Welcome to the North American Subaru Impreza Owners Club Thursday March 28, 2024
Old 04-17-2021, 12:27 AM   #1376
cement_rex
Member#: 523737
Default beautiful write up man !
Originally Posted by Vlad View Post
GRB EJ207
The early GRB EJ207
As the GRB bodystyle started for the JDM, Subaru did not yet have a Spec C model. They quickly started an A-line Sti, equipped with an EJ257 and automatic transmission (different than the USDM EJ255 GRB one) and used an EJ207 converted to throttle by wire, canbus, no intercooler autospray, immobilized, dual AVCS.
All GRB EJ207 have the dark blue injectors, replacing the GDB pinks.
The turbo is a VF49, twinscroll. The intake manifold has functional TGV's. The engine speed limit is 8000 rpm
It is possible, but not confirmed yet, that for these engines, the castings were the thick liner, desirable ones, described below in detail, under "spec C".
The part number for the kit of : block half-castings, castings bolts, castings plugs is:
1008AB210. This is the same part number as for the later Spec C engines, suggesting that while the long block is different, the castings are the same, you'd still get the thick liners.
I believe that these were the Rev A and B
The codes of these engines are
EJ207HG1LE
The factory notes for these are two, the first is "for EJ207", the second is "for Sti".
So in a confusing way, the first of these engines, went into a car called "EJ207". My opinion is that this refers to the factory prototype, it could be ANY chassis.
The Sti in Rev A was not yet a Spec C
The Spec C EJ207
Sobaru finally rolls out the Spec C. They were definitely putting together the base for a strong engine for this particular EJ207.
These are dual AVCS, topfeed injectors (they switched to dark blue ones), with functional TGV's, canbus, throttle by wire, immobilized.
These came, at least in the beginning, still with the VF49, then the VF53. Then the VF56 for the R205 and then for the S206.
This engine was homologated for Group N.
The intake ports in the heads are much bigger than anything before, by as much as 2 milimeters. The exhaust ports are larger by 0.7mm, but the inner diameter of the exhaust manifold is unchanged.
The block for the Spec C is a thick casting, reinforced block, I call it a 3/4 closed deck.
The total thickness of the liner and liner support, measured at the headgasket seating area is:
EJ257 7.7 mm
EJ207 GDB 9.6mm
EJ207 GRB 13.2mm
Here is a photo:
I believe that these were the revision B Spec C engines.
the codes for these are:
EJ207HJ2LJ
EJ207HJ2NJ
The factory notes for these two are "for Spec C" and then you have couple option packages.
An important note is that the option packages marked OPC are starting to show up again, with the beginning of the Spec C.
I never really decoded the OPC yet, but within OPC 91-93, in GDB, you had oil radiator, no AC, lightweight battery and maybe small windshield washer tank.
So now OPC91-94 are showing up, hinting to a possible GRB Spec C with no AC and maybe with oil radiator.
A new OPC 98 appears..
How to ID your GRB EJ207
This becomes a very important question, if the early GRB EJ207 can be different..
I have partial information available, from the work of dr20t (Mick).
This partial information is important because it points towards the spec C engine.
As in the photo below, it is marked with B25C. Don't forget that there WERE JDM EJ257 Sti, they can also be marked B25C. However, the EJ20 sqare casting mark, singles thisone out as EJ207.
Mick noted that the extra thickness of the liners (and maybe of sleeves too?) is obtained from a casting similar to an EJ257, but with thicker liners, to account for the reduced displacement (and cylinder diameter) pf the EJ207.
Apparently, the coolant jacket holes in the headgasket, line up with those in an EJ257 headgasket.
The pistons are cast, from all the info available at this time.
These were provided by Mick.
There is still a significant amount of TDC to deck clearance with these. The clearance to deck is the same as a V8-V9, the compression ratio with a hybrid based on heads from V8-9 would not change.
Headgaskets are particular to these.
1008AB210
Swapping the GRB EJ207
Swapping into a GDB Body
The GRB needs its ECU to work properly. This time, the discrepancy in range between AVCS and other parameters is larger.
The GRB both in US and JDM can only be CANBUS.
CANBUS is vaguely similar to Ethernet.
So your GBD ECU does not have the "network switch" installed, hardware is missing. It could not control a GRB engine.
Caution: the following is theory only, nobody has tried this yet.
