02-05-2023, 11:17 PM | #1 |
Member#: 483721
Vehicle:2004 WRX Wagon Ugly.... Silver. |
2004 fxt and a dumb arse with tactrix 2.0
So here is the short and skinny. Moms hand me down AKA request she never trade in her car but... give it to me. EGINGE block #50021... no sheet! back to business. 159k developed a fuel leak, required my pulling off the entire top end. While in there, a newer TD04 a CATLESS up pipe and the post MAF intake.
I have a tactrix 2.0 AND a laptop running widows 11. I have a tuner in a remote local who I have faith in but CANNOT get my computer to talk to my car !!! I am scared to run too long with a P0171 code. Please help and if you are local to DC area call me! I will pay ya but $1000 via local shops is BS. I want a reliable runner not a screamin demon..... My 2004 wrx wagon with be the auto X killer. Joshua Oh... the old lady also got a gates timing belt etc. the original turbo had .125+ of shaft play! freeking Mirical
02-06-2023, 03:38 PM | #2 |
Add Lightness
Moderator Member#: 13699
Vehicle:2021 Building It Better |
Why can't you run the stock tune? Go back to 100% stock intake. The up pipe cat shouldn't matter if there's a cat in the down pipe.
02-06-2023, 09:32 PM | #3 |
Member#: 508105
Vehicle:Link G4X flex tuned 02' EJ205 20G 6MT wagon |
I think he is having trouble getting his PC to work with Rom raider.
Are you getting an error? Do you not know how to get started? Your E tuner should walk you through the process of what you need to do to pull logs and reflash maps. Where are you getting stuck? |
02-08-2023, 11:51 AM | #4 | |
Member#: 483721
I destroyed the original intake (oops) post maf... so I had to use the aftermarket. Josh |
02-08-2023, 11:53 AM | #5 | |
Member#: 508105
Jre is Java runtine environment Do you have Java installed? |
02-08-2023, 01:42 PM | #6 |
Member#: 483721
Yes, however it's 64bit. I am ignorant as to how to get 32bit running at the same time. Or how to get rid of 64 and install 32?
02-08-2023, 01:46 PM | #7 |
Member#: 508105
02-08-2023, 02:54 PM | #8 |
Member#: 483721
I will give that a shot and lyk the outcome this evening! Thanks!
02-17-2023, 08:59 PM | #9 |
Member#: 483721
yeah no love... a buddy was able to get the romraider to work but ECU flash is giving a parsing error with XML
02-17-2023, 09:12 PM | #10 |
Member#: 371521
Vehicle:2002 WRX PSM :( |
Whats the error? Did it give you a specific line/character where the error occurs?
02-20-2023, 07:46 PM | #11 |
Member#: 483721
this is what ecu flash shows me when I open it. then when I want to load a car ....NADA.
[19:43:29.238] Logging to file C:/Users/degre/AppData/Roaming/OpenECU/EcuFlash/logs/ecuflash_log_20230220t194329.txt [19:43:29.238] EcuFlash Version 1.44.4870 [19:43:29.238] OS Version Windows 10 [19:43:29.238] Kernel Type winnt [19:43:29.238] Kernel Version 10.0.22621 [19:43:29.238] CPU x86_64 [19:43:29.238] Product Name Windows 10 [19:43:29.239] Product Type windows [19:43:29.239] Product Version 10 [19:43:29.239] Qt Version 5.6.0 [19:43:29.239] Qwt Version 6.1.2 [19:43:29.239] QwtPlot3D Version 0.2.6 [19:43:29.239] Boost Version 1.60 [19:43:29.239] FTDI Library Version 3.02.11 [19:43:29.239] Openport J2534 Library Version 1.02.4870 [19:43:29.244] 67 memory models read. [19:43:29.244] scanning for metadata models in C:/Users/degre/AppData/Roaming [19:43:29.268] Error parsing xml of file C:/Users/degre/AppData/Roaming/HP/HP Setup/REGDATA/RegistrationSubset.xml: Parse error at line 1, column 1:error occurred while parsing element [19:43:29.269] ROM metadata models RegistrationSubset.xml is invalid. [19:43:30.569] ROM metadata models logger.xml is invalid. [19:43:30.580] ROM metadata models logger.xml is invalid. [19:43:30.638] ROM metadata models cars_def.xml is invalid. [19:43:30.687] ROM metadata models logger_IMP_DE_v370.xml is invalid. [19:43:30.687] ROM metadata models logger_IMP_EN_v370.xml is invalid. [19:43:30.687] ROM metadata models logger_METRIC_DE_v370.xml is invalid. [19:43:30.687] ROM metadata models logger_METRIC_EN_v370.xml is invalid. [19:43:30.687] ROM metadata models logger_STD_DE_v370.xml is invalid. [19:43:30.687] ROM metadata models logger_STD_EN_v370.xml is invalid. [19:43:30.975] 4 ROM metadata models scanned. [19:43:30.975] checksum module "subarudbw" loaded. [19:43:30.975] checksum module "subarudiesel" loaded. [19:43:30.975] checksum module "subaruhitachi" loaded. [19:43:30.975] checksum module "mitsucan" loaded. [19:43:30.975] checksum module "mitsuh8" loaded. [19:43:30.975] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded. [19:43:30.975] patch module "Mitsu CAN RAM Parameter Logging" loaded. [19:43:30.981] flashing tool "wrx02" loaded. [19:43:30.983] flashing tool "wrx04" loaded. [19:43:30.985] flashing tool "sti04" loaded. [19:43:30.986] flashing tool "sti05" loaded. [19:43:30.989] flashing tool "mitsucan" loaded. [19:43:30.989] flashing tool "mitsukernel" loaded. [19:43:30.989] flashing tool "mitsukernelocp" loaded. [19:43:30.989] flashing tool "mitsubootloader" loaded. [19:43:30.989] flashing tool "shbootmode" loaded. [19:43:30.989] flashing tool "shaudmode" loaded. [19:43:30.990] flashing tool "subarucan" loaded. [19:43:30.993] flashing tool "subarucand" loaded. [19:43:30.994] flashing tool "subarubrz" loaded. [19:43:30.996] flashing tool "subaruhitachi" loaded. |
02-20-2023, 07:48 PM | #12 |
Member#: 483721
BTW broski... thank you for your help mi amigo
Josh |
02-20-2023, 07:48 PM | #13 |
Member#: 483721
oops multiple post...plz delete
