07-12-2022, 05:25 PM | #51 |
Member#: 100607
AKIC
Vehicle:2019 STI-His 14 XT-Hers |
07-14-2022, 01:51 AM | #52 |
Member#: 80864
AKIC
Vehicle:I'll have the tuna. No crust. |
V6 spoiler 2k sealer and 2k highbuild. Let dry overnight, fill low spots, block sand, 2k seal, 2 coats Aspen white base coat.
07-26-2022, 04:49 PM | #53 |
Member#: 80864
AKIC
Basecoated jams, spoiler, front grill, and respray hood vents and hood scoop.
07-31-2022, 05:47 PM | #54 |
Member#: 80864
AKIC
Bit by bit is the approach respect to full time auto body guys. Layed 2k thicc highbuild followed with 2k sealer. Letting dry for 7 days then basecoat finally.
08-08-2022, 02:21 PM | #55 |
Member#: 80864
AKIC
Painted this past weekend.
08-11-2022, 02:53 AM | #56 |
Member#: 80864
AKIC
Mock up with hood and diy jdm hood scoop. Paint should be fully cured by Sunday then another round of wet sand then final color coat.
08-11-2022, 02:53 AM | #57 |
Member#: 80864
AKIC
Rear taillights mod.
09-04-2022, 03:10 AM | #58 |
Member#: 80864
AKIC
Re assembly ha begun. Wheels are next.
10-14-2022, 03:54 PM | #59 |
Member#: 80864
AKIC
Update |
10-21-2022, 08:40 PM | #60 |
Member#: 80864
AKIC
Got my studless blizzaks tires mounted the other day. Thinking of painting the rims black.
10-21-2022, 09:51 PM | #61 |
Member#: 159474
Vehicle:2017 Impreza Sport Lithium Red - OLDKID |
No please don't paint the wheels black. It makes cars look heavy. Silver, matte gray/bronze, gold, or gun metal.
Sent from my SM-F926U using Tapatalk |
10-22-2022, 10:33 AM | #62 | |
Member#: 80864
AKIC
10-22-2022, 04:26 PM | #63 |
Member#: 159474
I was thinking FnF as well. Lol But I like it!
12-27-2022, 05:32 PM | #64 |
Member#: 80864
AKIC
Worked on the interior the past few weekends. 04 WRX center console mod with window/lock control relocation, and gauge install mod.
12-28-2022, 01:40 PM | #65 |
Member#: 80864
AKIC
Door panels done
02-04-2023, 06:38 PM | #66 |
Member#: 80864
AKIC
Update from wrenching past few weeks.
New clutch, refreshed all vacuum lines and high pressure rubber fuel hoses, 8:1 rrfpr Vortech unit regulator, re-installed intercooler tubing to fit better, DIY recirculation BOV hose to intake tube, custom radiator mounts bottom and top, refresh engine harness and plugs, regapped NGK spark plugs, timing belt and pulleys, new head gaskets,, torqued head studs to wrx turbo spec, and new water pump. Next will be to finish exhaust piping from DP to midpipe. Bought new TD04 turbo core to refresh that too. This setup will be comparable to a stock wrx but much lighter. Wastegate 10psi max. Last edited by nasiocjunkie; 02-07-2023 at 03:47 PM. |
02-04-2023, 07:28 PM | #67 |
Member#: 159474
Nice work! I like the door panels.
02-04-2023, 08:02 PM | #68 |
Member#: 80864
AKIC
Thanks man. I'm finally rounding the bases back to home plate with this project.
Here's a temporary DIY mod I did to a stock WRX exhaust is add an Electronic Exhaust Cutout haha. Drive quietly through my neighborhood then open her up when brapping around town or back roads. [/url] Think they'll notice? |
02-07-2023, 03:53 PM | #69 |
Member#: 80864
AKIC
Moar weekend pics. Finished welding exhaust pipe from down pipe to mid pipe, fuel pump swap pics Walbro 255, temp DIY accessory belt cover with old LP (might paint black in the near future), and began finalizing electrical wiring to double din stereo, power and ground supply to all 3 gouges (A/F, Boost, and EGT).
02-10-2023, 07:55 PM | #70 |
Member#: 340756
AKIC
Vehicle:1998 Legacy GT Ltd |
I love these updates
02-14-2023, 04:38 AM | #71 |
Member#: 80864
AKIC
Thanks man yeah lots of late nights for sure.
Made more progress. Upgraded radiator fans and was able to keep factory fan shroud housing. Rewired radiator fans so passenger side kicks on first --> Bucky Lasek figured that by doing this it keeps engine Temps much cooler. Wanna see how the previous owner did it?? Lol And installed air/fuel sensor. Last edited by nasiocjunkie; 02-14-2023 at 04:51 AM. |
02-14-2023, 02:31 PM | #72 |
Member#: 80864
AKIC
Forgot to add these:
Interior is pretty much buttoned up except for my amp/speaker install. Will tackle in near future (400 watt 4 channel amp powering two 6x9 250 watt speakers, and a 10" kicker bass speaker for the trunk) I am using a generic Amazon black colored seat covers, picked up the most rugged floor mats i found on Amazon these Motor Trend mats, two generic arm rest units, wiring is finished for gauges, rear seat storage, and new black paint on cowling and wiper arms. ELectronic Exhaust Cutout controller tucked near driver seat. Last edited by nasiocjunkie; 02-14-2023 at 03:13 PM. |
03-05-2023, 12:15 PM | #73 |
Member#: 80864
AKIC
Finally got to setting my ride height--> fronts tight 2 fingers, rears loose 2 fingers. Upgraded rear 6" speakers with Kenwood 6x9 400 watt speakers with a Kicker sub. Installed rear wrx seats.
03-10-2023, 03:37 AM | #74 |
Member#: 340756
AKIC
I don't know why I love the look of those rear seats so much.
03-13-2023, 06:40 PM | #75 |
Member#: 80864
AKIC