-You could use your GDB JDM EJ207 ECU
-You could use your GDB EJ207 heads and manifold, with all associated sensors.
-You would in this case use the GRB EJ207 headgaskets and bolts, the compression ratio will not change.
-There are 3 sensors that normally would be located on the GRB block and their compatibility has to be looked at:
The knock sensor, water temp sensor and the Crank position sensor. The information available suggests that these should work even from GDB.
In fact, K2Kevin posted in this thread that the 32bit crank sensor is the same as the 16 bit crank sensor and that the only other 32bit conversion was to change the plug style for the temperature sensor, to splice a different style plug into the engine harness.
This has been done in reverse (16 bit sensor substituted by 32 bit sensor), by Kpluiten and K2Kevin, in their projects of converting a 16bit EJ207 to a 32 bit EJ207.
-You would use GDB EJ207 spark plugs and coil packs that you already have.
This combo should in theory be more sturdy than a regular GDB EJ207, due to the thicker liners and flow air the same way a GDB 207 would.
From the latest research and clearance to deck info above, the compression ratio of the hybrid will not change.
Swapping into a GRB USDM body
I am seeing two swaps GRB into GRB with one other possibly done with the owner unwilling to post or share any info. I believe that this third and oldest one is a full and complete swap, including wiring, etc, therefore not that interesting or important.
Once again, here is my theory:
Since CANBUS cand be vaguely compared with Ethernet, each ethernet device must have a switch and a software driver.
When you get a JDM ECU, the first step is going to be to get the immobilizer to allow the ECU to start the car.
For the GRB, the latest information collected from Mick and Dave is that you need as a matching kit: the Cluster, Body control unit, ECU, keys and immobilizer unit.
The GRB would already have the antenna built into the ring.
This may sound like a lot, but many convert their clusters anyway
Once you start the car, the problems you may be facing will have to do with the ECU seeing on the network devices for which it has no drivers.
By example: USDM ABS.
The only thing i happen to know is that German VW implementation of CANBUS uses the VAG software to install drivers each time you replace a sensor.
So maybe there is a driver installation device, like a Subaru laptop and there are drivers that they download from a database.
End of theory, beginning of collected data.
One fo the other two swaps mentioned above, resulted into the engine started but idrive and ABS/VDC non functional. The owner believes that swapping a JDM ABS unit may solve that problem.
I have a different theory:
A board member has tried to implement a quick steering rack, made by Qrack in a GRB Sti, the ECU of that car has then disabled the VDC/ABS, due to unmatching output from the steering angle sensor.
A Spec C ECU would expect to find a 13:1 steering rack, and if it finds a 15:1 standard Sti rack, it will then disable the ABS/VDC probably (this is a theory). The solution would be to get a Qrack.
amazing write up and plenty of information ! thank you vlad ! currently searching for a v7 207 for my bugeye wrx so love reading this !
cement_rex is offline   Reply With Quote
Old 04-17-2021, 08:20 AM   #1377
Vlad
Member#: 46135
19 GLA45 AMG
C63 AMG
Thanks, enjoy the swap adventure, be careful with the engine you choose as they're old now and people are having problems with what's available on the market V7-V9.
Old 04-17-2021, 10:45 AM   #1378
dr20t
Member#: 311246
2000 AUDM GC8 WRX
Royal Silver
I completely agree with Vlad.
You can now quite easily source Grb onwards thick walled brand new subaru assembled short blocks.
I would go with one of these and source jdm ej207 v7-9 single avcs heads or Jdm 01-05 ej205 avcs heads (same casting as the big port single Avcs ej207 heads) - these can also be found in the eudm, sadm or audm 03-05 ej205’s - T20 castings.
