: 40189
2004 STi
Silver/Silver
Your biggest enimies will be weight and rolling resistance. Turn in might actaully improve slightly with a lower profile tire. Less sidewall flex. Not that the stock tires have much flex.
Silver-Bolt is offline   Reply With Quote
Old 08-18-2003, 07:21 PM   #3
Wombat North
Member#: 21267
STI, EWG 8cm Green
UTEC/ECUtek/WI & SD tune
Some quick info
Nathan from turboxs ran a 12.37sec at 3600 ft and if you use the altitude correction factor he was in the 11's. He used stock WRX rims 16 inch.
I used 16 inch stock rims with 50 series tires at the track days in my old WRX which gave me good acceleration and top end but sucked in the corners.
Below copied from Vivid's web site, hope they don't mind.
Now, it has long been believed that bigger is better. In the case of wheels and tires, this only applies to cosmetics. You see, the added weight of a wider tire actually makes the vehicles engine have to work much harder to accelerate. Likewise, as you go to a larger diameter wheel, the weight of the wheel is moved further from the center, and again is much harder to accelerate. In a recent issue of Sport Compact car, they did some tests on the effects of different wheel diameters on acceleration, and track times. They tested 16, 17 and 18-inch wheels, on the same car. They also tested the effect of adding 200 pounds of dead weight to the interior of the vehicle. The difference in quarter mile times and road-course times, as the wheel size was increased, was fairly close to the effect of adding 200 pounds of weight to the car.
The larger diameter wheels, with tires of the same circumference slowed the car down every time. One other consideration when picking wheels and tires is the contact patch. For all intensive purposes, your car has a static mass (if you have a WRX, it's about 3100 lbs). Given a set tire pressure, no matter the tire size (within reason), you will have a set contact patch area. As you drive your car hard into a corner, the tire will start to roll over onto the sidewall. The contact patch changes shape. If 20% of the tire is no longer touching the road, and you have a large round contact patch, then you loose perhaps 25% to 30% of your rubber on the road. If you chose wider tires, and have a longer narrow contact patch, then the 20% of the tire no longer touching the road may only represent a loss of 10-15% of the contact area. This is why people 'should' run wider tires. Anyways, if you want to upgrade your car with the best possible package, choose a high quality tire. Yokohama, Nitto, BF Goodrich and Toyo make some excellent high performance models. If you currently have any sort of all-season on your car, and you want the biggest possible increase in cornering and braking ability, upgrade those tires. As for wheels, pick something that is cosmetically pleasing, but is light weight. Often you can tell the quality of a wheel by price. The incredibly lightweight Volk Racing TE37's are several hundred dollars a wheel, while your local garage may be able to source out an identically sized wheel for well under a hundred dollars. You typically get what you pay for. Don't let your desire for 'bigger is better' get the better of you. Choose quality over quantity!
Wombat North is offline   Reply With Quote
Old 08-18-2003, 08:37 PM   #4
ciper
Member#: 15543
555 Having a Subaru
shop means too many cars
You shouldnt recreate what has already been covered many times. This same thread has happened in the wheels and tires forum too many times to count.
Old 08-18-2003, 10:20 PM   #5
wewu
Member#: 38767
17" = go
18" = show
19" = slow
wewu is offline   Reply With Quote
Old 08-18-2003, 11:10 PM   #6
ciper
Member#: 15543
555 Having a Subaru
16" = go with moh dough (for mods that will make more of a difference)
17" = go
18" = show
19" = slow
Old 08-18-2003, 11:23 PM   #7
RichQY
Member#: 31948
2004 STi
16= doesn't fit
RichQY is offline   Reply With Quote
Old 08-19-2003, 01:37 AM   #8
1BlueSTi4Me
Member#: 40940
2004 Impreza WRX STi
WR Blue/Gold
Originally posted by RichQY
16= doesn't fit
You stole my line !!!
1BlueSTi4Me is offline   Reply With Quote
Old 08-19-2003, 10:04 AM   #9
essogas
Member#: 35703
2004 WRX STi
Thanks guys, so it's pretty much true what I've been told. And I did check in the wheels forum and found ZERO.
Old 09-15-2003, 09:08 PM   #10
essogas
Member#: 35703
2004 WRX STi
I was wondering if anyone else had anything to say about this? I'm having trouble deciding on 17's or 18's...
Old 09-15-2003, 09:15 PM   #11
z
Member#: 41762
04 STi
in ur Floriduh
16= doesn't fit
Dammit, that's what I was gonna say too, try squeezing 16's over those giant brembos and you'll see why they went to 17'z
z is offline   Reply With Quote
Old 09-15-2003, 09:32 PM   #12
ciper
Member#: 15543
555 Having a Subaru
Those posts just show how much misinformation is on this forum. I did a search and the FIRST THREAD on that search had this posting....
Posted by:
Leonardo
Son of Splinter
"Well, the good thing about having them on the island is I can check. I know for a fact the Sub-Zeros don't fit but the SDT's (Prodrive knock offs) fit and those were 16!!!!"
In the same thread
Posted by:
Konrad
"according to motorsport specialities, compomotive TH3 15" wheels will fit. I believe that wheel diameter is not the problem but the relationship between the wheel spokes and the side of the monster Brembo's."
