04-18-2021, 10:09 PM | #1 |
Member#: 432652
Vehicle:2010 Subaru WRX STI 61K (Gray) |
P0139 help (slow rear o2 sensor response)
So I posted a thread talking about my journey in tying to fix this issue but to no avail. I've tried different sensors, searching and fixing exhaust leaks, etc. I don't have any oxygen sensor spacer to get rid of a cat code. I have a access port tune but I have another thing that I'm thinking is causing it.
So I had recently rebuilt the motor thats stronger (closed deck, I-beams, the whole thing). I went with higher CR pistons (from CP 8.2CR to a Wiseco 9.0 CR prison, same diameter pistons and same length rods) Now my question is, would a higher compression piston affect the response? I'm not versed in tuning whatsoever so I'm just asking for opinions. If not could my tuner use the acessport to just turn off that code? My AFRs are looking normal across the board but I just don't understand what could be causing this slow response code after trying for weeks...
04-19-2021, 07:50 AM | #2 |
Member#: 283429
South East
Vehicle:2016 Fuji Sunfire 03 Silver |
What does your tuner say? Generally when someone tunes your car they should deal with any issues that pop up.
04-19-2021, 07:59 AM | #3 |
Member#: 432652
Hello again Elbert, I haven't contacted my tuner because I thought it was a mechanical issue. The tune was done in Aug of 2018 and nothing has changed or popped up from my engine until I finished the motor build in October of 2020. Even before I started the build the light hasn't popped up. The only thing I can think of that has changed with the build is a higher CR but I don't know if that would effect it. I'll give the shop a call today and find out if they think that could cause any problems
04-19-2021, 10:10 AM | #4 |
Member#: 515308
I feel ya, I just installed an engine now my immobilizer is out of sync, and I had a muffler shop kill an ecu once pulling an o2 and letting the wires ground.
I’d delete it. |
04-19-2021, 10:29 AM | #5 |
Member#: 432652
Called the shop, they said that they would not delete the code for me and that my best bet would be to weld in a high flow cat. Anyone know a place in PA that would delete JUST the slow response code? I don't want to get rid of my oxygen sensor, just the slow response for it. I am just so stumped and getting annoyed with it. The last thing I want to do is throw money at it welding in a high flow cat and still have it pop up
04-20-2021, 03:11 PM | #6 |
Member#: 515308
With epa out and about, I doubt anyone will respond any differently to such a call. Times like this U need a personal relationship. EPA will have everyone on open source before long.
04-21-2021, 09:32 AM | #7 |
Member#: 432652
Yeah, thats the problem I guess, I've been under the car while it is running, no exhaust leaks, guess ill try replacing the oxygen sensor harness and then if that doesn't work ill weld in a cat
04-21-2021, 08:50 PM | #8 |
Member#: 515308
I don’t see the cat helping slow response. Someone capable of tuning that thing will chime in and delete that for you. Openport will do it, I’m sure u would need to tune it then, easy enough and you are no longer have to worry about Cobb
04-26-2021, 03:20 PM | #9 |
Member#: 432652
Holy cow do I have a weird thing going on with this rear oxygen sensor harness... so NASIOC won't let me upload pictures for some reason but here are the links:
https://ibb.co/BP5bmYf https://ibb.co/qJ2LQbJ https://ibb.co/jhCrYZW https://ibb.co/6Wjwhkt https://ibb.co/1nzD48D So from what I can tell there are 2 heater wires, and then a ground and a signal wire. I've tried looking through threads and none of the colors are matching up with the harness I have. As well that I can't find any threads verifying that there is supposed to be a bridge between two of the wires. For whatever reason 2 of the wires are bridged on the harness (Blue and White wires) and then the white wire also seems to be spliced into a bigger grey wire??? I don't know what kind of makeshift harness this is but its very weird. Hopefully someone can shine some light on the situation, I have a new harness on the way |
04-26-2021, 04:32 PM | #10 |
Member#: 432652
So I found a thread saying that the bridge between the wires and the grey wrapping is supposed to be there, back to square 1
04-26-2021, 08:05 PM | #11 |
Member#: 283429
South East
The wire in the grey wrap is shielded but only the white color wire should connect to anything. Although the connection for the shield in the grey par is to ground, it grounds back at the ECM. Looks like your wires have melted together. That blue wire is a ground circuit but that connection could be creating a ground loop which can create electrical noise. I would snip that connection, and insulate those wires. Also make sure the center wire and the outer wire wrap in the grey are not shorted together
04-26-2021, 08:14 PM | #12 |
Member#: 432652
Okay so took a look at the FSM and through this page (https://ibb.co/G0SDT8Q) went through and I got the first and last checks done but could not get a reading for the connection between "rear oxygen sensor connector and chassis ground" the sub-harness is plugged into the engine harness but no ground that i would touch would give me a reading
First ohm: 0.2 Second ohm: 5.4 All within the specifications given Last edited by WRXXXED; 04-26-2021 at 08:33 PM. |
04-26-2021, 08:38 PM | #13 | |
Member#: 432652
04-26-2021, 08:44 PM | #14 | |
Member#: 432652
Here's a link to the thread I found explaining why they're connected: https://forums.nasioc.com/forums/sho....php?t=2909633 |
04-29-2021, 01:08 PM | #15 |
Member#: 432652
Okay so installed the new oxygen sensor harness and took another ohm reading and its still the same. When I started the car the code cleared but I believe thats just because the connection was broken. Going to see if the code comes back and if it does I guess there's a short from the ECU to the connection that I plug the harness into. Well see...
04-30-2021, 09:52 PM | #16 |
Member#: 432652
Sure enough, popped up again
05-09-2021, 08:48 PM | #17 |
Member#: 432652
Truly not sure what caused it but had a member on here who helped me out in fixing the problem and will be getting a tune from them soon to completely fix the problem
09-18-2021, 08:10 AM | #18 |
Member#: 432652
Switched over to a bosch 4.9 wideband and sensor combo and went to a v-band housing and the wideband is matching with the "sensor 1" front oxygen sensor.
I was just going through the cobb acessport guages and saw "sensor 3 voltage" which is the rear and at idle it reads .9 volts, out of a 0-1v narrowband scale that's really rich... so which one is correct? It's not an oem sensor but a DENSO oem replacement so is the scaling weird? I am going to be getting road tuned Monday and said tuner is planning on shutting off the rear input in place of the wideband so is it not that big of a deal until it gets tuned? I just don't see how the rear is running rich but the front is showing a good idle afr. |
