04-17-2021, 11:42 PM | #1 |
Member#: 515308
Now a p1571 immo issue
So after engine build and car sitting for 6mos or so I am getting a p1571, immo code issue. I have a spare ecu I cloned and it also is showing p1571, I even pulled the immo chip of one of the ecu and verified the file and replaced it. No dice. I知 thinking I will need a trip to dealer to try and reprogram for the keys.
I guess I値l flash a stock rom in and just change the injector settings so they might not be freaked out by the merp modded ecu. Thousands into tos engine and I would love to get past this
04-18-2021, 09:06 AM | #2 |
Member#: 515308
I have tried both ecu, both keys, checked both immo chips. It must be something other than the ecu or keys. Guess I値l make an appointment, I hate paying the dealer
04-18-2021, 08:45 PM | #3 |
Member#: 515308
I知 going to buy a ssm3. Maybe vxdiag, I値l try w my open port with the software first but I think I値l buy the vxdiag before I tow it to the dealer. I hope
04-19-2021, 04:55 PM | #4 |
Member#: 515308
Vxdiag enroute, I have the 2 security pin cards on my spare key so I think I can get it done
04-19-2021, 10:53 PM | #5 |
Member#: 515308
05-08 forester xt learning code 3178
09-13 Forester xt 3781 05-07 Impreza 3178 08-11 Impreza 3781 Also, p1571 looks like bad code in ecu or biu. Since I have 2 ecu, I imagine it痴 in the body unit. |
04-25-2021, 07:52 AM | #6 |
Member#: 515308
Still waiting on ssm3, here is some key cutting and prog info
https://subaru.locksmithsdrm.com/SubaruSDRM/downloads/subaru_service_bulletin.pdf |
04-29-2021, 07:09 PM | #7 |
Member#: 515308
Vx diag is the ****, took forever to get working on my laptop, but once I ran a all systems check it woke up the immo. All good and an idle.
04-30-2021, 05:24 PM | #8 |
Member#: 515308
Ok who needs ssm3, I知 very excited to get my car back, I was on 3rd string vehicle, was getting old
04-19-2022, 10:28 PM | #9 |
Member#: 521029
What was your fix exactly I got the same code and multiple modules and can稚 get it to start
04-22-2022, 12:52 PM | #10 |
Member#: 515308
I bought a ssm3/vxdiag and fixed it doing a relearn, didn稚 even have to do the relearn, it woke it up when I connected to it. I think it was from battery being out for 3mos
08-19-2023, 10:14 PM | #11 |
Member#: 400886
Vehicle:2004 STi PSM 2010 STi SSM Hatchback |
Where did you get it and which did you get? Was thinking about VXdiag for some ABS check/reset but feels a little dirty. Any recommendation of something that worked well is better than rando.
09-28-2023, 11:03 AM | #12 |
Member#: 535649
I've made attempts to resolve the issue by testing both ECUs and using both keys, even verifying the immobilizer chips. It appears that the problem lies elsewhere, possibly unrelated to the ECUs or keys. As a next step, it might be best to schedule an appointment for professional assistance, even though I understand your reluctance to pay dealership fees. Sometimes, getting the expertise of a qualified technician is the most efficient way to diagnose and address complex vehicle issues. They can help pinpoint the problem and potentially offer a more cost-effective solution of Questcraft Mods, Pojavlauncher
