02-23-2021, 06:53 PM | #1 |
Member#: 389509
ECUflash read issue on FSTI 2005 JDM model
Hi All. Its been a few years since I have been on the forums but need some help for a new Subaru ECUflash read issue I seem to be having. I purchased a fresh import JDM FSTI 2005 facelift and love the car to bits after swapping from VAG. I have owned quite a few Imprezas and mapped two multiple times both STI and WRX with ECUflash and Romraider in previous years. I've been logging with a plan to scale my MAF before moving on to the next point, as you do. Problem is Romraider works and logging seems to be fine. But the read option from Ecuflash isn't playing ball. Any help would be greatly appreciated with being able to pull a copy of the map to get some work done. I have logged on my old version of Ecuflash and the newer version both read details from Ecuflash below -
Older version of Ecuflash [22:48:07.867] EcuFlash Version 1.44.3721 [22:48:07.867] OS Version Windows 7 [22:48:07.867] Qt Version 4.8.0 [22:48:07.883] 63 memory models read. [22:48:07.883] scanning for metadata models in C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata [22:48:07.977] 507 ROM metadata models scanned. [22:48:07.977] checksum module "subarudbw" loaded. [22:48:07.977] checksum module "mitsucan" loaded. [22:48:07.977] checksum module "mitsuh8" loaded. [22:48:07.977] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded. [22:48:07.977] patch module "Mitsu CAN RAM Parameter Logging" loaded. [22:48:07.977] flashing tool "wrx02" loaded. [22:48:07.977] flashing tool "wrx04" loaded. [22:48:07.977] flashing tool "sti04" loaded. [22:48:07.977] flashing tool "sti05" loaded. [22:48:07.977] flashing tool "mitsukernel" loaded. [22:48:07.977] flashing tool "mitsukernelocp" loaded. [22:48:07.977] flashing tool "mitsubootloader" loaded. [22:48:07.977] flashing tool "shbootmode" loaded. [22:48:07.977] flashing tool "shaudmode" loaded. [22:48:07.992] flashing tool "subarucan" loaded. [22:48:07.992] flashing tool "subarucand" loaded. [22:48:07.992] flashing tool "mitsucan" loaded. [22:48:56.935] using metadata XML ID read_sti05 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_sti05.xml [22:48:56.967] J2534 API Version: 04.04 [22:48:56.967] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59 [22:48:56.967] Device Firmware Version: 1.17.4869 [22:48:56.967] Device Serial Number: TAbUZ8mP [22:49:01.473] kernel get version [22:49:01.676] interface close [22:49:01.707] J2534 API Version: 04.04 [22:49:01.707] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59 [22:49:01.707] Device Firmware Version: 1.17.4869 [22:49:01.707] Device Serial Number: TAbUZ8mP [22:49:02.019] VIN read not supported [22:49:02.128] interface close [22:49:02.159] J2534 API Version: 04.04 [22:49:02.159] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59 [22:49:02.159] Device Firmware Version: 1.17.4869 [22:49:02.159] Device Serial Number: TAbUZ8mP [22:49:02.347] SSM2 init [22:49:02.487] SSM2 ECU ID is 3B02594216 [22:49:02.565] Requesting Seed... [22:49:02.612] Sending Key... [22:49:03.236] interface close [22:49:03.251] interface close [22:49:23.508] using metadata XML ID read_sti05 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_sti05.xml [22:49:23.539] J2534 API Version: 04.04 [22:49:23.539] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59 [22:49:23.539] Device Firmware Version: 1.17.4869 [22:49:23.539] Device Serial Number: TAbUZ8mP [22:49:25.929] kernel get version [22:49:26.132] interface close [22:49:26.163] J2534 API Version: 04.04 [22:49:26.163] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59 [22:49:26.163] Device Firmware Version: 1.17.4869 [22:49:26.163] Device Serial Number: TAbUZ8mP [22:49:26.350] interface close [22:49:26.382] J2534 API Version: 04.04 [22:49:26.382] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59 [22:49:26.382] Device Firmware Version: 