Closed Thread
Old 11-29-2003, 10:13 PM   #1
Extraze
Member#: 16980
Default 2004 STi ECU Wiring diagram
Wondering if there is a document out there ...
im looking for ECU wires to tap for an HKS Camp system...
thanks
Extraze is offline
Old 11-30-2003, 03:14 PM   #2
NicGordon
Member#: 24827
2008 Kia Spectra
I can look into after work on Tuesday. I have the shop manual, so maybe it'll be in there.
NicGordon is offline
Old 11-30-2003, 03:44 PM   #3
Extraze
Member#: 16980
that would be great !
i only need :
RPM Signal
Speed Sensor
Injection Pulse
let me know ... thanks
Extraze is offline
Old 11-30-2003, 07:09 PM   #4
brunetmj
Member#: 8023
2019 Crosstrek
white
Speed sensor and tach wire can be found on connector I11 on the back of the gauges I11 is a ten pin connector , the smallest. Blue/green is the tach (c5 -toward the center) and green/black is the speed(c2 on the end) . I know they both work bcause i use both. Injector pulse i will have to look up.
brunetmj is offline
Old 12-01-2003, 02:41 PM   #5
TreyS
Member#: 42478
2004 WRX STi
White/Gold
I looked up those sensors on the STi ecu pinout (ECM I/O Signal) from the manual I downloaded and got this:
Plug B134:
Pin 23 = I RPM
Plug B135:
Pin 5 = B 12v Switched (ignition)
Pin 19 = U 12v Constant
Pin 27 = S Speed Sensor
Plug B136:
Pin 3 = #4 injector
Pin 4 = #3 injector
Pin 5 = #2 injector
Pin 6 = #1 injector
Pin 22 = P (FCD)
Pin 23 = P (AFR) Air/ Fuel
Plug B137:
Pin 1 = E Ground
*There was no TPS info for our ECU I guess because we are drive by wire but this was the info on the diagram for the STi:
Plug B136:
Pin 18 = Main; Fully Closed = 0.6; Fully Open = 3.96
Pin 29 = Sub; Fully Closed = 1.48; Fully Open = 4.17
TreyS is offline
Old 12-01-2003, 02:44 PM   #6
TreyS
Member#: 42478
2004 WRX STi
White/Gold
Pinouts are here
You might have to go to page 2 then back to 1 to see page 1.
TreyS is offline
Old 12-01-2003, 07:39 PM   #7
Extraze
Member#: 16980
Plug B134:
Pin 23 = I RPM
Plug B135:
Plug B136:
Pin 3 = #4 injector
Pin 4 = #3 injector
Pin 5 = #2 injector
Pin 6 = #1 injector
Pin 22 = P (FCD)
Plug B137:
Pin 1 = E Ground
Plug B136:
hmmm ... RPM and Speed sensors are quite obvious ... i dont know what people use for injector pulse ? maybe any of the 4 injector wires ?
any one has wired a HKS CAMP can shed any light on this ?
thanks for the help guys
Extraze is offline
Old 12-03-2003, 01:54 AM   #8
brunetmj
Member#: 8023
2019 Crosstrek
white
The problem i ran into was the difficulty in tapping one of those wires (can't remember which one-tach or speed?) because it is buried in the center of the plug.Thats why i suggested picking them up behind the gauges where there is room to work.Up to you of course.
brunetmj is offline
Old 12-16-2003, 03:41 PM   #9
WolfDrive
Member#: 49506
2004 Impreza WRX STi
Java Black
So when we're measuring Air/Fuel Ratio we should tap into the Mass Air Flow Sensor?
Is there any wire for measuring EGT's?
WolfDrive is offline
Old 08-02-2013, 01:24 PM   #10
marcinna
Member#: 364137
just wondering if anyone has a guide for a bee*r in a 04 sti?
marcinna is offline
Old 08-02-2013, 02:36 PM   #11
Mulder
Trust no one
Member#: 11170
02 RAV4 MT
15 WRX/11 CRZ
Please don't bump 10-year-old threads.
Mulder is offline
Closed Thread
05+ JDM STI ECU Wiring Diagram JSarv Subaru Conversions 0 10-17-2009 11:40 PM
04 STi ECU Wiring Diagrams turbo2ltr Engine Management & Tuning 3 06-30-2004 06:09 AM
STi ecu wiring diagram STiMe Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 03-25-2004 03:23 PM
