07-19-2017, 04:13 PM | #1 |
Vendor Sales Rating: (43)
Member#: 198281
MAIC
Vehicle:2005 WRX/STi WRB of course |
Killer B Motorsport V4 CAST Performance Oil Pan
You may have heard the rumors, or even seen a sneak peek at one of the events we attended this summer, but it's true... We have started production.
New for 2017 Killer B Motorsport V4 Cast Aluminum Performance Oil Pan Features: Track Tested High Performance Oil Pan Thick Walled Aluminum throughout Advanced Heat Treatment for Improved Toughness and Strength Machined FLAT Flange Surface for Leak Free Installs Precision Machined Mounting Holes 6 quart capacity M20 Port (OEM) 1/2NPT Port Uses OEM Dipstick Tube Includes Hardware Let me know if anyone has any questions
__________________
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. vs. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
07-19-2017, 06:21 PM | #3 |
Member#: 198281
MAIC
__________________
07-20-2017, 10:44 AM | #5 |
Member#: 198281
MAIC
__________________
11-04-2017, 05:42 PM | #7 |
Member#: 198281
MAIC
Right now we have a small lead time on the new cast pan, a couple weeks and we should be all caught up.
I know it's early, but we do sometimes run out of stock during the spring-time rush. Don't wait until the last minute
__________________
03-15-2021, 06:32 AM | #8 |
Member#: 198281
MAIC
New for 2021 we've split into 2 lines. Our traditional V4 cast oil pan and the new extreme performance Super-G. Check out the Super-G and let me know if you have any questions...
Super-G Extreme Performance oil Pan
__________________
04-19-2021, 08:03 AM | #10 |
Member#: 198281
MAIC
__________________
06-03-2021, 08:32 AM | #11 |
Member#: 198281
MAIC
To all of you who have purchased our new Super G Pan and High Flow Pickup.
We are interested in your feedback and data. We would love to get some plots that include telemetry, oil pressure, oil temperature, and crankcase pressure. We have sold a lot of these pans and our customers have been generous with feedback, but more is always better.
Learn More
__________________
06-08-2021, 03:41 PM | #12 |
Member#: 198281
MAIC
Fun fact...
We use a proprietary casting process that allows thinner walls with no draft required. A benefit of using this process technology is that it allows pan geometry that can hold more oil. More oil means more 'residence time' (the time oil spends in the sump before it gets sucked back into the engine). Any increase is residence time will decrease aeration. Improved oil residence time has been shown to de-aerate oil better than 'de-aeration baffles'. Improvements in de-aeration increase oil pressure, reduce heat, and improve overall lubrication system function.
__________________
06-15-2021, 04:29 PM | #15 |
Member#: 198281
MAIC
^ Yes this
Yes they will. depending on which OEM TS manifold, the heat shield may need to be trimmed to provide clearance.
__________________
06-22-2021, 03:06 AM | #16 |
Member Sales Rating: (49)
Member#: 50586
BAIC
Vehicle:64 Impala |
Mine did not fit with OEM TS headers, I didn't try to trim the heatshield but it doesn't look like it wouldn't fit even with trimming.....there's pics in my thread
06-22-2021, 08:03 AM | #17 |
Member#: 198281
MAIC
I just checked it out and responded. That looks normal for JDM TS contact points. Trimming the heat shield should do the trick. Although, I'd like to see how far off the gaskets the flanges are. Feel free to PM me pics.
__________________
08-13-2021, 07:24 AM | #19 | |
Member#: 198281
MAIC
We see this kind of thing on occasion. Mostly from install error, what we call 'forced' installs; installer doesn't remove the manifold, and/or doesn't jack the engine up, and forces the pickup through the baffle. That is 95% of the failures we see. Even at that this was less than 1% and FAR higher with the older 100% fabricated pan design. Likely due to to increased tension that 120" of weld can induce. The current cast pan design is obviously a very different process and we opened up areas in the baffle to add some more installation clearance. Additionally, the design was further changed to reduce heat cycling stresses. The pan in the Smedia vid is older and has an older baffle, and we will replace it with the latest design. I won't know what the cause of the failure is until we get it here to review. Perfection is something we strive for, but in reality is unobtainable. We all make mistakes, but how we respond to that can have the biggest impact. Even when pans have been installed incorrectly, we replaced the baffle under warranty with some guidance on installation, but would NOT cover it after a second occurrence. I wish I could say we never saw one come back a second time for a forced install, but it has happened Never once has this cause an engine issue. The pan is under a constant oil bath. There is no rubbing or chafing of metal-on-metal as most assume, and the parts can be seen fitting together like a puzzle with no bits missing, even under magnification. Oh, and if you've replaced enough OEM pans, you will occasionally find a broken OEM pan baffle, or even a missing tack weld For fun, here's a pic from one of the forced installs....
__________________
08-19-2021, 04:00 PM | #21 | |
Member#: 198281
MAIC
Do you have a cracked baffle? If so, reach out to us.
__________________
08-19-2021, 09:56 PM | #22 | |
Member#: 50586
BAIC
Vehicle:64 Impala |
I have no idea if it's cracked or not because its on the car. I guess I can use a borescope when I change the oil next time.
08-19-2021, 05:11 PM | #24 |
Member#: 198281
MAIC
__________________
08-20-2021, 06:21 PM | #25 |
Member#: 382191
Vehicle:2006 WRX |
I haven't seen it yet (or I keep missing it); What is the height difference between this and the OEM EJ Pans? Does it hang below any of the bottom bits when installed (in my case, an 06)?
