Welcome to the North American Subaru Impreza Owners Club Friday March 29, 2024
Old 09-03-2020, 03:14 PM   #1
defury
Member#: 428480
2003 Jdm Forester
Default Can't add vehicles to ECU flash definitions?
I have all the definitions I need from
https://github.com/TD-D/SubaruDefs/tree/Alpha
and my ECU is in there but when I can't figure out how to make it so when I go to select vehicle it shows up. It's only a bunch of mitsubishis and a couple subarus so I can't download my rom.
How do I change it so the proper definition is showing in the "select Vehicle"?
defury is offline   Reply With Quote
Old 09-03-2020, 07:10 PM   #2
zcivic
Member#: 199691
04 Forester XT
If you’re meaning select vehicle drop down for read/reflash I think there’s only 16 bit for dbc cars and 32 bit for dbw. What are car are you trying it on? You don’t select your specific vehicle just the flash type.
zcivic is offline   Reply With Quote
Old 09-03-2020, 08:46 PM   #3
defury
Member#: 428480
2003 Jdm Forester
I figured out the problem. I had engage test mode at the exact same time as I hit "OK" on Ecu flash or it wouldn't read, if the fans started I was already too late and it would error out. It was basically half a second I had to turn the key and hit ok.