Im not going to search for anymore. I just now know you guys are wrong.
Old 09-15-2003, 09:41 PM   #13
peczenij
Member#: 16791
2004 WRX STi
WRBlue
Sorry if I misunderstood...
But, ciper
Scooby Specialist, are you saying there are 15 inchers that will fit over the Brembos?
peczenij is offline   Reply With Quote
Old 09-15-2003, 10:24 PM   #14
Red Rocket
Member#: 10507
'04 Ex STi Owner
'97 4Runner
Hey,
There is nothing wrong with running a set of 18's if you like.
They will in general weigh a bit more and have more rotational interia, but you can find light ones if you look. For example, toyo t1-s weigh 22 lb in a 225/40-18 and 22.9 in a 245/35-18. Light wheels aren't hard to come by either.
The tire will have a reduced sidewall height, which will make a noticeble difference in road feel - you will have a more precise, direct feel from the wheels. You will also have a better chance od damaging the wheels on rough roads.
I personally run a set of 17x9" front and 17x8.5" rear wheels, with 255/40-17 Toyo RA-1's. Probably the grippyest but still streetable setup you could possubly run. The one thing I don't like about them is the sidewall is a little tall and soft - it's grippy and forgiving, but not super precise.
Kevin
Red Rocket is offline   Reply With Quote
Old 09-15-2003, 11:23 PM   #15
z
Member#: 41762
04 STi
in ur Floriduh
Posted by:
Leonardo
Son of Splinter
In the same thread
Posted by:
Konrad
Seems there is a lot of misinformation going around here:
I did a search on this forum for "SDTs" -for any date- and the only 2 posts that came up were this one and the one you referred to ??
so school me, what are SDT's, bro?
as for the TH3's, I'm going to check on that...we'll see...
EDIT: i wouldn't put those ugly @$$ wheels on my car, anyway. So looks like 17's ????
Old 09-16-2003, 11:33 AM   #16
z
Member#: 41762
04 STi
in ur Floriduh
Posted by:
Leonardo
Son of Splinter
In the same thread
Posted by:
Konrad
Hey Ciper,
Thanks for more misinformation.
I just got off the phone with Belinda at USA comp (800-621-8408)
She called UK while I was on hold and they said:
"NO THE 15's WILL NOT CLEAR THE BREMBO's"
The 17's will. 17's, get it? NOT 15's.
OK?
she said I should clear up this "misinformation" floating around on the forum before a bunch of "misinformed" fools start ordering their 15's only to realize THEY DON"T FIT!!!!!
thanks for trying though, sucka
EDIT: still waiting to find out what those SDT's are
Old 09-16-2003, 11:49 AM   #17
SubEd
Member#: 717
15's?!?
SubEd is offline   Reply With Quote
Old 09-16-2003, 11:57 AM   #18
gforced
Member#: 38898
All you guys have to do is look at your wheels and you will know that nothing less than 17" will fit. I know a lot of people pop off info like they know what they are talking about and their comments are idiotic. Just wait and see what the tuners start using or ask somone that has changed their wheels.
gforced is offline   Reply With Quote
Old 09-16-2003, 01:56 PM   #19
jagcars26
Member#: 2394
2005 Legacy GT wagon
2009 Forester X
Could Leo have meant 15 inch ROTA SDRs?? Just a guess,,,,,im running 17 inch SDRs as a winter setup and i know they fit.
Rudy
jagcars26 is offline   Reply With Quote
Old 09-16-2003, 02:54 PM   #20
z
Member#: 41762
04 STi
in ur Floriduh
Rudy
That was Konrad that said the 15's would fit.
Old 09-16-2003, 07:29 PM   #21
ciper
Member#: 15543
555 Having a Subaru
Im just trying to show everyone that this has been discussed before and others have posted the information.
More than one thread exists with information about wheels smaller than 17 inch fitting.
If the information is incorrect in the other thread you should post that in responce.
I think I read the calipers on the brembos have an effective diameter just greater than 15 inch, meaning the smallest wheel that would fit is something in 16 inch. Cant find that post again though. Did anyone else see it?
I also remember reading about others that have ordered 16 inch wheels for the STI. What do they know that we dont?
Old 09-16-2003, 08:41 PM   #22
z
Member#: 41762
04 STi
in ur Floriduh
I don't know, but I wouldn't mind getting a pair of 16's for winter, if anyone happens to know of any 16's that fit. If not, 17's it is. No 18's for winter for me.
Old 09-17-2003, 08:06 AM   #23
[email protected]
Tire Rack Moderator
Member#: 1215
ext. 4362
there is no way a 15" or a 16" will clear the Brembo's on an STi
Nothing in the FAQ for 08+ Sti wheels...v.question RideZX-6R Tire & Wheel 3 03-05-2010 11:08 PM
Things to NOT leave in your Ferrari when parking it in Jersey City Whitford Off-Topic 39 10-07-2009 05:26 AM
Not answered in FAQ Gc8 info AWDSupaDrift4U Tire & Wheel 1 11-17-2004 11:36 AM
Boost creep question not covered in the FAQ. Nytmare Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 11-10-2004 07:16 PM
This thing is just not kicking in Hyper Off-Topic 5 03-30-2004 07:29 AM
