03-30-2003, 10:22 PM | #1 |
Member#: 19154
air/water intercooler
does anyone think it would be a good idea (and possible) to fit a RS legacy air/water chargecooler to a wrx?
does anyone also know possible performance gains compared to stock ic, other tmic or a fmic? thanks.
03-30-2003, 10:31 PM | #2 |
Member#: 24570
Vehicle:wrx 13.51@98 1/4 1.72 best 60ft |
Should give a much cooler charge, very good for 1/4 type stuff.
i've seen this done, although it was a very long time ago. anything is doable Someone in our ranks is putting a wrx motor into a 67 vw bug, that's a much larger project then air/water ic |
03-30-2003, 10:42 PM | #3 |
Member#: 19154
but would it worth it in terms of performance?
03-31-2003, 12:42 AM | #4 |
Member#: 524
Vehicle:04 STi White |
I'd look into a more professional setup first. The legacy one is frankly quite small, and not really sized right for best performance.
03-31-2003, 12:46 AM | #5 |
Member#: 33979
South East
Vehicle:2006 STi WRB |
Definitely good performance. You may not think it is worth it if you hire someone to do it. Now if you could engineer one and let the rest of us in on it.
Regarding kewl Subaru boxer uses - I happened across a site the other day discussing using a 2.2L closed deck in an airplane. |
03-31-2003, 04:03 AM | #6 |
Member#: 15127
Vehicle:2002 WRX Silver |
When I get home from work I'll post a link to a site with a nice A/L intercooler setup. It uses three Laminova cores if memory serves which, if you're unfamiliar are one of the most efficient designs. I've been seriously considering one of these. Here's a link to Laminova's site
-Leland |
03-31-2003, 11:47 AM | #7 |
Member#: 19154
Laminova's site is very interesting.
03-31-2003, 12:45 PM | #8 |
Member#: 17974
SWIC
There is a company that builds intercoolers for RX-7s and Typhoons/Cyclones in Texas... When I get home I will post a link.... but what they do is instead of using water to cooler they actually plumb into your A/C system and use a condensor to cool the intake charge.... pretty slick setup... and if memory serves me (the link is at home and im at work) the parasitic drawbacks of runing the AC system are actually negates by dropping intake temps by 30-40degrees in the Texas Desert
Will post the link asap hth ~wrx300 |
04-07-2003, 10:24 PM | #10 | |
Member#: 17193
Vehicle:1991 Legacy RS White |
04-08-2003, 02:14 AM | #11 |
Member#: 524
I don't mind small, but looking at the Legacy one, it just looks to be of poor design. If it was 1-2" thicker it would be ALOT better as then the core would be roughly the same thickness or greater than the TB opening, and thus reduce the restriction at the TB side of the Intercooler.
04-08-2003, 09:24 AM | #12 | ||
Member#: 10173
South East
Vehicle:2005 WRX STi Silver |
I still have yet to get confirmation on whether I will be getting the Pipe w/ BOV...... though, once I do, I'll do a nice little write up. Quote:
Blue Last edited by BlueDemon; 04-08-2003 at 09:32 AM. |
04-08-2003, 10:30 PM | #13 | |
Member#: 17193
What the heck is this on his intake manifold? air/water intercooler?? | STR8OUT | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 19 | 03-25-2003 12:27 PM |
STi air-water intercooler?? | kotaro | Legacy Forum | 22 | 12-19-2002 01:51 PM |
Air/Water intercooler install, any suggestions? | BlueDemon | South East Region Forum | 3 | 08-25-2002 09:39 PM |
Air/Water intercooler? | FuZZyLoGiC | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 4 | 06-29-2002 11:45 PM |
Interesting Air/Water intercooler thought | Legacy GTR | Normally Aspirated with bolt-on Forced Induction Powertrain | 9 | 02-13-2002 11:53 PM |