Then change cams and springs to good aftermarket ones and use new gaskets and
Seals and voila
Mick
dr20t is offline   Reply With Quote
Old 05-09-2021, 01:48 PM   #1379
2000c43
Member#: 518845
I am putting an AIM Power Distribution Module in my car and am in the process of finalizing sensors for my EMS Stinger v4 ECU and AIM PDM. I have two questions (apologize if these are dumb or obvious):
1. What is the sensor under the alternator next to the EJ20 stamp? I assume this is for oil pressure. As you can see from the photos, the previous owner has hacked in something unusual here. I will be putting a 1/8 NPT AIM pressure sensor in this location if this is in fact where oil pressure readings are taken.
https://drive.google.com/file/d/1NhQ...ew?usp=sharing
https://drive.google.com/file/d/1yXt...ew?usp=sharing
2. What is the sensor located at the back of the engine into the block. This has a single spade connector and looks like a temp sensor to me. This is the one I'm most confused about.
https://drive.google.com/file/d/1--2...ew?usp=sharing
https://drive.google.com/file/d/1hQq...ew?usp=sharing
Thank you!!! Dean
2000c43 is offline   Reply With Quote
Old 05-09-2021, 04:24 PM   #1380
johnfelstead
Member#: 856
2123 JDM STi
Those are the oil gallery plug locations.
Front is used for the OEM oil pressure switch, mostly used in aftermarket for an oil pressure sensor.
Rear is blanked as OEM but usually used for a takeoff for an oil temp gauge sensor.
You can buy adapters that screw into the block for the sensors to screw into.
Looks like you have an early cast EJ20 closed deck block, the hatchings are only found on sand cast blocks. That's not an EJ207. It should have piston oil squirters in the block. They were made very early in the EJ series and are nice to have for bigger power builds.
johnfelstead is offline   Reply With Quote
Old 05-10-2021, 11:07 AM   #1381
2000c43
Member#: 518845
Thank you John. That solves the mystery. I'll put the AIM pressure switch in the front and add an AIM oil temp in the rear since the provision for oil temp is already there.
I believe it is a EJ205G Type RA engine. It has the fifth injector, cross hatching, etc. I purchased a Ferrari Dino and this is the engine and trans that was in it. Kind of a nice surprise to find that the engine the car came with was such a nice one.
Old 05-10-2021, 02:33 PM   #1382
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
That is an identical setup to how I have my Defi gauges setup
Oil temp by the turbo is a great indicator , On a recent track day I barely got over 205f with 60f ambient temperature.
Gigs90 is offline   Reply With Quote
Old 05-13-2021, 04:15 PM   #1383
Toff
Member#: 524278
2010 R205 STi
RED
Great thread this! Found it very helpful when IDing parts on my Spec C GRB
Toff is offline   Reply With Quote
Old 06-26-2021, 04:53 PM   #1384
Scuter83
Member#: 59781
2002 wrx sedan
sedona red pearl
Not sure if this is the best place for this question but here goes. I have a 2002 WRX sedan with an EJ207. I am trying to replace my engine mounts. I did the driver side no problem, but with the passenger side it seems the twin scroll header isn't allowing the passenger side engine mount to come out anywhere. Has anyone done these in the car? If so, how did you get the passenger side mount out?
Scuter83 is offline   Reply With Quote
Old 06-27-2021, 12:53 PM   #1385
Scuter83
Member#: 59781
2002 wrx sedan
sedona red pearl
In case anyone finds this helpful in the future, I dropped the header. I think it is the only way it can be done if you just raise the engine without removing it.
Old 07-06-2021, 04:30 AM   #1386
Phosoup253
Member#: 514882
Trying to ID my ej20
Recently purchased an 2002 wrx sedan with jdm 6 speed and 04 brembos and a “jdm ej205” as listed on the ad.
Owner didn’t know too much about the car, heading to college just wanted it out.
I have a slight hunch I have an ej207 v7,v8 on my hands.
Aftermrket turbo so can’t identify there
Red intake manifold looks to be oem Sti by texture of paint and the wear on there from age
Stock oem tgv deletes
Aftermarket injectors so don’t know if they came with the pinks Sti or blue wrx
After comparing pictures and remembering something I read a while ago regarding the harmonic balancer/crank pulley being different I decided to take look at mines.
I do indeed have the same more “flush” crank pulley like the other ej207 I see online as oppose to the crank pulley on the ej205. Physical different is drastic in comparison.
Any other way to identify?
Phosoup253 is offline   Reply With Quote
Old 07-06-2021, 09:48 AM   #1387
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
Head castings are a good indicator
Old 07-07-2021, 08:51 PM   #1388
Sittinlw
Member#: 484662
13 STI hatch
Has anyone manged to get Thea v8 207 swap into a GRB without swap in the GRB cams?