1.17.4869 [22:49:26.382] Device Serial Number: TAbUZ8mP [22:49:26.553] SSM2 init [22:49:26.959] SSM2 init [22:49:27.364] SSM2 init [22:49:27.770] SSM2 init [22:49:28.176] SSM2 init [22:49:28.581] SSM2 init [22:49:28.987] SSM2 init [22:49:29.392] SSM2 init [22:49:29.798] SSM2 init [22:49:30.204] SSM2 init [22:49:30.718] interface close [22:49:30.734] interface close [22:49:55.249] using metadata XML ID read_sti04 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_sti04.xml [22:49:55.280] J2534 API Version: 04.04 [22:49:55.280] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59 [22:49:55.280] Device Firmware Version: 1.17.4869 [22:49:55.280] Device Serial Number: TAbUZ8mP [22:49:57.791] kernel get version [22:49:57.994] interface close [22:49:58.025] J2534 API Version: 04.04 [22:49:58.025] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59 [22:49:58.025] Device Firmware Version: 1.17.4869 [22:49:58.025] Device Serial Number: TAbUZ8mP [22:49:58.212] interface close [22:49:58.243] J2534 API Version: 04.04 [22:49:58.243] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59 [22:49:58.243] Device Firmware Version: 1.17.4869 [22:49:58.243] Device Serial Number: TAbUZ8mP [22:49:58.415] SSM2 init [22:49:58.820] SSM2 init [22:49:59.226] SSM2 init [22:49:59.632] SSM2 init [22:50:00.037] SSM2 init [22:50:00.443] SSM2 init [22:50:00.848] SSM2 init [22:50:01.254] SSM2 init [22:50:01.660] SSM2 init [22:50:02.065] SSM2 init [22:50:02.580] interface close [22:50:02.596] interface close [22:51:03.853] using metadata XML ID read_sti05 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_sti05.xml [22:51:03.884] J2534 API Version: 04.04 [22:51:03.884] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59 [22:51:03.884] Device Firmware Version: 1.17.4869 [22:51:03.884] Device Serial Number: TAbUZ8mP [22:51:07.840] kernel get version [22:51:08.043] interface close [22:51:08.074] J2534 API Version: 04.04 [22:51:08.074] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59 [22:51:08.074] Device Firmware Version: 1.17.4869 [22:51:08.074] Device Serial Number: TAbUZ8mP [22:51:08.261] interface close [22:51:08.292] J2534 API Version: 04.04 [22:51:08.292] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59 [22:51:08.292] Device Firmware Version: 1.17.4869 [22:51:08.292] Device Serial Number: TAbUZ8mP [22:51:08.464] SSM2 init [22:51:08.870] SSM2 init [22:51:09.275] SSM2 init [22:51:09.681] SSM2 init [22:51:10.086] SSM2 init [22:51:10.492] SSM2 init [22:51:10.898] SSM2 init [22:51:11.303] SSM2 init [22:51:11.709] SSM2 init [22:51:12.114] SSM2 init [22:51:12.629] interface close [22:51:12.645] interface close Newer Ecuflash read attempt [21:02:18.168] Logging to file C:/Users/s/AppData/Roaming/OpenECU/EcuFlash/logs/ecuflash_log_20210222t210218.txt [21:02:18.168] EcuFlash Version 1.44.4870 [21:02:18.168] OS Version Windows 7 [21:02:18.168] Kernel Type winnt [21:02:18.168] Kernel Version 6.1.7601 [21:02:18.168] CPU x86_64 [21:02:18.168] Product Name Windows 7 [21:02:18.168] Product Type windows [21:02:18.168] Product Version 7 [21:02:18.168] Qt Version 5.6.0 [21:02:18.168] Qwt Version 6.1.2 [21:02:18.168] QwtPlot3D Version 0.2.6 [21:02:18.168] Boost Version 1.60 [21:02:18.168] FTDI Library Version 3.02.11 [21:02:18.168] Openport J2534 Library Version 1.02.4870 [21:02:18.168] 67 memory models read. [21:02:18.168] scanning for metadata models in C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata [21:02:18.356] 745 ROM metadata models scanned. [21:02:18.356] checksum module "subarudbw" loaded. [21:02:18.356] checksum module "subarudiesel" loaded. [21:02:18.356] checksum module "subaruhitachi" loaded. [21:02:18.356] checksum module "mitsucan" loaded. [21:02:18.356] checksum module "mitsuh8" loaded. [21:02:18.356] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded. [21:02:18.356] patch module "Mitsu CAN RAM Parameter