Welcome to the North American Subaru Impreza Owners Club Thursday March 28, 2024
Go Back   NASIOC > NASIOC Technical > FA Series Factory 2.0L Turbo Powertrain
Old 01-18-2023, 01:39 PM   #1
Th3_huntsman
Member#: 530262
Default Extremely high FKL with no FBK
Hello all,
Running a COBB Stage 1 91oct tune with 93 gas. Everything has been fine except for a constant massive timing pull in second gear. Around 2.5k RPM and less than 10% throttle I’ll get a -9.84 FKL with 0 FBK. My DAM dropped to .625 but is back to .88X but the second gear timing pull persists. Wondering if something is truly wrong or if the tune may not be flashed correctly.
Th3_huntsman is offline   Reply With Quote
Old 01-18-2023, 05:27 PM   #2
PollyPoger1
Member#: 530671
2017 WRX
Default Reply
Do you have any mods installed, also what region are you in?
PollyPoger1 is offline   Reply With Quote
Old 01-23-2023, 10:17 PM   #3
X49
Member#: 386600
2015 WRX
Get a datalog of this happening, upload it to datazap, and post it here.
If it happens at very low throttle, chances are it's false knock from something on the engine making noise that a knock sensor is picking up, or maybe from a bad knock sensor. Check for rattles.
Knock shouldn't occur with calculated load below around 0.5 g/rev in these engines, so if you're getting big knock readings at loads lower than this, it's probably not real knock.
X49 is offline   Reply With Quote
Old 01-28-2023, 09:16 AM   #4
Mort Mortinsen
Member#: 532371
This is almost exactly what is happening to my 2018 wrx right now.
Mort Mortinsen is offline   Reply With Quote
