01-04-2007, 09:28 PM | #1 |
Member#: 48180
Vehicle:2004 WRX Impreza Java Black Pearl |
Busted my TGV motor
Long story short, I busted the thing into two pieces installing my turbo inlet. I'm picking up another one tomorrow but I was told I need to pre-load the valve, another forum said to install the motor so the plug receptacle is at the 12 o'clock position then turn entire thing so the mounting holes line up. Sound correct?
01-04-2007, 09:33 PM | #2 |
Member#: 108716
South East
Vehicle:2004 2.1L, PT 6069 480@30psi Subarus-R-Us |
not sure but it will need to be calibrated (or so the dealer told us it had to be) and that thing is is like $300.
01-04-2007, 09:36 PM | #3 |
Member#: 48180
more like 145..
01-04-2007, 09:52 PM | #4 |
Member#: 105115
Delete them...
01-04-2007, 10:07 PM | #5 |
Big Ron
Super Moderator Member#: 18062
www.scoobymods.com is your friend, whatever it says....do.
01-05-2007, 01:09 AM | #6 |
Member#: 30745
South East
Vehicle:SRP Greddy(R.I.P) Bugeye & '99 LandRover D2 |
Man that sucks.That happened to me and my buddy.We were doing the same thing(turbo inlet hose install)on his 05 STi.He ended up buying the part.
-Caesar |
01-05-2007, 09:14 AM | #7 |
Member#: 93646
Vehicle:Many Track Records Let us help you go fast! |
I don't believe you have to preload the motor side. The other side has a sensor to determine the angle of opening of the tgv's inside the housing. That sensor needs to be preloaded by inserting it, then rotating 90*. I have never really played with the motor side before, but wouldn't think it would have the preload as it is controling the movement of the rod.
I also don't think scoobymods has anything about the motor replacement. They have the sensor replacement bit on there I am sure of. Tony |
01-05-2007, 11:19 AM | #8 |
Member#: 48180
So while the car is off I'm assuming the valves are shut?
01-05-2007, 01:15 PM | #9 |
Member#: 48180
01-05-2007, 04:39 PM | #10 |
Member#: 48180
bump for putting this thing in before i need to go to work.
01-18-2007, 09:41 AM | #11 |
Member#: 3782
South East
Vehicle:02 WRX WFC#040 Clean on 19's |
I had this issue, it was fixed with plumbers tape bent around the sensor and bolted in, been working fine for 50k miles!
01-18-2007, 10:04 AM | #12 |
Member#: 12344
Vehicle:2002 2JC blue |
If you are very careful you can use JB weld, or even one of those acrylate instant glues. I have done lots of fixes with those two. I have also used the expanding type (not recommended for this job!) Gorilla glue. It is very important to not use too much and to hold, tape, or clamp the pieces together until cured. You don't want glue on the gear.
01-18-2007, 10:38 AM | #13 |
Member#: 64246
I have extras - cheap. PM if interested.
01-18-2007, 12:14 PM | #14 |
Member#: 65852
Vehicle:02 Wrx wagon |
delete them, it's free and hp friendly!
01-18-2007, 12:29 PM | #15 |
Member#: 64246
01-18-2007, 12:38 PM | #16 |
Member#: 25731
Vehicle:02 wrx(sold)/2005 Sti/ 93 Leg Wag |
LIke Tony said, the sensor will need to be pre-loaded, not the motor. Install the motor as usual, then put the sensor on at a 9 o'clock position and twist it to 12 'clock (or is it 12 to 3?..it's been awhile)......or TGV delete as mentioned. If you really get in a hurry just unplug all 4 sensors and live with the cel for a bit.
edit: actually 12 - 3 seems right...... |
04-26-2021, 06:47 PM | #17 |
Member#: 518403
Do you have the motor PN??
I broke it aswell and have been looking for the part locally for a week and nobody seems to know of it
fs: aps tgv deletes with 04 sti tgv motors | boostinwrx | Engine/Power/Exhaust | 2 | 12-03-2009 08:56 AM |
Does anyone have a spare TGV motor? | stichris | Mid Atlantic Impreza Club -- MAIC | 1 | 10-02-2006 05:32 AM |
WTB : TGV motor/actuator/thing | prototypeWRX | TXIC Private Classifieds | 0 | 09-20-2006 12:49 PM |
tgv motor /senser what does it control ? | suprasingle | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 10-25-2002 11:22 PM |
I busted my headlight. What are my options? Morette? | BoxeRShorts | General Forum Archive | 1 | 03-01-2001 08:48 PM |