Logging" loaded. [21:02:18.356] using metadata XML ID read_sti05 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_sti05.xml [21:02:18.356] flashing tool "wrx02" loaded. [21:02:18.371] flashing tool "wrx04" loaded. [21:02:18.371] flashing tool "sti04" loaded. [21:02:18.371] flashing tool "sti05" loaded. [21:02:18.371] flashing tool "mitsucan" loaded. [21:02:18.371] flashing tool "mitsukernel" loaded. [21:02:18.371] flashing tool "mitsukernelocp" loaded. [21:02:18.371] flashing tool "mitsubootloader" loaded. [21:02:18.371] flashing tool "shbootmode" loaded. [21:02:18.371] flashing tool "shaudmode" loaded. [21:02:18.387] flashing tool "subarucan" loaded. [21:02:18.387] flashing tool "subarucand" loaded. [21:02:18.387] flashing tool "subarubrz" loaded. [21:02:18.387] flashing tool "subaruhitachi" loaded. [21:02:18.449] J2534 API Version: 04.04 [21:02:18.449] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31 [21:02:18.449] Device Firmware Version: 1.17.4869 [21:02:18.449] Device Serial Number: TAbUZ8mP [21:02:18.449] interface close [21:02:18.480] J2534 API Version: 04.04 [21:02:18.480] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31 [21:02:18.480] Device Firmware Version: 1.17.4869 [21:02:18.480] Device Serial Number: TAbUZ8mP [21:02:18.480] interface close [21:02:18.496] J2534 API Version: 04.04 [21:02:18.496] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31 [21:02:18.496] Device Firmware Version: 1.17.4869 [21:02:18.496] Device Serial Number: TAbUZ8mP [21:02:18.496] interface close [21:02:18.543] J2534 API Version: 04.04 [21:02:18.543] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31 [21:02:18.543] Device Firmware Version: 1.17.4869 [21:02:18.543] Device Serial Number: TAbUZ8mP [21:02:18.543] interface close [21:02:18.590] J2534 API Version: 04.04 [21:02:18.590] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31 [21:02:18.590] Device Firmware Version: 1.17.4869 [21:02:18.590] Device Serial Number: TAbUZ8mP [21:02:18.590] interface close [21:02:18.636] J2534 API Version: 04.04 [21:02:18.636] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31 [21:02:18.636] Device Firmware Version: 1.17.4869 [21:02:18.636] Device Serial Number: TAbUZ8mP [21:02:18.636] interface close [21:02:37.010] using metadata XML ID read_sti05 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_sti05.xml [21:02:37.041] J2534 API Version: 04.04 [21:02:37.041] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31 [21:02:37.041] Device Firmware Version: 1.17.4869 [21:02:37.041] Device Serial Number: TAbUZ8mP [21:02:39.820] kernel get version [21:02:40.038] interface close [21:02:40.085] J2534 API Version: 04.04 [21:02:40.085] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31 [21:02:40.085] Device Firmware Version: 1.17.4869 [21:02:40.085] Device Serial Number: TAbUZ8mP [21:02:40.366] VIN read not supported [21:02:40.475] interface close [21:02:40.491] J2534 API Version: 04.04 [21:02:40.491] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31 [21:02:40.491] Device Firmware Version: 1.17.4869 [21:02:40.491] Device Serial Number: TAbUZ8mP [21:02:40.662] SSM2 init [21:02:40.803] SSM2 ECU ID is 3B02594216 [21:02:40.881] Requesting Seed... [21:02:40.927] Sending Key [1]... [21:02:41.551] interface close [21:02:41.551] interface close
02-23-2021, 07:03 PM | #2 |
Member#: 50586
BAIC
Vehicle:64 Impala |
do you have the jumper block and green test connectors connected??
02-24-2021, 01:28 AM | #3 |
Member#: 389509
I was under the impression that I only needed the jumper and test blocks for the older platform. Would make sense of that is the problem. Are they required for the newer platform Subaru's?
02-25-2021, 08:15 PM | #4 |
Member#: 50586
BAIC
Vehicle:64 Impala |
I think they're not needed on 32bit ECU's but needed on 16bit....check out the Tactrix website. I'm not familiar with JDM STI Foresters but assume they're similar to JDM STI's.
