07-28-2020, 09:09 PM | #1 |
Member#: 132978
Vehicle:2004 Mike angel tund efr 7670 1.05 Twiscroll |
Xona 6564 x3c 586 whp mustang Dyno
Event: dyno pull Location: All access tuning/ Devin le blanc. Las Vegas Nevada. Mustang Dyno Ambient Temp: 100 F Elevation: 2001 ft. Weather: hot as fuk, July vegas weather Track and Conditions: Dyno is rollers Tires: hankook Ventus v12 255/35/18 Car: 1994 gc coupe Tuner: Devin le blanc, all access tuning Las Vegas Nevada Dyno Info: mustang Transmission: factory sti 6 speed 2005 Gear: 4th gear Peak HP at RPM: 586 @ 6444 rpm Peak Torque at RPM: 508 @ 5821 rpm Baseline hp/tq for a stock on same dyno: 200 Target Boost: 30 psi Target AFR: dunno Fuel: good E85 Engine/Power Modifications: built longblock. Fobiawrx rotated kit, xona 6564 x3c .82. Id 1700cc injectors. Built heads gsc II cams +1mm intake valves.
07-30-2020, 01:55 AM | #2 |
Member#: 452601
some nice numbers there have you been down the 1/4 mile yet
07-30-2020, 02:54 AM | #3 |
Member#: 132978
07-30-2020, 11:11 AM | #4 |
Member#: 80649
South East
Vehicle:2000 2.5 Auto-X RSTi Sparkly |
You'll want to put the outlet of the AOS somewhere else. The crawford WILL dump oil when you start pushing it through corners, and it's right over the hot side of the turbo. That is a fire waiting to happen.
I've had the crawford before, had the oil push issue, converted to IAG, still pushed some oil. |
07-30-2020, 12:07 PM | #5 | |
Member#: 132978
08-12-2020, 02:53 AM | #6 |
Member#: 92894
BAIC
Vehicle:2015 Wrx - fury kit silver duh |
Curious how are you liking that turbo? I've been eyeing Xona Rotors for quite sometime now.
Also where did you get that BOV/intercooler hose adapter from? |
08-12-2020, 07:15 PM | #7 |
Member#: 366241
South East
Vehicle:2009 09 wrx delivery Dgm |
08-12-2020, 07:23 PM | #8 |
Member#: 92894
BAIC
^^ thanks silversufer05
08-13-2020, 01:47 AM | #9 |
Member#: 132978
08-13-2020, 01:49 AM | #10 |
Member#: 132978
As of now I have had no problems with turbo. The powerband is very linear and really easy to control.
Only thing suks is the wait from fp. This was 3 months before COVID. Now it's probably longer. |
08-19-2020, 08:54 PM | #11 |
Member#: 478704
what is the mass air setup
08-25-2020, 10:40 PM | #12 |
Member#: 132978
08-28-2020, 10:54 PM | #13 |
Member#: 163648
MWSOC
Vehicle:2002 WRX V9 6mt R180 Brembos |
Nice GC, looks tough in that first photo. 586whp and set up totear up the corners, that sounds like fun.
Fobiawrx's Stuff is top notch. Enjoy! |
08-29-2020, 02:01 AM | #14 |
Member#: 132978
08-30-2020, 10:27 PM | #15 |
Member#: 48377
MWSOC
Vehicle:1996 Gutted, built XP class Impreza L |
That is a beautiful car. Love the setup. The power delivery is awesome.
Advice from a friend- make sure your hood latches are not knock-offs. He had his hood open unexpectedly at 125mph on a straight (thankfully). I'd be a bit worried about the line that runs over the hotside of the turbo. May want a bit more clearance than what I can see in the pictures. |
09-02-2020, 01:41 PM | #16 | |
Member#: 132978
Thanks for compliments bud! |
09-02-2020, 02:27 PM | #17 |
Member#: 501446
Vehicle:'15 WRX gone plaid |
09-05-2020, 12:24 PM | #18 | |
Member#: 132978
11-24-2020, 10:28 AM | #19 |
Member#: 332869
International
Vehicle:2007 STI lmtd #089 Morning Frost White |
I'm curios what clutch you are using.
12-20-2020, 03:26 AM | #20 |
Member#: 132978
03-18-2021, 09:58 AM | #21 |
Member#: 339923
Vehicle:2006 Impreza WRX STi grey |
how's the boost come on when on the street/track? i'm debating on a few turbos but this xona has definitely caught my eye. looks very similar to the 3076 by garrett. how fast does it hit spool and how's transient response?
03-22-2021, 02:17 AM | #22 |
Member#: 132978
I thought Dyno plot looked laggy in my opinion, even called fperformance turbo and talked to one of their techs about it. Wyatt from Fp said this turbo is similar to gt35 turbo, but boost comes in sooner. On the street it’s snappy, and between gears it spools up quick. On street I’m getting 28psi at 4500k. But then again this is on a 2600 lbs. car so my results might differ then yours.