Sittinlw is offline   Reply With Quote
Old 07-07-2021, 11:03 PM   #1389
subaru_gc8
Member#: 29292
2004 WRX wagon
the v8 car is a SAVCS and the grb is a DAVCS. that is a lot of work to go backwards
subaru_gc8 is offline   Reply With Quote
Old 07-08-2021, 12:22 AM   #1390
Sittinlw
Member#: 484662
13 STI hatch
I got the motor cheap and mine took a dump. I just wanted something different as well.
Old 07-08-2021, 07:24 AM   #1391
snow_bound26
Member#: 395793
2005 92x Aero
Beige
Stand alone EM and rewire for 2 wire cam sensors would probably do it. But as stated, it's going to be a lot of work to go backward
snow_bound26 is offline   Reply With Quote
Old 07-27-2021, 01:10 PM   #1392
Bansheeboy11
Member#: 182415
1999 RS
Fellow 207'ers i need yo help. Ive gotten two years out of this tomei manifold, slip joints rotted and i rewelded them to get by, ive now done that twice and im at the point where i need to cut the joints out and replace entirely or get a new manifold. Anyone know of a shop that makes/sells twin scroll manifolds that arent made of chineseum? I was looking for a Moore manifold but they seem to not be making any parts, Full race and ETS wont make a twin scroll, only their 1.5 setups.
The flanges and tubes are in good shape, its just the slip joints that i can cut/replace if i can find the right size tubing. But id like to get a more robust manifold that can handle more aggressive anti lag use.
Bansheeboy11 is offline   Reply With Quote
Old 07-27-2021, 10:22 PM   #1393
Bluestreak03
Member#: 125887
2001 EJ207 V7 RSTi,
Mica Blue
Why don't you just have straight sections welded in eliminating the slip joints
Bluestreak03 is offline   Reply With Quote
Old 07-28-2021, 07:29 PM   #1394
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
Sounds like your headers are experiencing a lot of wear due to weather over time, which is outside of normal wear and tear. Have you consider going back to OEM? Seriously, OEM exhaust manifolds/headers are designed to last, not aftermarket headers.
Fierysun is offline   Reply With Quote
Old 07-28-2021, 10:59 PM   #1395
ether947
Member#: 297799
2003 WRX
EJ207 version 8
It sounds like he is using anti-lag.
FWIW, I never had any issues with my Tomei headers (single scroll; EJ255 & EJ257 approx. 80k miles), but that was several years ago and the quality may have gone down since then. I kept them wrapped and I always ran an undertray. My OEM T/S header cracked two different runners at the flange; it blew one runner completely out. I just replaced it with another used OEM header but I'm leaning towards single scroll if this one breaks. Or I could have the outside of the flanges fully welded up. I can't imagine they will hold up to anti-lag abuse as is.
Bansheeboy11, you can try these guys for stainless tubing if you want to patch up your Tomei header.
https://www.verociousmotorsports.com...bing-stainless
ether947 is offline   Reply With Quote
Old 08-24-2021, 08:22 AM   #1396
Vlad
Member#: 46135
19 GLA45 AMG
C63 AMG
My OEM twinscroll headers had developed a crack in time, I had replaced them at the time with another used set.
The new ones were too expensive.
Then I steel brushed the replacement set and sprayed them with cold galvanizing paint.
Old 08-24-2021, 01:05 PM   #1397
Bansheeboy11
Member#: 182415
1999 RS
Ive used a few sets of OEM manifolds on my car and customers cars, the ones that get tracked and driven hard all crack primary tubes within a few inches of the head flanges. They also weigh quite a bit more. I did a dirty mig job to get by for a bit but ill probably just cut the tubing out and tig in some new slip joints. The manifold is in great shape aside from the joints going bad, flanges were straight last time i had it off, no corrosion of the tubing either.
Old 08-24-2021, 08:57 PM   #1398
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
That is why I have a spare now
Old 10-23-2021, 12:28 PM   #1399
murrdogg24
Member#: 50586
64 Impala
hey guys I am running a hybrid EJ257/207 swap now with the V8 JDM ECU with AVCS...would it be worth it to do the 3rd alternator wire? I can't remember how I did it on my last JDM swap.
murrdogg24 is offline   Reply With Quote
Old 10-24-2021, 12:11 AM   #1400
Fierysun
Member#: 82745
2005 Subaru STI
To be honest, I noticed zero nada zipp when I did the 3rd alternator wire mod. But hey, maybe that's what it's suppose to do...
