09-14-2003, 03:42 PM | #1 |
Member#: 14246
How to install HKS BOV? Help
Hi can anyone know how to install the BOV for my sti?
i know it easy, but this is the first time for me ,so i want to know anything i need to be more careful ?or anyone can give me the instruction please? thanks a lot.
09-14-2003, 06:21 PM | #2 |
Member#: 40110
Vehicle:04 STI 131 MPH 4th gear Madness |
this is real easy!!!
just take the two (12mm)bolts that hold the stock blowoff valve off pull it out from the bottom hose, take the vacum line off the stock blowoff valve, cut about 3" of that hose suply in the hks blow off valve kit put one end on the hks bov secure with the ring-clamp the other on the filter suply then put the vacum line on the oder end of the filter (notice how one side is bigger than the other) the fat side is where the stock vacum goes sucure it with a ziptight ,put the plug suply in the hose and secure with the clamp, fasten the two (12mm) bolts and go make some noice. i wish i could post pictures is much better with pictures,but is so easy. i just took mines out today cause it stop working took it apart clean it nothing. hope you have better luck than me.i only had mines for 4 month's. |
HOW to install HKS turbo timer? | Kyle_R | Electrical & Lighting | 5 | 01-24-2009 01:28 PM |
How to install stock BOV back?? | BBBsti LTD | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 12 | 08-23-2006 05:02 AM |
Any One Have Direction On How To Install Hks Camp | JayRObrero | Interior & Exterior Modification | 2 | 11-27-2004 06:02 PM |
How To Install HKS BOV? | SpoonTypeR | Newbies & FAQs | 8 | 12-12-2003 10:20 AM |
Question on how to adjust HKS BOV | S-WRX | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 10-27-2002 04:31 PM |
